RC10 - FF10 -Done-
- chilihook
- Regular Member
Re: RC10 FF
Wow. It's pretty clear that this is the "deep end of the pool" when it comes to builds! Absolutely amazing. Can't wait to see it running.
- sandkil
- Has thanked: 795 times
- Been thanked: 623 times
Re: RC10 FF
Thank you so much, chilihook.
It is quite a substantial build and it’s a bit learning by doing.
Fortunately the knowledge is out there and after much researching and finding other FF builds the picture of what’s needed clears to some extent
I was offered a set of Yokomo wheel adapters from Mr. ED and as I had a pair of Yokomo ZC-800 wheels and a pair of Schumacher U6797 tires it seemed fitting for this build.
I also finished the last bit on the trailing arms. M2 grub screw for securing the toe in setting.
Still waiting on the Mirage SS body. Once received I can determine body and wing post placement.
- Has thanked: 2759 times
- Been thanked: 2250 times
Re: RC10 FF
Wow! ! ! How did I miss this build ? This is really well done , you should be pleased as punch with the result
I'm deeply jealous of your car , can't wait to see it run !
- sandkil
Re: RC10 FF
Thank you so much, Dadio! I’m pretty pleased with it so far.
I’m stuck regarding the rear body mount..
Don’t know if to do an aluminum/steel bar influenced by the Yokomo 834 (on inside of body), neodymium magnets or two pan car posts..
I need your input guys..
Pictures with the Mirage SS body from Sabula Tech/Oldrc.com.
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Re: RC10 FF
I think I'd throw some electrics in there and then look at what space there is for mounting points , the later 834 RPS style roll hoop might fit well but its not delicate or refined to look at and the rest of the build looks refined and light , I might put two posts at the rear on the body side pods , that would be subtle with the body off and secure when its on . Or as you have Kydex up front an 834 ish Kydex roll hoop at the back ? might look good .
- Has thanked: 7 times
- Been thanked: 42 times
Re: RC10 FF
Are you leaving the rear section of the body intact or chopping it off flush with the rear of the chassis?
- sandkil
Re: RC10 FF
My thought is to leave it as it is now.adam lancia wrote: ↑Fri Jan 22, 2021 5:28 am Are you leaving the rear section of the body intact or chopping it off flush with the rear of the chassis?
Something similar to the HPI-Koga FF, but the Mirage is way longer than the Ultima body.
- sandkil
Re: RC10 FF
I was thinking of small side posts just like the Tamiya F1 has. Just want them in white. I'll see what i find in the boxes. Kydex roll hoope is a good one as well.Dadio wrote: ↑Fri Jan 22, 2021 5:07 am I think I'd throw some electrics in there and then look at what space there is for mounting points , the later 834 RPS style roll hoop might fit well but its not delicate or refined to look at and the rest of the build looks refined and light , I might put two posts at the rear on the body side pods , that would be subtle with the body off and secure when its on . Or as you have Kydex up front an 834 ish Kydex roll hoop at the back ? might look good .
Appreciate your input.
Yes that goes well with the Yokomo parts and era feel of the build. Just need to make it look good with the rest of the car.. Appreciate your input.
Re: RC10 FF
Gold anodised this could work .
- sandkil
Re: RC10 FF
The Parma Eagle body has the pods to far back. That would result in cutting away parts of the cockpit.
The Losi xx4 body is too narrow for the gold pan. Losi xxx4 might fit, but I need to get that confirmed.
I cant use the RCL Incident body (Ryuz/Kanda Special) as that also are too narrow. 130mm in whith. Gold pan 137mm.
I also have the Kyosho Lazer ZX body that I'm working on. It has the same width as the Mirage SS.
One solution to the rear body post issue is to do a second upper deck at the rear, but that demands a really good design and access to the battery hold down.
- sandkil
Re: RC10 FF
The duck tail is not that bad once the wing comes on. Sure the cockpit is high on the Mirage..
Reminder that the rear end is high as no battery is weighing it down.
Sorry for poor quality on pics
- coxbros1
Re: RC10 FF
pics clear up nicely once tapped on....the body in the last two pics is a go! no need to do anymore research. get it do an entered in botm....just let us all know what month so we can skip that one
- 48 Replies
- 20529 Views
Last post by Turbobuick
- 3302 Views
Last post by Beau S
- 1663 Views
Last post by MBesr25
- 2200 Views
- 1629 Views
Last post by SMOKE-DOG
- 4470 Views
Last post by WebSteve
- 1946 Views
Last post by JosephS
- 2099 Views
Last post by mrduckz
Tbot [Bot] and 4 guests
