B1M
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Re: B1M
Post by mk-Zero »
the depth is .025" :wink:
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Finished machining the chassis tonight
then i started assembling the car. Got the roller more or less together, but i need longer turnbuckles for the front to go with the longer arms. I also need to paint the body. I hope to have the car on the track in a couple weeks.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: B1M
Post by JK Racing »
lemme know when your going to hit the track, ill come by and drool, i mean watch :)
MCKNBRD
Re: B1M
Post by MCKNBRD »
Nice!
I'm going to have to come up with something different for the bracing, though...I'm planning on using a litespeed heatsink motor plate, and I don't see how I could get it to fit with that style bracing.
Should be a heckuva performer! Keep us posted!
Byrdman
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Thanks guys. I'm pretty excited to get it on the track, it's been a while in the making. I'm sure it will take a while to get it dialed in though. For starters I'm going to use the same springs as the B5M, since the weight distribution will be similar, or at least closer than a regular RC10. We'll see.
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Tonight i mounted all the electronics. I put the esc on the right side of the car to help balance the motor being off-center to the left.
Test fitting the body
i put some wheels on her and took her for her maiden voyage on the street in front of my house. So far so good. We'll see how she does on the track, hopefully a week from this Thursday.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Re: B1M
Post by DaveM »
8)
It looks great!
Good luck mate, let us know how you go!
I just noticed are you running a gear cover?
Cheers, Dave. :)
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Thanks Dave. I have a gear cover for it, just haven't put it on yet. :-)
DaveM
Re: B1M
Post by DaveM »
8)
Pics are good!
Cheers, Dave. :)
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
I couldn't resist the other night, i took it for a few laps on the track. No body, nothing adjusted, almost no droop in the rear, and not enough in front. Even so, it handles pretty good. I can't believe how much steering it seems to have, its very responsive. Hopefully by next week I'll get the body painted and do a preliminary setup on the suspension. I think this is going to be a really great handling car.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: B1M
Post by RC10th »
The steering was the first thing I noticed with NIX10M. 2wd buggies (especially RC10's) tend to push but that wasn't the case. I assume yours handles similarly.
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Yeah, even with no setup its got way more steering that it did as a rear motor car. I can only imagine how well it's going to handle with a proper setup.
JK Racing
Re: B1M
Post by JK Racing »
Brian...dont tempt me...You know my biggest complaint is the slight push I have :)
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
I'll help you make one, no problem Joey 8)
Once I get the bolt-in trans cases and bolt-in rear bulkhead it will be a piece of cake. I may make my chassis braces available too...
JK Racing
Re: B1M
Post by JK Racing »
After I finish the other 8 project cars I have going right now!! I'll find a nice beat roller to get ready for your transformation :)
Users browsing this forum: No User AvatarAmazon [Bot] and 1 guest
