2014 stealth
- Been thanked: 4 times
Re: 2014 stealth
I just got mine in from Amain.
Will probably build it in a few hours....I just have to prepare psychologically.
Feels good to finally have a tranny that will handle high Kv and 3s where I can have the power at hand to obliterate the thing on contact. Not that that's the objective.
The color of the case isn't white. It's off white on the beige/grey side.... Noticeably different then the 6gear kit supplied tranny case.
Tried uploading a pic, but the file size using this iPad mini seems to be too big.
Looks just like the pic posted a couple posts above, along with the instructions in the bag.
Edit: if you look at that pic (of the tranny in its packaging) posted like 2 posts back where the top left on top of the trans case (the rim around the slot the screw goes in) seems to have a brown smudge on it, mine has one in the same spot....that edge seems a lil brown (burnt?) n scuffed.
.....not that I'm complaining.....(a brothas happy as all hell)...just an observation.
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
Re: 2014 stealth
Wow, that's cool. I didn't think they had released them yet. Would love to see pics when you get it figured out. Thanks.
Re: 2014 stealth
Yeah, I got lucky.....The Sunday before last ,by chance, I noticed someone on here had mentioned them being "In stock" on Amain, so I rushed over there and ordered one. By Monday morning they were out of stock again.
I had told my local hobby shop to back order me one last month, and I went over there last night and he mentioned his distributor shows "march 4th" , so he should be getting it in a few days after that.....I guess I'm gonna end up with two...Not a bad thing.
I'll try to see if I can somehow manage the file size on this thing...Not only aren't I rc savy, I can't say I'm too tech savy either.
.....but it's exactly the same as the pic a couple posts up, just with instructions included in the bag.
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: 2014 stealth
I use "auto resize" from the App Store on iOS, very easy to use and good file size to upload here
It just has you pick a pic from your device and it saves it again as a smaller copy
Re: 2014 stealth
You might actually have the one they used for the addNickTheGreek wrote:I just got mine in from Amain.
Morten Max
Re: 2014 stealth
That's the only pic that seems to fit....I took it from far away n tried to zoom in, but if you look close, you can see the small scuff I was referring to on the upper left around that rim where the top screw goes....
It's MUCH more obvious up close...only way I can describe it, is that it looks like the edge of a burnt newspaper.
Thanks for that app info....Tomorrow when I get home from work I'll download it n play with it n upload some pics.
Re: 2014 stealth
There one more pic that seems to work.....Sorry for the bad quality.Im taking them from far way and trying to zoom in to make the file fit.
Edit... You can see how dark the plastic is in contrast with white instruction sheet.
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
Re: 2014 stealth
Well it looks like the original case. Even down to the top rear most screw hole damage (driver side), most original cases I've handled, have some kind of damage there.
Any way to tell the new one's from the old... ie: markings
Re: 2014 stealth
I thought I had mentioned this previously, but I will help clarify.marlo wrote:Well it looks like the original case. Even down to the top rear most screw hole damage (driver side), most original cases I've handled, have some kind of damage there.
There are TWO transmission cases, a new case and the original USA case. The two cases are VERY easy to distinguish from each other.
The new case has the ribbing and some internal pockets to improve how the case shrinks when it is cooling after injection. The new case halves are much flatter than the original and the spacers are now molded in as well as the cap. This was done just to minimize the tooling cost since it isn't really necessary for the WC. Also the new transmission case uses an updated idler gear that is more like a B4 idler gear, with the bearings in the gear and uses a B4 idler shaft but the idler tooth count is still the same as the original.
Lastly, both cases are available in spare parts so the oval guys have nothing to worry about (at least for the time being).
Tim Tunnermann
Team Associated Design Engineer
Team Associated | |Reedy | XP Digital | JConcepts | Futaba | Makita | Kicker | LiveRC
Re: 2014 stealth
O interesting! So the worlds gets the updated unit but the trans kit has the original style?
Re: 2014 stealth
Correct!
The current stealth transmission kit uses the US made transmission case, diff gear and idler gear AND we have just the US stealth transmission case by itself available.
The new case will come in the kit and in spare parts.
Tim Tunnermann
- 1729 Views
Last post by XLR8
- 74 Replies
- 6186 Views
Last post by GreenBar0n
- 1441 Views
Last post by spru
- 1422 Views
Last post by popboy905
- 853 Views
Last post by DennisM
- 20 Replies
- 4440 Views
Last post by Bubbleboy
- 874 Views
- 21 Replies
- 2810 Views
