Goatless wrote:Motor that's installed in on of the Top Cat's
- ROH73
- Been thanked: 23 times
Revtech Contest Gold, 19 triple. Great off-road motor from the late 80s...tons of torque.
- klavy69
- Moderator
- Has thanked: 640 times
- Been thanked: 294 times
pan car chassis. Wrote down manufacturer and model but no idea where its at
or this one:
Thanx for any upcoming info
or this one:
- nvxwax
Ok anybody know who made these or are they home made (The Wheels)
- drbelleville
- Been thanked: 4 times
My Turn,
Can anyone tell me about these pan car fronts - I thought they were TRC ZR-1 Wheels that had been drilled, but that is not the case.
The Trinity Spur Gear as well? When where these offered? I had seen the magic series but not these.
The left Pan car hub, I have never seen this one.
Thanks
-Maurice
Thanks
-Maurice
- reign79
- Has thanked: 3 times
Lazerlite shadow,bolink bandito chassis and radio tray, 1/10 Parma panther front cross armpan car chassis. Wrote down manufacturer and model but no idea where its at
Ryan
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Front wheels: TRC? (came with EV-10, I think). Spur: Zero Gravity, about 1996-97ish. Pan car hub: early Trinity or Associateddrbelleville wrote:My Turn,
Thanks
-Maurice
- Has thanked: 7 times
- Been thanked: 42 times
I've got a hub like that on my Delta 10th scale. It's got one 5-40 set screw right?
- drbelleville
I am sure the wheels are not TRC / Trinity - those cars are my specialty. I thought the same before I got them. I will have to spec them out just to give some dimensional information. Hub is stepped and the Trinity and Associated cars have a "cupped/dished" hub. Thanks for the Spur info.EvolutionRevolution wrote:Front wheels: TRC? (came with EV-10, I think). Spur: Zero Gravity, about 1996-97ish. Pan car hub: early Trinity or Associateddrbelleville wrote:My Turn,
Thanks
-Maurice
- drbelleville
Yeah it does, I will send you a PM about measurements to compare.adam lancia wrote:I've got a hub like that on my Delta 10th scale. It's got one 5-40 set screw right?
Thanks
-Maurice
I've been clearing out a box of pan car parts and found a few bits that i haven't a clue what they're from. Can anyone help me ID them?
First up is a radio plate i think.
Next is a rear pod. It's a bit narrower than a 12L pod.
Front axle from?? I've seen this somewhere but i can't think where.
Not sure about these. Probably from a 10th scale rather than 12 as they're big and chunky.
Lastly this gear diffed rear axle. Gear diff part mounts inside the wheel hub. Any ideas?
Thanks.
Thanks.
- klavy69
- Moderator
mostly traxxas fiero stuff. axle, rear carriers and plate, front axles are for sure along with that radio plate. The radio plate is only a partial. its been cut off from the rest of the top plate of the chassis. The beam front end I have seen before but can't place it either...
- 59 Replies
- 16213 Views
Last post by Diamond Dave
- 106 Replies
- 27303 Views
Last post by mikesofunny
- 431 Replies
- 55218 Views
Last post by Eccentric
- 67 Replies
- 16978 Views
Last post by bearrickster
- 321 Replies
- 42263 Views
Last post by tazz888
- 448 Replies
- 50533 Views
Last post by MelvinsArmy
- 351 Replies
- 47787 Views
Last post by Frankentruck
- 4227 Views
Last post by mrlexan
