JK's re-re Racer build
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: JK's re-re Racer build
I was doing decent in the 2nd qualifier with it (ran the 22 in the first qualy). Transponder wasnt picking up, then the motor moved with 3 laps left, so I babied it around, still killed the spur.
- mdutcher
Did you use the stock front block carrier on your recent build? I believe these would be at 15 degrees, correct? What did you think of the performance of the front end and steering and such with the stock blocks versus one with 25 or 30 degrees? Just curious.
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
They look loke B44 or B4 and a B4 cvdmikea96 wrote:I was wondering what rear hubs those are?
Morten Max
- JK Racing
RC10 CVDs, I asked for GT rear carriers, 1.5 degree and got these. They look just like them, but have 2 holes for adjustments
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Yeah those are ASC7367. Joey I looked and sold the white 10T ones in a lot a while back.JK Racing wrote:RC10 CVDs, I asked for GT rear carriers, 1.5 degree and got these. They look just like them, but have 2 holes for adjustments
- JK Racing
no issues, the black ones work just fine
Yes, I have the 15 degree carriers on there. I am going to give them a true shot on the track, but I will have a set of black 30 degree ones with me just in case. I didnt get a full pack in, motor moved and chewed up the spur. That is fixed now, so just need to get back to the track to get a set up done.
- JK Racing
I ran the car this past weekend, gave it quite a few shake down runs, played with gearing mostly. The car handles great. I need to pull the shocks apart and verify the set up, then I will post my complete set up.
The 15 degree carriers dont seem to be hurting it all that bad (with my driving, I cant really tell).
- mdutcher
Well that is good to hear JK. Thanks!
My build is 99% complete. Just need to take it out sometime and try it out.
Mine is almost done. I should make a post with what I have done. Just waiting on a few parts to finish it off. I can't wait to see your setup and how it differs from mine. I won't be able to hit the track anytime soon, so yours should be a good starting area for me.
- Has thanked: 170 times
- Been thanked: 23 times
And they are finally here!aip47-2008 wrote:flipwils11 wrote:I thought that if you contacted him he could specify a checkout procedure on his website whereby he would put together a set with lengths to match your application? I've never asked for a set for a short arm rc10 though.aip47-2008 wrote: Awhile ago, I sent an e-mail to Kelly Lunsford wanting to know if he could bring back some Vintage Lunsford Turnbuckles for the RC10 Classic Reproduction.
Edit: fixed the quoted section, sorry.
I was thinking Vintage.
http://www.lunsfordracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LUNS&Category_Code=NEW
- Y'ernat Al
JK,JK Racing wrote:...Gomachv, if you look, i spaced the rear tower way forward and run the shock behind them. I really didnt like the spacing needed on the tower or the arm to get the big bores lined up right in front of the tower...
B4 clear cover - only using the top screw for now. my 4-40 tap broke
BTW, big fan of the rear tower space forward idea. Great move
- Has thanked: 3 times
- Been thanked: 10 times
JK Racing wrote:I didnt contact him, Aaron did
The front arms are NOT whitened, nor brand new, they are used and scratched up on the bottom. That was just elbow grease and simple green, with a grout scrubber!
update from last night:
what gearing are you using with that 17.5?
- JK Racing
i gotta look again, but i think i am at 32~33/75
- 1581 Views
Last post by mikea96
- 2118 Views
Last post by pumpkinfish
- 31 Replies
- 5808 Views
Last post by blk05wrx
- 27 Replies
- 5585 Views
Last post by JK Racing
- 2374 Views
Last post by delsami
- 3872 Views
- 96 Replies
- 8031 Views
Last post by jsrracing
- 42 Replies
- 3411 Views
