Inventory updates
Moderator: mytimac
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 56 times
Re: Inventory updates
Some Associated parts back in stock. But also check prices on our other Associated parts. We have adjusted prices on most of our Team Associated parts. We want to get them out the door at fair prices to people here before we start to sell them on eBay in the coming months. I know some of them will go higher on eBay.
7708 RC10GT Air Filter Boot
8184 (black) Antenna Shock Mount (We also have in whote)
7366 Rear Hub O Deg Toe-In Composite
6493 Buggy Front SPring Brown 2.8LBS
8417 Pivot Ball
7668 Diff Outdrive Left
6619 Carb Diff Ball
7706 RC10GT Paper Air Filter Element
8417 Pivot Ball
6619 Carb Diff Ball
- mytimac
- Business Member
Just quick one part thing since these are hard to find right now.
Associated RC10 6451 Shock Collars.
Normal retail price on our store for our supporters here. Plus you can add in other parts you know you want while at it.
We have them at a premium on eBay.
- mytimac
- Business Member
These parts just in. Mostly Losi. Some great Trinity Losi parts mostly for XXX XXXT, one RC10GT. The Trinity XX4 bulkhead is already sold as of just a few hours ago.
https://www.youtube.com/watch?v=p2WCWCgp3bE
- mytimac
- Business Member
Just in, some RPM parts for Losi.
81623 Clawz Chrome Rear Wheels for XXT LXT NXT GTX XXXT XXXNT
81863 Slingshot Chrome Rr Wheels for XXT LXT NXT GTX XXXT XXXNT
7305 JRXT Extra Wide Rear Links
7325 JRXT Extra Wide SIde Bulkheads
7371 Cushioned Front Bumper XX XXT
7355 JRXT Extra Wide Rear Truck Arms
- mytimac
- Business Member
A big Losi parts update.
a1011 Long Thread Tie Rod Set (old style hex)
a1017 LXT GTX NXT Fr Spindles Carriers
A1101 Original XX Bulkhead (white)
A1108 Front Shock Tower (XXT)
a1111 Fr Suspension Arms XXX
a1126 Front Spindles and Carriers
a1210 Front Suspension Arms XX4
A1510 Steering Sector Arm w/screws
a2112 Rear Pivot Block 0Deg CR
a2113 Rear Pivot Block 2Deg CR
a2141 Rear Suspension Arms Truck
A2142 Rear Suspension Arms
A3010 Diff Drive Rings
A3057 Retrofit Transmission Screw Set
A3070 Differential Drive Rings
a4003 Antenna Caps
A4028 Transmission Brace Drake
a4047 Molded Chassis Brace
A4055 Adjustable Front Body Mount
a4116 Battery Strap
A4125 Fr Spindles, Carriers, R Hubs
a4209 Gear Cover XXXS/4
A5004 Shock Shaft .6"
A5002 Shock Body .6" (short)
a5030 Shock Body Hard Anodized (Grey)
a5058 Shock Shaft .28 Ti-Nitride
a5059 .36 Ti-Nitride Shock Shaft
a5152 2.5" Spring 2.6 rate Red
A7001 Front Spoke Rims
A7002 Front Spoke Rims Wild red
a7080 Truck Disc Front Wheels Natural
a7106 Wide Rr Solid Wheels Blue (sold already)
a7198 Truck Disc Wheel Caps
a7184 a7074 RC10T Disc Fr&Rr Wheel Set Yellow
a8102 Adjustable Wing Button Set (sold already)
a8106 XX Wing Wire
a8120 Machined Aluminum Wing Button (kinwald)
a9411 Disc Brake Rebuild Kit XXXNT
a9601 Wheel Tuning Setup Kit
a9756 2 Deg Graph Spindle Set
a9811 Rear Arms Graphite XXXNT
a9830 Graphite Composite Rear Pivot Plate
a9911 Graph Long Battery Strap
A9907 Graphite/Composite Battery HoldDown Strap Standard
a9950 Alum Thrust Bearing Spacer
a9930 Alum Upper Gear Shaft 2.19
a9974 CVD Steel Driveshaft
a4003 Antenna Caps
a4116 Battery Strap
a8106 XX Wing Wire
- mytimac
- Business Member
Very small update of some Losi stuff.
Lunsford 7093 Titanium Front King Pins BallStuds for XX XXCR
RPM 7371 XX XXT Cushioned Front Bumper
RPM 7385 Losi Heavy Duty Front Carriers with King Pins (jrx2, jrxpro, junior,jrxt)
Losi A9951 XX4 Blue Worlds Edition 3DEG Rear Hinge Pin Brace
- mytimac
- Business Member
We just added all these XX Losi parts today. While also updating the store to higher encryption standards. Now all communication is encrypted, not just the checkout.
A1009 Threaded Rod 1.5” Old Style
A1011 Long Tie Rod Set Old Style
A1101 XX XXT (Black) Front Bulkhead
A1110 XX Front Arms
A1115 XXT Front Arms
A1125 Fr Spindles and Carriers XXT
(sold)A1602 Adjustable Steering and Servo Mounts
A2107 CR Rear Pivot Plate
a2126 “CR” Rear Hub Set
a2162 Rear Inner Hinge Pins for CR
a3009 Differential Balls 3-32 (losi part)
a3059 XXT Transmission Case Set 2.61
a3063 XX Motor Plate
a3065 Diff Lube
A3071 XX Thrust Bearing
a3072 Tranny Diff Tube
a3073 Transmission Outdrive Cup
a3074 Tranny Diff Gear 2.19
a3075 Trans Upper Gear and Idler
(sold) a3076 XX Diff Gear 2.61
a3077 XX Trans Upper Gear and Idler 2.61
A3078 Differential Screw Hardware
A3081 Buggy Drive Shaft wYoke (Grey)
a3090 Dogbone with Yoke (grey)
A3124 Spring, Cup, Spacers
A3125 9/16" x 1/4" Thrust Bearing Assembly
A3130 HydraDrive Rebuild Kit
A3132 Slipper Back Plate
a4015 Foam Battery Blocks Black
A4056 XXT Front Body Mount
a4115 Battery Hold Down (x-long)
A4130 XX Front Bumper
A5005 Shock Shaft .9"
a5008 Upper Shock Mount Bushing (newer style)
a5023 Shock Spring Clamps Cups Grey
A5046 Teflon Shock Pistons 56 (Red)
A5132 2" Spring 3.5 Rate (Bright Green)
a5148 Spring 2.0 Rate (yellow)
A5150 2.5" Spring 2.3 rate (pink)
a5152 2.5" Spring 2.6 rate (red)
a6000 Rod End w/Balls (grey)
a6001 Ball Studs w/Ends 4-40 x 3/16 (Grey)
A7505S Fr Directional Tire (silver) XXT Kit Tires
A7638S Rear IFMAR Pin (silver) XXT Kit Tires
A1110 XX Front Arms
a3065 Diff Lube
- mytimac
- Business Member
In a big change we have USED parts on the store now. They are from XX and XXT models we took apart. They had been sitting in boxes for a few years now.
All used parts are labeled USED and have a red picture background.
XX
https://sabulatech.com/storefront/index.php?id_category=14&controller=category
XXT
https://sabulatech.com/storefront/index.php?id_category=15&controller=category
Then new OLDRC.COM stickers.
XX
XXT
- Attachments
- ST8402.jpg (25.81 KiB) Viewed 2619 times
- ST8400.jpg (26.58 KiB) Viewed 2619 times
- mytimac
- Business Member
Oh, Also have good Yokomo YZ10 Protech bodies with tray and wings back in stock.
- mytimac
- Business Member
New stuff in we got coming back from VONATS.
New in stock
Traxxas
1822 Sledgehammer Chassis White
Autographics
301 DieHard Stickers (Combo Sheets)
639 Hardees Stickers
643 Rick Mears/Penske Stickers
10113 Airtronics Gold Decals
Also red blue black
10831 F-Style Truck Decals
10800 Rodney Racer Decals
10801 Power Puff Decals
10802 Freddy Fanatic Decals
10803 Crash Gordon Decals
10804 Will E Hammer Decals
10805 Scardy Cat Decals
10806 Mr Terri Fied Decals
10808 Melvin Monster Decals
10830 C-Style Truck Decals
10832 D-Style Truck Decals
10841 Ford Taurus Decals
10852 Stupid Yellow Signs Decals
10855 Blue Net and Detail Decals
10856 Red Net and Detail Decals
10858 White Net and Detail Decals
10859 Yellow Net and Detail Decals
10866 GunRack Decals
Proline
PL2532 Rear Wheel 2.0 Diameter JRX2 JRXPRO
MIP
1019 Xx/XXX Diff Rebuild
Losi
A1004 Front Shock Tower
A1005 Fr Axles
A1009 Tie Rod Set 1.5”
A1019 A2042 LXT GTX NXT Graphite Arms Set
A1106 KinwalD Fr Tower
A1115 XXt Fr Arms
A1601 Xx Steering parts
A2013 Rear Toe In Links
A2022 H-Arm Hub Clips
A2113 Rr Pivot block 2 deg
A2210 Rear Pivot Blocks
A3010 Differential Drive Rings
A3055 Retrofit Transmission Case Set 2.61:1
A3070 Diff Rings
A3073 Outdrive Cup
A3074 Diff Gear
A3076 Diff Gear (sold out just as posted this)
a7105 A7005 White Rear and Front Wheels Set (2wd)
a7105 A7046 White Rear and Front Wheels Set (4wd)
a9709 XXT Graphite Front Arms
a9730 0 Deg Front Bulkhead XX4 Street Weapon
a9813 XX Graphite Rear Shock Tower
New in stock
Traxxas
Autographics
Also red blue black
Proline
MIP
Losi
A1005 Fr Axles
A1115 XXt Fr Arms
A3070 Diff Rings
A3073 Outdrive Cup
A3074 Diff Gear
- mytimac
- Business Member
If you had gone to VONATS you saw we had a bunch of used tires and rims. They mostly came from my personal collection that the wife was encouraging me to do something with now.
We sold some there, but we had a lot left over. Most are Losi items. So they are now on the store along with a few Associated rims and XXX sets.
See them all here in the new products section. https://sabulatech.com/storefront/index.php?controller=new-products
Then we had some new parts in for the Losi guys.
Lunsford
3054 Losi XXX Titanium Hinge Pin Kit
Losi
A1116 XXXT Front Arms
A2208 3 Deg Rear Toe Conversion XX4
A8114 XXX4 Wing
A8040 XX Buggy Body
A9712 VLA XXXT / AD2 Front Arms
Lunsford
Losi
A8114 XXX4 Wing
A8040 XX Buggy Body
- mytimac
- Business Member
Some parts just in.
Associated
6189 Worlds wing Mount
6190 Wing Mount
6451 RC10 Accessories
Losi
A6350 Washer Assortment
A6004 Ball Studs with Ends
A6401 Pins for Wheels only
A9702 XXX-T, NT front arms
A5062 1.2 Shock Shafts Nitride
A5079 Shock Ends with Cups
A2943 XXX/T Gen 2 Gear Cover
A7055 XXXT NT front Wheels
Associated
6190 Wing Mount
Losi
- mytimac
- Business Member
We had to get some Fluorescent Yellow XX Bulkheads made so we decided to make some Associated RC10 parts the same color.
We have 6191 RC10 Wing Mounts, 6189 RC10 Wing Mounts, and 6451 RC10 Shock Accessories now in Fluorescent Yellow.
We have them on the store and eBay. There is limited quantity and they look to be selling fairly quickly.
6189 RC10 Wing Mounts https://sabulatech.com/storefront/index.php?id_product=4893&controller=product
6191 RC10 Wing Mounts https://sabulatech.com/storefront/index.php?id_product=4894&controller=product
6451 RC10 Shock Accessories https://sabulatech.com/storefront/index.php?id_product=4895&controller=product
Also one set of 6800 6850 rims in black.
https://sabulatech.com/storefront/index.php?id_product=4603&controller=product
- mytimac
- Business Member
Team Losi Items in. We had a customer come into the hobby shop and do a trade in with some old LXT stuff.
Original Retail Package:
A2001 Rear Bulkhead
A3005 Transmission Molded Gear Set
A4001 Front Battery Cup
A4045 Front Bumper
A4047 Molded Chassis Brace
A5008 Upper Shock Mount Bushing (old style)
New from kit:
GREASE Losi grease containers from kit (losi logo on one)
TOOLS Losi Wrench and Allen Wrenches
SCREWS LXT JRXPRO All Phillips Chassis Screws from Kit
A1018 Adjustable Link Set NO Ends
A1018 Adjustable Link Set W/Ends Grey
A2016 Rear Pivot Support from Kit
A2022 H-Arm Hub Clips (4 clips)
A2038 Extra Rigid Rear Hubs (H-Arm)
A3009 Differential Balls 3-32
A4051 Early Version Molded Chassis JRXPRO SE & LXT
A5005 A5005 Shock Shaft .9"
A5022 Shock Shaft 1.2"
A5023 Shock Spring Clamps Cups (Grey)
A5030 .9” Shock Body (black)
A5031 1.2" Shock Body (black)
A5047 Teflon Shock Pistons 55 (Orange)
A5152 2.5" Spring 2.6 rate
A6000 Rod End w/Balls (grey)
Used Parts
7370 RPM LXT Fr Arms USED
A1003 Bulkhead USED
A1017 USED
A1018 USED
A1507 A1512 A4002 A6200 USED
A2001 A2024 USED
A3076 USED
A3908 USED
A4001 USED
A4045 USED
A4047 USED
A4051 Late Version Molded Chassis Used
A4053 USED
A4055 Used
A5030 A5031 and Shock Springs USED
A2001 Rear Bulkhead
A4045 Front Bumper
New from kit:
Used Parts
A1003 Bulkhead USED
A1017 USED
A1018 USED
A2001 A2024 USED
A3076 USED
A3908 USED
A4001 USED
A4045 USED
A4047 USED
A4053 USED
A4055 Used
- mytimac
- Business Member
Losi Items
New
A4206 XXXS Chassis, new from kit
Used
LXTMANUAL LXT Manual in very good condition
A4100 XX Used Standard Chassis
STUSPURS1 3 used double disk slipper spurs
STUSPURS2 3 used double disk slipper spurs
A1110 Fr Arms XX Used
A1110 Fr Arms XX Used (second set)
RCRACER Team Losi RC Racer Game for Playstation
XX4MANUAL XX4 manual and Addendum plus more
XX4ADD XX4 Addendum Only
XXXTMANUAL XXXT Sport II Manual
New
Used
- 1982 Views
Last post by mytimac
- 1095 Views
Last post by amx73
- 1474 Views
Last post by MONSTER
- 55 Replies
- 6431 Views
- 731 Views
Last post by RCveteran
- 308 Views
Last post by Tang
- 1799 Views
- 26 Replies
- 4335 Views
Last post by Jared J
