So, what did you do RC today?
- Frankentruck
- Has thanked: 2623 times
- Been thanked: 2990 times
Huh, I didn't even know they changed pan cars to be like that.
- Has thanked: 271 times
- Been thanked: 260 times
Like GoMachV said, that is the new setup.Frankentruck wrote: ↑Thu May 02, 2024 6:21 pm Is that motor plate missing a top section?
- silvertriple
- Has thanked: 753 times
- Been thanked: 1348 times
On the road to 13th... I started to work on the bodyset of my 12th Marui model...
Started to organize my hobby room to make more room. Getting rid of the treadmill as that should offer space for another 20 or so kits!
I didn't come into this world on some probation, I must have then come out of it!
- silvertriple
Today, beside painting few Super Wheelie bodies, I admired my son at work... Each time his paintjobs are getting nicer and sharper. I'm a very proud dad
- Has thanked: 2776 times
- Been thanked: 2253 times
Today I was mostly 3d printing polycarbonate Meteor gears .
- Frankentruck
Printed a new replacement nylon light bar for the Super Clod roll bar and also some gear covers. The gear covers still need come cleanup.
- morrisey0
- Has thanked: 95 times
- Been thanked: 1886 times
Started experimenting with chrome nail powder as a possibility for chrome plating plastic. Of course, the YT videos always create better results, but I feel like I may be able to make something work. I do know now that I need a black base, so I have black spoons on order so I don't have to keep painting white ones.
- R6cowboy
- Has thanked: 897 times
- Been thanked: 913 times
Finished a RC10 T4.1 FT, except for body as usual. This one was in pretty rough shape and rusty when I bought it. It wasn't complete and the bottom of the chassis, rear plate and motor guard were scratched to kingdom come. I sanded a lot of the scratches out and decided to paint the chassis, front top plate, rear chassis plate and motor guard semi-gloss black. Left some of the scratches to show some of its history in other words.
Fitted it with all new hardware, turnbuckles, RPM bumper, red aluminum front hinge pin brace, wheels, Pro-line Blade front & JConcepts Pin Downs rear tires, 84T spur and 21T pinion. Electronics consist of Savox servo, Futaba R603GF 2.4Ghz receiver, LRP SXX Stock Spec V2 ESC and Novak SS 21.5 brushless motor.
And have an original NIP JConcepts Hi Flow body to go on.
-Jerry-
- Frankentruck
My son figured out that the tall soft wall crawler tires that are (were
) great for taller grass don't hold up to 10T brushless rolling burnouts.
- R6cowboy
Duct tape the inside of the drive tires (new pair of course) and try again.Frankentruck wrote: ↑Wed May 08, 2024 10:19 pm My son figured out that the tall soft wall crawler tires that are (were) great for taller grass don't hold up to 10T brushless rolling burnouts.
-Jerry-
- juicedcoupe
- Has thanked: 274 times
- Been thanked: 2114 times
If he wants taller tires, why not try some from a Sledgehammer, Monster Beetle, or Blackfoot?Frankentruck wrote: ↑Wed May 08, 2024 10:19 pm My son figured out that the tall soft wall crawler tires that are (were) great for taller grass don't hold up to 10T brushless rolling burnouts.
While not soft, the Sledgehammer and MB tires are tough and aggressive.
- Frankentruck
These were cheap tires I got a couple of years ago when I was looking for 2.2" tire options. He is going back to the Proline Trenchers.
The tire rupture was so violent it ripped the suspension arm from the hinge pin. When it first started to let go you could hear the tire tearing apart. It sounded like a car driving on a rumble strip.
Printed a couple of tool organizers and painted the B7D body. I know it's supposed to be red but I don't like red cars so it's blue.
- Has thanked: 1156 times
- Been thanked: 624 times
I did a cosmetic cleanup on this oddball Trinity #2020 Reverse Rotation Monster Horsepower motor. Removed the caps and cleaned off excess solder & flux while trying to preserve the original label. It also had a pressed on brass gear that I had to cut off with the Dremel.
Before -
After -
Before -
After -
-Brad
- 6125 Views
Last post by Dr. Robotnik
- 20 Replies
- 11096 Views
Last post by cas22
- 7114 Views
Last post by Synergy
- 7298 Views
Last post by ireg
- 5916 Views
Last post by clm
- 2787 Views
Last post by mrlexan
- 2620 Views
Last post by DHood
- 2833 Views
Last post by Winger
Users browsing this forum: hugger19 and 22 guests
