1993 Brian Kinwald Replica (last update 12/12/2009)
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
Re: 1993 Brian Kinwald Replica
that's a freaking sweet looking ride kenooze. did you polish the nose tubes? and, what did you use to cut the front shock tower?
- kenooze It’s my birthday!
After several minutes of work (with a file), the front tower is down.
Just after I started to work on the front and rear custom body mounts.
(Not sure to be really right with length, may be too long...)
The building process continue.
In first, the front body mount fit the nose plate.
The Houge enterprise steering levers fit his RCPS turnbuckles and white ball cups.
Tower and camber links fit the waiting front end.
They shocks could be assembled to complete the front end.
Now the front end could fit the chassis.
Before all, I have to reduce the length of the nose brace and polish it slightly.
(BK used 2 small Aluminium blue washers, probably to balance the lost length due to a chanfer at the end to join perfectly the nose plate???)
Nothing to say.
Excepted, I definitively need the right screws and a black lower spring cup...
Or.
Nothing to say.
Or.
Not so easy to glue properly they tires on wheels, without the inner and outer edges.
Near to the end of the project ???
Next step, fidding the right screws (titanium or stainless steel) and a lower black spring cup, making the fiberglass battery brace, building a gear cover, fidding the right speedo heatsink and fitting the electronics.
Please help me with Mr Lexan to make me a RCPS Mirage SS shell WITH airscoop, send him a wave of PM asking him this special release .
Him also looking for Sanyo florescent pink stickers and Kimbrough black servo orns to fit Airtronics steering servo
- JPAE07
Re: 1993 Brian Kinwald Replica (last update 12/12/2009)
Cedric,
As it sits. Awesome work!!!!!! I only wish Brian could see it and give you some feedback on the perfection of your build.
- m_vice
it might be excessively perfect. i love it.JPAE07 wrote:Cedric,
- littleVETTE
i'll say it again, that's hawt cedric. that rear motor mount really brings out the car. i noticed the set screw you put in, in the front axles. detail!
why not just dye that white spring cup black?
Very nice! Now all you need is that Mirage SS body to top it off.
- call-911
Ha!! Now you're just showing off! VERY NICE BUILD!!!
Keith C
Re: 1993 Brian Kinwald Replica (last update 02/01/2010)
Well, the car looks near to be down but not already finish for 2009
I still have to hand made the battery tray.
BUT, the 3D file of this car are down and looks terrific, isn't it ?
Blow me down! What more can you ask for? Masterpiece.
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
- 115 Replies
- 38688 Views
Last post by kaiser
- 44 Replies
- 15605 Views
Last post by Cplus
- 1211 Views
Last post by keyesgood
- 46 Replies
- 8600 Views
Last post by mikea96
- 1796 Views
Last post by TUCRACEMAN
- 27 Replies
- 8153 Views
Last post by jamin
- 3565 Views
Last post by hugger19
- 2299 Views
Users browsing this forum: Ahrefs [Bot] and 5 guests
