A-stamp long arm updated runner
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Re: A-stamp long arm updated runner
Post by mk-Zero »
I swapped in the 3 degree rear arm mounts last night. In doing so, I discovered that the rear hubs it had were 0 degree. Here's one of the old ones (left) on the same pin as one of the new 0 degree hubs I just bought. I figured all the original rear hubs were 1.5 degrees, guess not...
And one of the old hubs with one of the old 1.5 degree (?) Arm mounts
So it looks like I only had 1.5 degrees per side, all from the arm mounts. Hopefully the 3 degree mounts will help give me the corner exit steering I'm looking for. I guess I'll find out on thursday night. I still have the 25 degree castor blocks I'm holding onto (currently running 30's), but I'm trying to just change one thing per week.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
mk-Zero wrote:..I figured all the original rear hubs were 1.5 degrees, guess not...
The original 0 degree carriers vs. the 1.5 degree carriers:
http://www.rc10talk.com/viewtopic.php?f=38&t=27110#p276154
mk-Zero
Business Member
Post by mk-Zero »
Thanks Phin, good info!
mk-Zero
Business Member
Post by mk-Zero »
I did the bigbore spring conversion yesterday. Even just on the bench, the suspension feels much smoother through its travel. It has a much more purposefull look to it too 8)
I'll see how it goes on the track tonight. For now I'm running whites on the rear and blacks on the front. I may get a set of brown fronts to try out if the car is still understeering on power as it did with the small bore black springs up front. We'll see.
Norman
Post by Norman »
how did it run?
Hi. :)
mk-Zero
Business Member
Post by mk-Zero »
Pretty good, smooth for sure. The main issue remains push during corner exit. Next week I'll try the 25 degree blocks and see if that helps at all.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Brian, we should look at reducing front droop first (in my opinion), moving to the 25 degree caster blocks should exaggerate the exit push issue.
Adding caster (leaning the uprights further back) will generally give less initial turn-in, but more on-power steering and better straight line stability, while decreasing caster will generally add some turn-in, but at the expense of on-power steering and straight line stability.
By reducing front droop, less weight should transfer to the back leaving you more front grip upon exit.
mk-Zero
Business Member
Post by mk-Zero »
Sounds good Joey, lets try it!
I'll hold off on the 25 degree blocks for now then, I thought they would help it, not hurt it.
Users browsing this forum: No User AvatarTbot [Bot] and 5 guests
