Help finding RC10T2 rear arm mounts
I recently acquired a t2 and one of the rear arm mounts is broken. There was a thread about these somewhere in the forum, but the last post was a while ago and they seemed to be rare then. Any ideas where to start searching? Thanks in advance!
- Has thanked: 170 times
- Been thanked: 23 times
Re: Help finding RC10T2 rear arm mounts
Did it have RC10 1.5 degree mounts on it? They break so easily. The 10T/T2 3 degree mounts are pretty hard to break! They're also the rarest mount around unfortunately. You'll only find them on Ebay.
Sorry for the late reply, but here are the part numbers that I came up with... Associated 7363, RPM7062, are both 3 degrees, and Robinson RRP2035 wich is 3.5 degrees. Thanks for the input so far.
You may be able to find them here.
http://www.hobbywholesale.com/ProductInfo.aspx?productid=784695073630
- 1845 Views
Last post by cowsrneat2002
- 1241 Views
Last post by ELF-BMX
- 1175 Views
Last post by longboardnj
- 509 Views
- 1739 Views
Last post by templeofspeed
- 1348 Views
Last post by DaveM
- 777 Views
Last post by tony6187
- 1531 Views
Last post by askbob
