RogueIV
Has thanked: 2130 times
Been thanked: 1096 times
Post by RogueIV »
RC10th wrote: Sat May 31, 2025 8:04 am This will get lost in here but I'll post this for documentation.
B5 knockoff
T5 knockoff
B5M knockoff
T5M knockoff
They also do an SC10B
Who is "They"?
I just want to point out that the Crossed out "No Copies" sticker is actually a double negative, Associated Asked for this!
80sRunner
Has thanked: 7 times
Been thanked: 16 times
Post by 80sRunner »
....a complete rere GT body set for a vintage black pan that I am restoring. These nitro trucks aren't difficult, but are a pain to clean.
TravelinTravis
Has thanked: 986 times
Been thanked: 371 times
Post by TravelinTravis »
Well...I might have done something. :lol:
Trass
Has thanked: 487 times
Been thanked: 258 times
Post by Trass »
TravelinTravis wrote: Sat May 31, 2025 4:11 pm Well...I might have done something. :lol: 20250530_114314.jpg
Lipo powwwwweeeeeeeerrrrrrrrrr !!!!!!
Jerome
ZED32
Has thanked: 166 times
Been thanked: 242 times
Post by ZED32 »
Finally found a reasonably priced stealth transmission. It needs a new bearing or two and smells of cigarettes, but that's nothing I can't take care of. Plus I'll probably be dying it black to use for my Tamiya Astute. I'll modify a 6-gear motorplate to use with it.
Been thanked: 3917 times
Did you find some longer axles for the astute? I found the db01 axles work well with a stealth on the king cab, and I'm pretty sure they are on the same arms.
ZED32
Post by ZED32 »
GoMachV wrote: Mon Jun 02, 2025 5:04 pm Did you find some longer axles for the astute? I found the db01 axles work well with a stealth on the king cab, and I'm pretty sure they are on the same arms.
I'm not sure what size I need yet. I need to make a bracket to mount the stealth first and then I'll measure for new bogbones. I'd imagine it'd be the same as the king cab, although my Astute still retains the stupid adjustable rear hubs.
We used to sell an adapter plate to put a lethal weapon on the astute. If you get stuck let me know and I should be able to reverse it to a 6 gear using the one set of holes that lined up, then add the stealth holes from the adapter plate to get the correct layout. It's like a 5 minute task to lay it out.
Has thanked: 1735 times
Been thanked: 1145 times
GoMachV wrote: Mon Jun 02, 2025 10:03 pm ...It's like a 5 minute task....
Famous last words..... :P
TRX-1-3
Has thanked: 2063 times
Been thanked: 991 times
Post by TRX-1-3 »
Incredible_Serious wrote: Mon Jun 02, 2025 10:06 pm
"Nothing takes 5 minutes"
TRX-1-3 wrote: Mon Jun 02, 2025 10:36 pm
Those things take two weeks...
ZED32
Post by ZED32 »
GoMachV wrote: Mon Jun 02, 2025 10:03 pm We used to sell an adapter plate to put a stealth on the astute. If you get stuck let me know and I should be able to reverse it to a 6 gear using the one set of holes that lined up, then add the stealth holes from the adapter plate to get the correct layout. It's like a 5 minute task to lay it out.
I see the king cab adapter on your website, but if there's an astute one I don't seem to have the patience to find it at the moment. The astute and king cab require different provisions despite being similar. I also already have a sheet of carbon fiber on order to make my own. Not sure how big it is, but I'm going to make the entire chassis new in carbon if I can.
We haven't sold the astute set in years so I don't have the adapter plate listed, but we have em. Still, it sounds like you have it under control 8)
Has thanked: 2604 times
Been thanked: 2976 times
It's not often that I get a large batch of motors that I like all of them, but today is one of those days.
My only disappointment is that the Checkpoint isn't a modified. But it's only a small disappointment. :mrgreen:
TRX-1-3
Post by TRX-1-3 »
Frankentruck wrote: Tue Jun 03, 2025 1:23 pm It's not often that I get a large batch of motors that I like all of them, but today is one of those days.
Wow, the Race Prep with the "ceramic" shaft!
