Kyosho now on the re-re bandwagon - Scorpion
The place for all things re-release Kyosho.
Oozzee
Has thanked: 21 times
Re: Kyosho now on the re-re bandwagon - Scorpion
Post by Oozzee »
wydraz wrote:Any credibility to these Optima Mid 2015 rere rumours?
Rumours, what rumours where can i find this information,
ohh man another car, she who must be obeyed will not be happy with me :mrgreen:
The Dreaded 7 - 10 Split
wydraz
Post by wydraz »
Maybe it is just one person stirring and there's no substance to it?
Just wondered if anyone had heard anything?
kaiser
Post by kaiser »
CHKTM wrote:If it is the std bind that is included in the kit it will be the dogbone being fractionally long causing it. See if removing the dogbone eliminates the issue. I ground the ends down on mine to remedy this. My friend says the issue isn't there when using the universal shafts. I think Kyosho should have included these instead of the piece of paper telling you how they think it will be fixed by loosening the arm mounts and pulling forward on the arms while tightening which may or may not work. It didn't for me. Contacting Kyosho might be worth a go, see if they'll send out some universal shafts.
it's not the dogbone. i had it all free and working fine before it's first trip to the track. the jumps were a bit too big for the scorp, i think it's a bent pin.
i looked at it quick last night, but was prepping other cars for a trip to the track tonight.
i do have a spare arm, i'll mount that up and see, if it persists then it's the pin.
CHKTM
Post by CHKTM »
it's not the dogbone. i had it all free and working fine before it's first trip to the track. the jumps were a bit too big for the score, i think it's a bent pin.
i do have a spare arm, i'll mount that up and see, if it persists then it's the pin.[/quote]
Ah fair enough, hope you can sort it easy enough.
Brandon G
Post by Brandon G »
kaiser wrote:my friend is convinced his fast attack is going to "school" my scorpion. i laughed and told him to bring it on.
I swear I think the last time I'd heard this phrase I was in 8th grade....... :)
kaiser
Post by kaiser »
which one? school or bring it on? lol
or the whole thing....8th grade was awesome!!!!!!
CHKTM
Post by CHKTM »
Lol, I'm sure the outcome was similar then also :lol:
kaiser
Post by kaiser »
this thing is my new "yard car". it's so much fun on grass/lawn.
it's got the weight to really dig in. i'm going to use it to cut in a small track in the back.
HKS_TRD
Post by HKS_TRD »
Are the front tyres of the rere compatible with the original sc-26?
If so do they look identical?
tamiya
Been thanked: 9 times
Post by tamiya »
HKS_TRD wrote:Are the front tyres of the rere compatible with the original sc-26?
1 more rib isn't it?
Raman
Has thanked: 7 times
Post by Raman »
You just reminded me.. I have a set of SC-26 NIB.. PM me if you are interested
dj_kilroy
2.2 modern wheels for the scorpion
Post by dj_kilroy »
Hey guys,
Has anyone fitted 12mm hexs to the rear of the Scorpion and 2.2 wheels to the front.
I'd be keen to know which wheels fit so I can run some modern rubber.
Cheers
Kilroy
Raman
Post by Raman »
During my Tomahawk build, I finally realised the mistake I had made which caused my re-re Scorpions rear arms to bind. Having owned many of these chassis, I just simply assumed it should be built like my original one.
The two suspension shaft holders have a tapered end. The correct way to install them is: install the taller one with taper side up and the shorter one taper side down. Its clearly shown in the manual but I overlooked it.
Been thanked: 3917 times
It's also shown clearly in the OLD manual how to center the trans, which is what was causing my bind. After loosening and allowing everything to settle, and retightening it was perfect. Not sure why they didn't carry over the important notes from years ago
Return to “Kyosho Re-Release Forum”
