- Been thanked: 4 times
Id say their SEEs wheels for a 4x4 buggy by offset of the wheels.Wonder if theyd fit my RS4MT lol thats new an undriven.DON
- Bob-Stormer
I don't recognize these, not entirely. Be precise with an answer if you know.
If they are Delta, off of what? ain't the 1/12th shocks, they're to big. Not sure. was a part number on the bag (no header on it), barely visible, was a 4 digit number, might have been 5452, maybe. main shock body is 1.48" long. spring is .475 in outer diameter, about 1.2" long.
I enjoy, Schumacher 1/12th, Checkpoint motors, Lazerlite motors, PB Sizzler, Pro Panther-10, Dialed Speed Controls, Paranoia spurs.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
My guess is Custom Works (Dominator and Intimidator era)Bob-Stormer wrote:I don't recognize these, not entirely. Be precise with an answer if you know.
Come and visit the stable
- Been thanked: 325 times
I picked up a pair of Sees wheels almost identical to those, they're for a Losi (JRX-2, in my case). Same inner captured-pin mounting system, same general appearance. Yours appear to be a bit wider, though.THUNDERSTRIKE1 wrote:Id say their SEEs wheels for a 4x4 buggy by offset of the wheels.Wonder if theyd fit my RS4MT lol thats new an undriven.DON
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 472 times
Different slightly than the CW large volume Delta, Looks like Trinity Reflex shocks-Bob-Stormer wrote:I don't recognize these, not entirely. Be precise with an answer if you know.
Sorry, don't know what it is, but I recently picked up a Lynx 2 with that exact shock on it.Bob-Stormer wrote:I don't recognize these, not entirely. Be precise with an answer if you know.
- Incredible_Serious
- Has thanked: 1742 times
- Been thanked: 1145 times
So they may be Sees, or at least a copy of Sees rims..... then I'm guessing they're two pairs of rears? Just want to be as accurate as I can with the listing...Coelacanth wrote:I picked up a pair of Sees wheels almost identical to those, they're for a Losi (JRX-2, in my case). Same inner captured-pin mounting system, same general appearance. Yours appear to be a bit wider, though.THUNDERSTRIKE1 wrote:Id say their SEEs wheels for a 4x4 buggy by offset of the wheels.Wonder if theyd fit my RS4MT lol thats new an undriven.DON
Thanks guys...
- Been thanked: 100 times
I also think Lynx II shocks. My Lynx shock also had the same plastic holder like in the picture but I replaced this shock with the larger optional Trinity shock. But it´s possible the Lynx shock are OEM Delta.
Alex, in a few days, I'll be able to take some measurements and we can compare diameter & width. The pair I have are I believe 2.2" diameter and just under 1.5" wide.Incredible_Serious wrote:So they may be Sees, or at least a copy of Sees rims..... then I'm guessing they're two pairs of rears? Just want to be as accurate as I can with the listing...Coelacanth wrote:I picked up a pair of Sees wheels almost identical to those, they're for a Losi (JRX-2, in my case). Same inner captured-pin mounting system, same general appearance. Yours appear to be a bit wider, though.THUNDERSTRIKE1 wrote:Id say their SEEs wheels for a 4x4 buggy by offset of the wheels.Wonder if theyd fit my RS4MT lol thats new an undriven.DON
Thanks guys...
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
AlexIncredible_Serious wrote: So they may be Sees, or at least a copy of Sees rims..... then I'm guessing they're two pairs of rears? Just want to be as accurate as I can with the listing...
Definitely SEES wheels. like stated above I picked a set up off Brandon on here for a Losi JRX2 or whatever they are for. As for both being rears quite possible. Do you have the offsets specs by chance?
- Bob-Stormer
It could be possible that it's lynx 2. But Composite Craft went to basically 6 digit part numbers about that time. Based on the way the plastic is molded on, and the relatively sketchy way that its done, with no regard to the flashing, I'm thinking some kind of Delta, but I have no knowledge of 1/8 delta. they are bigger than the little deltas that are on the 1/12th car. and bigger than say the center shock on a TRC pro-10. Which I think were some of the original Custom works shocks. Maybe...
shane wrote:Sorry, don't know what it is, but I recently picked up a Lynx 2 with that exact shock on it.Bob-Stormer wrote:I don't recognize these, not entirely. Be precise with an answer if you know.
- Brandon G
Definetely See's JRX2 rear wheels. They use the 2.0" diameter rear buggy tires. The JRX2 wheels are the only ones with the straight 3/16" hole, pin drive, and that much offset.Incredible_Serious wrote:Looking for an ID on these alloy wheels. 5-spoke directional pattern, similar to Kyosho Optima plastic rims. 2" diameter, captive pin drive, and all four are rear wheel size.
Looking to know who made them (commercial manufacture or back-yard), and what they suit (ie is it two pairs of rears, or are they designed to fit front and rear of a 4wd).
Would like to know, to advertise them properly....
- Bimdapogs
How do you mount these on a 1/8 car?
This one is made by Mantua, but no mention of a specific model..
For a Traxxas Cat?
For a Traxxas Cat?
20886 are for Mangusta, Manta, Demon, Muscel Devil and Safari.Bimdapogs wrote: This one is made by Mantua, but no mention of a specific model..
It may fit others to but these I found in the 1987 catalog.
- prp
- Been thanked: 13 times
The 1/8 wheels are for the Mantua Mangusta (normally yellow), or the SG Indy 90 VCS, Space Europa :
http://www.rcmag.eu/Articles_Vintage/tractoricou/la_sg_vcs_indy_90_de_manu/photo/vcs90manu08101.jpg
- 59 Replies
- 16193 Views
Last post by Diamond Dave
- 106 Replies
- 27269 Views
Last post by mikesofunny
- 431 Replies
- 55154 Views
Last post by Eccentric
- 67 Replies
- 16956 Views
Last post by bearrickster
- 321 Replies
- 42228 Views
Last post by tazz888
- 448 Replies
- 50504 Views
Last post by MelvinsArmy
- 351 Replies
- 47762 Views
Last post by Frankentruck
- 4222 Views
Last post by mrlexan
