8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
The top piece looks like a servo mount of some sort with the elongated hole top right.
crusaderlyf
Post by crusaderlyf »
Asso_man! wrote:Front shock tower inthe 3rd pic is from a Kyosho Lazer-ZX I believe.
looks like that but the screw holes not right.
Has thanked: 1737 times
Been thanked: 1145 times
The top piece is "Carbon Battery Plate Set TA03F Pro" - see http://www.ebay.com.au/itm/Tamiya-53261-OP261-Carbon-Battery-Plate-Set-TA03F-Pro-/130591877742?pt=Radio_Control_Parts_Accessories&hash=item1e67e1ea6e.
Can someone confirm if these are Hyperdrive pulleys and belts please?
Thanks.
billetproofcustoms
Post by billetproofcustoms »
Ok,
here is an item on ebay, appears to ba an Italian made vintage RC from probably early 70's, possibly 60's..??
The listing has quite a few great pics of the car and the VERY primitive tranny, servo, and ESC? setup..
Anyone know if this is something worth buying?? Looks cool for sure..
http://www.ebay.com/itm/290606132137?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Has thanked: 358 times
Been thanked: 470 times
Incredible_Serious wrote:Can someone confirm if these are Hyperdrive pulleys and belts please?
Thanks.
They are indeed
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
billetproofcustoms wrote:Ok,
Ferrari P5 is from 1968 so later 60's early 70's. Too bad it's missing the glass as it looks pretty cool!
This is all very interesting!
Thanks.
They are indeed
Thanks mate.... now to find a Hyperdrive spur to go with them...
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
klavy69 wrote:anyone know what I ended up with here? of course the obvious is hot trick but for what?
just to bring it up to page. got the red stuff and still haven't gotten any ideas besides a possible brace suggestion. Any other guesses to point me in the direction of investigation? While you are thinking of this I was told this was an ofna TC but another told me it was Tamiya :lol: . I laugh because I have no idea but thought someone here might've seen it before...ImageImageImage
thanx again.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
The small brace on top is for the Optima Ram, as are the suspension arms below. The small L angle piece between the two is a body mount that uses velcro to attach bodies. Not so sure about the big part on top.
Aaron
klavy69
Moderator
Post by klavy69 »
Thanx Aaron. That helps a lot. Gives me a direction to start looking for the unidentified piece. This was one of those bid to watch and won type things so hopefully we'll figure out what that last piece is so these can get 'adopted' to a new home somewhere :lol:
klavy69 wrote:Thanx Aaron. That helps a lot. Gives me a direction to start looking for the unidentified piece. This was one of those bid to watch and won type things so hopefully we'll figure out what that last piece is so these can get 'adopted' to a new home somewhere :lol:
This is where we miss the "Guru of Hot Trick", ole Woobergoober..... he would have told you in a second that the large part is a Hot Shot rear mount... like in the pictures here, first pic: http://www.tamiyaclub.com/showroom_model.asp?cid=66704&id=3729. Took me a while to find, though.
klavy69
Moderator
Post by klavy69 »
And Thank you Alex :!: . Been trolling thru 'hot trick' in the non-rc10 section and between the slow DSL and broken pix its been really rather frustrating...
Lowgear
Has thanked: 121 times
Been thanked: 796 times
Post by Lowgear »
Did Hot Trick make different Optima arms because those are different from mine.
Lowgear wrote:Did Hot Trick make different Optima arms because those are different from mine.
Could be Hot Shot arms as well, hard to say... can't see pics clear enough of the Hotshot arms anywhere to make a decision.... although all pics of the Optima HT arms seem to agree with you.
Return to “Identifications”
