RPM CE runner
jbmeyer13
Has thanked: 25 times
Been thanked: 11 times
Re: RPM CE runner
Post by jbmeyer13 »
askbob wrote:Picked up the hard to find front white RPM team arms. :shock: Added the lower shock retainers, RPM front steering arms, delrin rear shock pivots, and new old stock front arm mounts.
Those are the from the World's Front End Kit that were designed to be used with the RC10T front nose piece. Looks like you are using the stock RC10 nose plate- what's the total width in this configuration?
Been thanked: 498 times
Re: RPM CE runner
those are the team arms, essentially the same length as the stock 'wide' arms or andy's arms. hella hard to find NIP and white, that's for sure.
jbmeyer13
Re: RPM CE runner
Post by jbmeyer13 »
jwscab wrote:those are the team arms, essentially the same length as the stock 'wide' arms or andy's arms. hella hard to find NIP and white, that's for sure.
Hmmm...they look identical to my World's Arms. My World's arms are definitely longer than the stock "wide" arms. I examined last night when I was cannibalizing my RCPS titanium hardware for another project. I think when I measured the RPM World's arms they were 67-68mm and the "team arms are approx. 58mm.
Re: RPM CE runner
the worlds arms should have two shock mount holes, and also have a wider inner arm mount due to the truck bulkhead:
http://www.rc10talk.com/viewtopic.php?f=35&t=30765&hilit=rpm+worlds+arms&start=15
but yes, I can relate to the confusion, it took a while to get it all straight for me.
jbmeyer13
Re: RPM CE runner
Post by jbmeyer13 »
jwscab wrote:the worlds arms should have two shock mount holes, and also have a wider inner arm mount due to the truck bulkhead:
Good eye- didn't catch the shock mount holes. Thx!
askbob
Re: RPM CE runner
Post by askbob »
Same with the rear RPM arms as well. Quick way to tell they are Worlds length is if they only 2 lower shock mount holes.
askbob
Re: RPM CE runner
Post by askbob »
Will update pics.
klavy69
Moderator
Has thanked: 628 times
Been thanked: 294 times
Re: RPM CE runner
Post by klavy69 »
askbob wrote: Sun Feb 18, 2018 9:27 pm Will update pics.
thank you...this was one of my inspirations 8)
Users browsing this forum: No User AvatarAmazon [Bot] and 10 guests
