Project: LS1 Chevette
THUNDERSTRIKE1
Re: Project: LS1 Chevette
Post by THUNDERSTRIKE1 »
cANT WAIT TIL SEE A VIDEO HAULN ARSE LOL
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
THUNDERSTRIKE1 wrote:cANT WAIT TIL SEE A VIDEO HAULN ARSE LOL
X2 :)
Cheers
Lars
My Feedback
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Time to fry the tires :lol: :lol: :lol:
[youtube]eExBLuJnC8Y[/youtube]
RC10th wrote:Time to fry the tires :lol: :lol: :lol:
Man, what a lame launch. And that lime green stripe does *not* work well with the orange...ugh. :x
RC10th
Post by RC10th »
Yes, it killed me to post that video being a Charger and General Lee fan.
Halgar
Has thanked: 146 times
Been thanked: 200 times
Post by Halgar »
Guess it should run and idle before you try to fry the tires. :lol:
Agreed on the green slime stripe.
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
Man that was a horrible burnout or whatever you want to call that :lol:
I promise to not dissapoint when the time comes. Car is back on the ground for the time being. Finished the crossmember supports, throttle cable in, and placed an order to start on the cooling and brakes. Im relocating the master cylinder to the inside. The master would fit in the stock location but the gas pedal is now where the brake pedal use to be so it will be easier to just relocate it. Won't hurt to re line the entire car too.
TRX-1-3
Has thanked: 2068 times
Been thanked: 992 times
Post by TRX-1-3 »
I'm such a schmuck I wouldn't want to smoke the tires. All that undue wear an tear would keep me up at night. Alternate pronunciation would be "Pew-see".
THUNDERSTRIKE1
My Honda mini van does a better burnout! :lol: DON
romulus22
Post by romulus22 »
Got some parts in the mail. Radiator fits just needs mounted.
And I adjusted the axle over to check clearances and take better measurements. Here's the slick with adequate inner clearance and tucked under the fender pretty nice I think. I will definitely need to roll the fender lip still.
romulus22
Post by romulus22 »
Early day at work so I managed to finish the pedal rack assembly.
Tucks up in there nicely.
Getting much closer to sending it off to be wired.
romulus22
Post by romulus22 »
Not a lot of progress. Finished mounting the radiator with some quick easy alum brackets.
Correct offset wheels arrived for the front. Mounted them up and they clear fine.
And lastly did a little more weight reduction. 11.6lbs from the passenger door. Drivers door will follow. Keeping the glass and window crank for now. Door cover will be going back on to hide the ugliness.
SFC K
Has thanked: 47 times
Been thanked: 9 times
Post by SFC K »
That motor just looks bad arse in that bay and I love the new wheels and tires! They are going give away your sleeper look though... :mrgreen:
Jeff
RC10th
Post by RC10th »
I kind of liked the stock wheels myself. If it were mine I would cruise around on the stock wheels and haul the slicks in the back to the track.
Looking good though and getting close, how long do you think till it moves under its own power?
romulus22
Post by romulus22 »
SFC K wrote:That motor just looks bad arse in that bay and I love the new wheels and tires! They are going give away your sleeper look though... :mrgreen:
They are more aggressive looking but I wanted something That would do well on the street. Stock tires were pretty lame in the corners.
RC10th wrote:I kind of liked the stock wheels myself. If it were mine I would cruise around on the stock wheels and haul the slicks in the back to the track.
I have another set of wheels I still need to buy tires for. They will be similar to fronts but slightly wider. Then the slicks will be in the back for the track.
I'm hoping to get it done by mid late summer.
