Dave145's gold pan build.
Dave145
Re: 6 gear with brushless
Post by Dave145 »
I'm missing part number 6627. Ive seen that number includes both thrust washers and the plastic diff washer as well.
PTModIT
Post by PTModIT »
I didn't read that right. I found this place.Never dealt with them.http://sabulatech.com/storefront/product.php?id_product=1017
RC104ever
Post by RC104ever »
I have dealt with them. Great place, he's also a member here.
- Chris
Lots of cars...so many cars
Been thanked: 3919 times
Wow..bookmarked! Good stuff there!
GoldRush
Post by GoldRush »
gomachv wrote:Wow..bookmarked! Good stuff there!
me too...that site is awesome...saved to favorites
do you think its a bad twilight zone episode for team associated to be re producing a buggy from yesteryear that is capable of beating their latest and greatest production buggy?
Dave145
Post by Dave145 »
just checked out that link to the thrust washer set. Why is it so expensive? I'm assuming because those parts are the most easily lost? :? Is there absolutely no washer out there that will work from a hardware store like Menards or True Value? That just seems a little expensive for three small parts... :|
GoldRush
Post by GoldRush »
most hardware that is used on rc cars is usually sourced from industry available stuff so i imagine that if you had the specs of the hardware in question it would be something you could get from mcmaster-carr....unless the parts in question were special ran for associated
Dave145
Re: Finally... Dave145's Gold Pan Runner Build
Post by Dave145 »
After lots more time and parts, here is what the car currently looks like. The battery cup on the back is for the esc because it was too tall to fit under the body with it's fan. The shocks are just tacked in place, they don't have any oil in them yet.
PTModIT
Post by PTModIT »
specialty tempered steel. Those carbide balls would wear normal washer big time which are a softer steel.(ie. Home Depot)
Dave145
Post by Dave145 »
I put in some standard washer that was similar in size and it literally disappeared. Wouldn't a chrome washer be stronger though?
CUDDZILLA
Post by CUDDZILLA »
From my personal experience:
I put a Novak GTB 4.5 turn(yeah BIG power) on an RC10 Gold Pan with 6 gear trans.
The trans had stock 32p internal gears with a Losi ball bearing diff tube. I never had a failure in MANY LiPO batteries run through it.
Running her on the street with rubber tires first then was forced to switch to foams due to blowouts.
I recently added Thorp 48p internal gears and she's quieter, smoother, STILL no mechanical failures in the trans!
My current dirt oval racer is a RC10 Gold Pan(6 gear trans) Street Stock running a sensored Novak Ballistic 13.5.
I don't think you'll have to worry about the strength of the 6 gear trans. Keep her clean a lubed she should be fine!
thrust washers and diff rings and diff balls(if not special materials, such as a carbide or ceramic) are hardened steel alloys, which are much more wear resistant than regular old mild steel. This is why they cost so much. You could in theory get them very cheap if you were to custom order like 1000 of them. But you would have to sell them to offset the cost. economy of scale.
and yes, they are making a nice profit on those parts but it's a niche product and thus commands the premium.
RC104ever
Post by RC104ever »
One option (if you can find them) is the steel idler gears that were out a long time ago. I have a set (somewhere) but haven't had a chance to try them yet.
- Chris
Dave145
Dave145's gold pan build thread
Post by Dave145 »
I actually have a set if those steel idlers in my 6 gear and they do hold up better then the plastic ones. Mine are getting king of worn down though but they do seem to work well enough with bearings in them. I also tun them dry with no oil or anything on them and that seems to work well also. I was more worried about the diff though with the brushless system. Will it survive or will it melt or wear away?
CUDDZILLA
Re: Dave145's gold pan build.
Post by CUDDZILLA »
The diff should be fine. As long as you clean/lube regularly. On my race machine(13.5 Novak Ballistic Brushless) I clean/lube before race day, race all day(2 heats/main)...no issues AT ALL so far.
That's Street Stock class on a big high-bite dirt oval
Users browsing this forum: No User AvatarGoogle [Bot] and 2 guests
