Old is New Yokomo 870C Finished!!!!
- nvxwax
Re: Old is New Yokomo 870C (Lipo cradles, upper brace done)
That Yoke is a work of art, this makes me think all the restores im working on are just no fun lol, I need to get iinto some custom builds
- Seabass
- Business Member
- Been thanked: 12 times
Thanks William, it is going a bit slow right now. I finished machining all my aluminum parts and tore the car completely apart. I will be dropping my aluminum off at an anodizer to be coated hard black. When the parts return, I will begin the final assembly. I am still waiting on my MR4-BX slipper plate to arrive so I can begin the final machining work on a slipper clutch.
My next update will be after the ano is complete and the beginning of the final product.
Jake
Jake
- m_vice
Sound like you need to start a new project...
- Seabass
- Business Member
Re: Old is New Yokomo 870C (Ano work complete)
It has been a while since I had an update on this one. I got my parts back from the anodizer and they turned out great. I started the final assembly on most of the car. I still have to make the slipper shaft and a few parts for the rear of the car. I hope to get this one done soon. The amount of work I have put in this car is starting to weigh me down.
I am thinking I need to dye the steering bellcranks black.. The off white just does not fit the theme of the car.
Enjoy the pics and I hope to have more updates soon.
Jake
Jake
Looking great Jake, cant wait for the slipper.
― Confucius
― Confucius
- nvxwax
Looks killer, We will have to see some before and after pics lol
- Seabass
- Business Member
I hope to be rounding the corner on this one and should be calling it done very soon. I made a few changes to my original plan since my slipper clutch plans did not work out. I acquired a one way spur shaft from Reggie (tahnk you) which is now installed in the car. I have to make some new hubs for the front but that should be a pretty easy task. Other than that, I just need to get the new hinge pin holes drilled and get the rear arms mounted.
I rebuilt the shocks for the car. I turned down the hexes and had the shock bodies ano'd hard black.
I also got the rear wing mounted with the aluminum wing buttons and wing mounts I also machined.
Not much left to do on this one. Stay tuned for the final pics coming soon.
Jake
Jake
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
- Has thanked: 7 times
- Been thanked: 42 times
jwscab wrote:well, at least you can put in the closet when you are finished driving it, and it would still be appropriate
- Seabass
- Business Member
I figured you guys would get a laugh out of that. The guy has all these fancy tools and is using a POS to wing wire. It holds the wing perfectly fine and will stay like it is
I think it adds character......maybe not
Jake
Jake
- 1266 Views
Last post by dubfreak
- 63 Replies
- 8313 Views
Last post by Synergy
- 2035 Views
Last post by flustorm99
- 2473 Views
- 2451 Views
Last post by Alex B
- 1179 Views
Last post by kenooze
- 26 Replies
- 4527 Views
Last post by DerbyDan
- 6639 Views
Last post by 59burst
