Edinger? Time for some love
winner_evo
Has thanked: 43 times
Been thanked: 74 times
Re: Edinger? Time for some love
Post by winner_evo »
Nice paint scheme, metallic blue goes well with the gold anodising. Top job!
mtbkym01
Has thanked: 190 times
Been thanked: 276 times
Post by mtbkym01 »
Thanks for the comments, I didn’t really have much of a vision on the paint, just grabbed some colours that I already had, and some masking tape. I couldn’t be happier with the result.
Got the driver, spotties and window nets done
If it's Old Skool, It's Kool
mtbkym01
Post by mtbkym01 »
Old Futaba Servo And RX installed, I found a round servo horn, and materials to make the steering linkage as per the manual
mtbkym01
Post by mtbkym01 »
bluewormx wrote: Fri Apr 19, 2019 8:38 am
mtbkym01 wrote: Fri Apr 19, 2019 8:19 am I’m gonna throw this out there, does anyone have the ball ends from a front stabiliser bar, and the connecting ball cups that they don’t require. I have the original stabiliser and the balls for the front arms, but am missing the rest, cheers Kym
There are plenty on ebay search for dubro 180, these are the original part. Now discontinued by dubro but are plentiful on ebay.
Thanks for this, just ordered 4 from a local seller on eBay (needed 4 for the ball cups)
mtbkym01
Post by mtbkym01 »
Just won a job lot of old RX's, ESC's and Servo's.
The oldest ESC (of the 3) will be a Futaba MC110 (1987), Think that is what will be placed in the Edinger.
I fitted the old AE 05 closed blue end bell motor yesterday, as my others are green label and too "new" I feel.
There's also some Servo's coming, so will see whats there and maybe replace the Futaba thats in this now if one turns out to be more period correct
mtbkym01
Post by mtbkym01 »
Picked up some the dubro ball ends today, not 100% happy with them, they are a bit bigger and more heavy duty than what would’ve been available back in the day. In this pic, you can see an “original” that was actually on the car so I’m assuming it’s era correct. I’ve has to shorten the new ones as well
Here they are all fitted up across the entire steering system
I guess at the end of the day, as this is a true survivor rebuild, overall I’m really happy with the car overall, once the front stabiliser parts and esc turn up, I’ll be able to call this done
Been thanked: 3919 times
The one you have in the pic on the left side is a Kyosho ball end from an optima/ultima
mtbkym01
Post by mtbkym01 »
GoMachV wrote: Sat Apr 27, 2019 12:15 am The one you have in the pic on the left side is a Kyosho ball end from an optima/ultima
Oh ok, that was on this one on one of the rear links, but it also had Tamiya ones on it, seems the original owner used whatever back in the day as the originals broke.
The Dubros seem ok on there for now atleast
Thanks for the info
mtbkym01
Post by mtbkym01 »
My Dubro parts for the front stabiliser turned up, now I need some (more) advice, what size set/grub screws do I need for the links, I’ve used some black ones (same as front suspension pin “locks”) but being black they are too visible I’d believe, so I’m guessing they used longer silver ones originally?
If you can find some regular #4 screws about half inch long, you could cut the heads off and use them. Or just wire wheeling the setscrews to remove the oxide coating
bluewormx
Has thanked: 41 times
Been thanked: 91 times
Post by bluewormx »
mtbkym01 wrote: Mon Apr 29, 2019 3:23 am My Dubro parts for the front stabiliser turned up, now I need some (more) advice, what size set/grub screws do I need for the links, I’ve used some black ones (same as front suspension pin “locks”) but being black they are too visible I’d believe, so I’m guessing they used longer silver ones originally?
The original parts are 2-56 threaded rod zinc plated (galvanized) approximately 1/2" long each.
mtbkym01
Post by mtbkym01 »
2-56 screws with the heads cut off, much better, thanks for the advice
Old school ESC should be here by the end of the week, then this’ll done (apart from the battery straps)
mtbkym01
Post by mtbkym01 »
I swapped out the RX from a “G” type connectors to a “J” type to suit the Futaba MC110. So now the electrics are all fitted, all it needs is battery straps.
I understand all these electronics (except the motor) are a little bit “newer” than the buggy, but I’m running with the “it was upgraded” as these items were released :wink:
It just needs the battery straps and it’s complete, gonna take some “outside” pics today if we see some sunshine
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Really nice! 8)
That one's a keeper.
I had one of those early blue end bell 05 motors once but I can't seem to find it now.
Looks good!
mtbkym01
Post by mtbkym01 »
Users browsing this forum: No User AvatarMojeek [Bot] and 3 guests
