RC10 DS Classic - Build
Everything pertaining to the RC10DS re-release.
morrisey0
Has thanked: 87 times
Been thanked: 1852 times
Re: RC10 DS Classic - Build
Post by morrisey0 »
GreenBar0n wrote: Wed Aug 07, 2024 8:42 pm Ran into a problem, was missing (2) ball studs from Bag A, tore the place apart looking for them.
Hope that saves someone else some wasted time and grief.
Wish I had read this first, and this one line will convince me to read your whole build before continuing. I was also missing the two ball studs in Bag A, but just grabbed a couple out of the parts bin. Would have saved some time and trouble if I had known this tid bit before diving into it. :)
Also in Bag A, I didn't not have any 1.11" king pins as called for in Step 3. I had four .951" pins, which is fine and they work as intended. Just a random fact.
GreenBar0n
Has thanked: 1271 times
Been thanked: 860 times
Post by GreenBar0n »
morrisey0 wrote: Mon Aug 12, 2024 9:32 pm
That manual made a fool of me more than a couple of times :lol:.
GreenBar0n
This was the least expensive and most modern components I could find for the DS. A $32 Reedy servo, and Xerun $112 ESC/Motor combo. Kind of wanted to step up a bit from the 1060/silver can experience on this one.
2S only.
Comes with the sensor cable and ESC fan.
Need to figure out the right pinion to use, nothing in the manual regarding that, or the diameter of the tires.
Been using this chart to determine pinion/spur size. Is there anything more accurate or better?
DS Classic kit comes with 81T 48P spur.
Dangeruss
Has thanked: 425 times
Been thanked: 1410 times
Post by Dangeruss »
GreenBar0n wrote: Mon Aug 12, 2024 9:25 pm As I get closer to running this DS, I'm not really comfortable gluing and peeling out on these tires that are irreplaceable, that's one of the very things that makes me not run some of my vintage RC's. I'm starting to think about foam instead, won't look as good, but I don't want to ruin the DS wheels and tires, too awesome.
Could get a set of plastic 12mm wheel hex's and some Tamiya TAM50548 or other tasty plastic wheels:
Fronts... super glue the wheel hex into the wheel, once dry drill the axle hole out to 3/8's then put a pair of 3/16x3/8 flanged bearings in and bolt the wheels up.
Rears... hex's slide right onto the axles, everything bolts up like normal.
Dustydrone
Has thanked: 530 times
Been thanked: 110 times
Post by Dustydrone »
GreenBar0n wrote: Mon Aug 12, 2024 9:15 pm
Dustydrone wrote: Mon Aug 12, 2024 8:50 pm They filmed parts of the in movie in Ojai, the town I grew up in. I was only 6 when they were filming but I remember it being a pretty big deal😎
Here are a couple of shots coming out of the old Rolands Shell station and the bottom on is passing the long since gone O-Hi Frosty👍
Very cool!
What model DJI drone is that in your avatar?
It's a Mavic 3 with a Decal Girl Old Glory wrap. The shot was taken by another drone while I was chasing Ultra4 cars out at King of the Hammers.
GreenBar0n
Dangeruss wrote: Mon Aug 12, 2024 10:44 pm Could get a set of plastic 12mm wheel hex's and some Tamiya TAM50548 or other tasty plastic wheels:
Thanks! Wish AE would just sell DS wheels and tires. I keep looking at the parts for the DS, and there is nothing.
https://www.associatedelectrics.com/teamassociated/cars_and_trucks/RC10DS/Classic_Kit/parts_accessories/
GreenBar0n
Dustydrone wrote: Mon Aug 12, 2024 11:09 pm It's a Mavic 3 with a Decal Girl Old Glory wrap. The shot was taken by another drone while I was chasing Ultra4 cars out at King of the Hammers.
Very nice! I have the Air3, hoping to get some drone RC videos here soon.
Dustydrone
GreenBar0n wrote: Mon Aug 12, 2024 11:30 pm
I look forward to seeing what you come up with! We will have to start drone/rc car thread. I have some cool stuff shot with my Avata 2 and my FPV Crawler.
GreenBar0n
Dustydrone wrote: Mon Aug 12, 2024 11:35 pm
RC Off Topic sounds like the perfect spot to make a Drone thread. Let's see those videos!
Really curious about the Active Track feature for the Air3, wonder if it can follow such a small object such as a 1/10 RC, and keep it in frame.
GreenBar0n
If you intend to use a brushed motor, it will fit the DS without issue. If you intend to use a brushless motor, you may need to mod the motor mount.
Brushelss on the left, brushed on the right.
I had to file the motor mount a bit to get the 3650 brushless motor to fit, the silver dot over the top screw hole had to be filed. Would not have gone in correctly.
DS kit did not include the motor mounting screws, which are metric M3, or 3mm x 6mm. Went with 23T pinion with the 81T spur.
$32 Reedy servo does not comes with horns, or screw. Had these laying around luckily.
Chassis entirely completed.
Will finish spraying the bodies tomorrow.
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
You are actually from there? I laughed when I first saw "Ojai" in your info. :lol: I thought it was quite the clever reference to the 6 Million Dollar Man tv show. :lol:
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
GreenBar0n wrote: Tue Aug 13, 2024 5:05 am If you intend to use a brushed motor, it will fit the DS without issue. If you intend to use a brushless motor, you may need to mod the motor mount.
You gonna run (a) washer(s) on the motor screws?
RogueIV
Has thanked: 2135 times
Been thanked: 1100 times
Post by RogueIV »
Thought occurred to me. Since the mesh part of the wheel is a separate disk that's non-structural we can easily change up these disks with custom 3d printed ones to get different looks.
Has thanked: 2604 times
Been thanked: 2977 times
RogueIV wrote: Tue Aug 13, 2024 12:47 pm Thought occurred to me. Since the mesh part of the wheel is a separate disk that's non-structural we can easily change up these disks with custom 3d printed ones to get different looks.
RogueIV
Post by RogueIV »
Frankentruck wrote: Tue Aug 13, 2024 12:55 pm
I fear for the corner marshals
Return to “Associated On-Road Re-Release Forum”
