#6002 - RC10 Worlds Car Kit
bully
Been thanked: 6 times
Re: #6002 - RC10 Worlds Car Kit
Post by bully »
I believe the bolt head goes on spur side mate...
abailey21
Post by abailey21 »
NickTheGreek wrote:Anyone else have an issue with the the steering being too tight as soon as you start screwing in the bellcrank bushing nut?? The bellcranks won't freely turn after like two turns of the nut.
How do I fix this?
Yeah, mine was the same way, I just found some bearings laying around, but I did put a drop of shock oil on the bushings to help before installing the bearings and it did help a little
NickTheGreek
Post by NickTheGreek »
bully wrote:I believe the bolt head goes on spur side mate...
I don't wanna sound like a moron, but how do you know which side that is?? Is it the side with the thrust spring and the the locking t-nut or the opposite end with the diff cover??
Thanks
Edit: ah yes, the head of the diff thrust bolt....i guess I figured it out,I hope.....Thanks.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
The side that has the bolt head (the side you adjust it from) goes on the same side as the spur gear.
popboy905
Been thanked: 10 times
Post by popboy905 »
anyone run there re-re worlds yet? is the tranny quiet like a b4, or is louder like the original stealth compared to a 2.6 tranny?
harvey
Post by harvey »
I ran the worlds tranny in my drill press at 3200 rpm with toothpaste and no diff. It sounded like gravel. That's as far as I've gotten.
GoldRush
Post by GoldRush »
well my worlds kit has some 90's era parts in it now :lol: ....found 4 flanged bearings for the bell cranks...now my steering is smooth. why wouldn't associated just put bearing in the bell cranks over bushings? kinda stupid. I mean its not like im going for spot on 100% accurate worlds car here.
do you think its a bad twilight zone episode for team associated to be re producing a buggy from yesteryear that is capable of beating their latest and greatest production buggy?
mtbkym01
Has thanked: 190 times
Been thanked: 274 times
Post by mtbkym01 »
Picked up my Worlds Car kit today from my LHS, no oil spillage 8) , and measured my top shaft from the gear to the flat = 13.62mm or 0.536 in.
Now, does this mean its good or bad?? :mrgreen:
If it's Old Skool, It's Kool
RC10th
Post by RC10th »
I'm keen to know this too as our cars likely came from the same batch :D
Twin Detonator
Post by Twin Detonator »
GoldRush wrote:well my worlds kit has some 90's era parts in it now :lol: .....
Same here... I got some brand new front 3 piece florescent yellow wheels coming today and I had some white vintage steering arms and axles in my parts box for the wheels to fit them. I will also put the front body post on the right steering arm screw like the original Worlds kit car was.
I also got some older electronics to go in for a vintage look as well.
I will do the body my own styled version of the Worlds car instead of a box art replica to break it up a bit.
Lynn
Patiofurnituregt
Post by Patiofurnituregt »
GoldRush wrote:well my worlds kit has some 90's era parts in it now :lol: ....found 4 flanged bearings for the bell cranks...now my steering is smooth. why wouldn't associated just put bearing in the bell cranks over bushings? kinda stupid. I mean its not like im going for spot on 100% accurate worlds car here.
Quite simply, cost and being a little more true to the original. Those 1/4"x 3/8" flanged bearings are certainly not the cheapest of the bearings to include.
Tim Tunnermann
Team Associated Design Engineer
Team Associated | |Reedy | XP Digital | JConcepts | Futaba | Makita | Kicker | LiveRC
Has thanked: 358 times
Been thanked: 470 times
The 93'came w/ bushings anyway :lol:
theibault
Post by theibault »
Just finished mine. Need to see what electronics to throw into this.
hondaman
Post by hondaman »
Well my new top shaft came in from AE and so did my bearings for the steering from oldrc.com.. Going to be rebuilding my tranny and installing the bearings.. FYI oldrc.com has the bearings(stb897) for $2.99 for a pair.. Will post my results..
Shawn
Twin Detonator
Here is my WC, it has some vintage 3 pc. wheels, steering arms, spindles, green springs, vintage WC instruction mounted front body mount, and vintage electronics. I have to get a motor for it still and do up the body.
Next to my B4.2 carpet racer.
Lynn
Users browsing this forum: No User Avatartommy911t and 7 guests
