So, what did you do RC today?
R6cowboy
Has thanked: 818 times
Been thanked: 849 times
Post by R6cowboy »
juicedcoupe wrote: Tue Feb 07, 2023 10:36 pm
R6cowboy wrote: Tue Feb 07, 2023 10:28 pm The black wheels on the runner truck are reproductions of the originals our resident Frankentruck 3D printed for me. Which fit perfectly, might I add.
Did you have to trim the back of the fronts?
The fronts that he made me hit the hinge pins before full lock. I'm thinking of getting a router attachment for my Dremel and using a 1/8" end mill bit.
No sir, mine does clear at full lock. Makes me wonder if there's something slightly different between our trucks. Mine is 100% stone stock to a T, at the moment.
-Jerry-
Has thanked: 264 times
Been thanked: 2010 times
Frankentruck wrote: Tue Feb 07, 2023 10:43 pm
juicedcoupe wrote: Tue Feb 07, 2023 10:36 pm Did you have to trim the back of the fronts?
Got a picture? It's the same model used for both your sets. I wonder if I missed adding a chamfer from the originals.
Beside a Stadium Blitzer wheel.
Point of contact.
R6cowboy wrote: Tue Feb 07, 2023 11:05 pm No sir, mine does clear at full lock. Makes me wonder if there's something slightly different between our trucks. Mine is 100% stone stock to a T, at the moment.
My steering is slightly different. I used the Tamiya high torque servo saver and the steering blocks are inverted. So its possible that I have a little more steering travel.
I did however notice that these would fit my Hornet, as it doesn't have hinge pins at all.
Has thanked: 2477 times
Been thanked: 2782 times
Thanks for the pictures. I'll make you a set with clearance. The OEM wheel was the same in that area so there definitely is a difference in your steering setup.
R6cowboy
Post by R6cowboy »
There's one operational unit.
-Jerry-
morrisey0
Has thanked: 74 times
Been thanked: 1739 times
Post by morrisey0 »
Waiting on some parts for a couple of builds, but some much needed 5-40 hardware came in for my Viper EX-10, so I got to work on getting everything cleaned up in prep of building. Supposed to rain all day Sunday, so that should be the day. :D
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
Made a couple rc videos. Ordered some add-ons for my turtle labs workstation. Ordered YET another Durango I didn't need (but it's one i didn't have). Sorted some of my bulk hardware to make it easier to find and keep track of.
Dadio
Has thanked: 2697 times
Been thanked: 2234 times
Post by Dadio »
morrisey0 wrote: Fri Feb 10, 2023 8:31 pm Waiting on some parts for a couple of builds, but some much needed 5-40 hardware came in for my Viper EX-10, so I got to work on getting everything cleaned up in prep of building. Supposed to rain all day Sunday, so that should be the day. :D
Looks beautiful :D
Rainy day screwing off.
Swapped some wheels and tires around on the hopper.
Frankentruck printed FXT wheels with Blitzer rear tires and LRP fronts.
I've got a couple sets of white Stadium Blitzer wheels as well, might see how they look.
morrisey0
Post by morrisey0 »
Great rainy Sunday of avoiding all adult responsibilities! :D
The Pro-2 is complete. Fill the shocks and she will be out bashing this week.
Then got a good chunk of the Viper done. The pmg rear wheels don't fit onto the hub of my truer like every other rear pan car wheel ever made (the four mounting holes are also not drilled correctly), so I have to jerry-rig something there, which is why the tires didn't get done today. Chassis is done though, and even started cleaning up and placing some electronics.
mikea96
Has thanked: 604 times
Been thanked: 858 times
Post by mikea96 »
I cutout a new body and wing for the yokomo today.
Tang
Has thanked: 47 times
Been thanked: 73 times
Post by Tang »
Just buying stuff :lol:
My World's rere will be here today, and I can finally start my build. This is what I have so far.
Dadio
Post by Dadio »
Today I CAD modelled and started printing what I hope will be some rather special wheels for an upcoming project , could end up looking crap though :lol:
morrisey0
Post by morrisey0 »
I got a little work done on what I am calling "oval car." Outside of it turning mostly left on a relatively flat track, that is it's only ultimate plan so far. I am trying to mostly work with spare RC10 parts, DR10 kit parts, and a few store bought Traxxas parts. I am kinda shocked the front worked out as well as it did, although there is nothing revolutionary there. The rear is an open book at this point.
1911Colt
Has thanked: 1670 times
Been thanked: 797 times
Post by 1911Colt »
I came in to the office early and rebuilt my Bosscat's front shocks at my desk. :lol:
I had been told that a modern big bore shock rod would fit the Schumacher "Vari-shock", and they do, but it is just a touch larger in diameter. The difference is miniscule and they did seem to work fine. I didn't like the gold color, so when I found the proper rods, I swapped them over. The pistons (I have Muzzoom, not the vari-shock ones) fit the modern rod noticeably tighter than they do the correct rod, again pointing to a tiny difference in diameter. I am guessing that the difference is down to the old one being machined to a fraction of an inch and the new one being mm. The difference is probably in the 0.01 inch range. Also, the groove spacing is correct so the e-clips above and below the piston fit perfectly well.
Anyway, the good news is that they do work in a pinch if you can't find the proper vintage rod, so there is an option. I happen to need a set of 4 long rods for a Storm 2000, and, had I not found the proper ones, would have used the Schumacher big bore rods.
More useless information: be careful which Schuey rod you order. At some point they switched from using e-clips to fit the pistons and used a washer and screw arrangement. My KF2 has the old style. The L1s, LDs, and Storm STs use the screw down style; not sure about KC, KD. Either will work, but I prefer the older style because it is a direct swap vs having to source screws and washers.
