I run big bores on my Re-ReOrange wrote:I put big bores on my RC10...
#6002 - RC10 Worlds Car Kit
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: #6002 - RC10 Worlds Car Kit
- abailey21
Is it avid that makes the big bore spring cups?Orange wrote:I put big bores on my RC10... They look right at home on there! And if I ran V2's, they would also get Big Bore springs adapted on them. Talk about rubbing springs! Not a fan of having to sand them to make them work semi right. I would run older kyosho springs before that happened.
(Let the comments commence)
- Orange
Yes... They are essentially the same, just beefier in all the right places.janaya wrote:Do the T2 versions not have the second set of holes for extending the wheel base?
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
With double the "angle of the dangle"Orange wrote:Yes... They are essentially the same, just beefier in all the right places.janaya wrote:Do the T2 versions not have the second set of holes for extending the wheel base?
- Orange
Adam - Ghea makes the Adjustable collars. And then you use AE spring cups.abailey21 wrote:Is it avid that makes the big bore spring cups?Orange wrote:I put big bores on my RC10... They look right at home on there! And if I ran V2's, they would also get Big Bore springs adapted on them. Talk about rubbing springs! Not a fan of having to sand them to make them work semi right. I would run older kyosho springs before that happened.
I think some people use the stock collars with some traxxas collars as well, its a much cheaper way to do it, but I'm not sure which collars are used.
- Orange
Yes... Forget about that all the time! I mostly like them because I don't have to worry about breakage! If I break one of these, I really, really suck!Charlie don't surf wrote:With double the "angle of the dangle"Orange wrote:Yes... They are essentially the same, just beefier in all the right places.janaya wrote:Do the T2 versions not have the second set of holes for extending the wheel base?The RC10 really becomes a different animal with these in it. Night and day-
- RC10th
- Has thanked: 52 times
- Been thanked: 1549 times
You'd probably be more likely to break an arm or pull the screw out of the chassis.
- TOLITS
Too bad got outbid on ebay item # 191062276136.
Will just wait for these re-release.
You can actually use Traxxas parts.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- bully
- Been thanked: 6 times
AE has listed most of the parts that are new for the worlds.. Something struck me is that rear hubs,they are listed as 0 degree and since they aren't doing 3 degree arm mounts the worlds has 1½ degree rear toe in. On the plus side is the stealth case and spacers,front and rear towers are listed,the stealth spacers and cap are listed under the idler link which is probably a mistake.. Hopefully the rear hubs are actually 1½ or 3 degrees... Almost forgot the 30 degree front caster block in white and the inline steering block also in white.. Awesome keep up the great work TEAM ASSOCIATED...
- blown5.0
The chassis is milled also!
http://teamassociated.com/parts/details/6302/
- Has thanked: 3 times
- Been thanked: 10 times
so redrc has some more pics of bk's worlds car from the jconcepts winter nationals:
http://events.redrc.net/2014/02/chassis-focus-kinwald-rc10-classic-b5/
and compares it to the b5. it is good to know that he can turn the same fast lap with a worlds as with a b5.
- Orange
Getting back to the "Worlds" Graphite because I missed a few pages and responses....
Only reason I said that, is because a few years ago when I was calling it that it seemed important by some to inform me that there was no such thing as a worlds graphite....
Glad I could return the favor on something that makes no difference.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
bully wrote:... Almost forgot the 30 degree front caster block in white and the inline steering block also in white...
- 2770 Views
Last post by sandkil
- 1058 Views
Last post by carloco8
- 4323 Views
- 2089 Views
Last post by XLR8
- 872 Views
Last post by RogueIV
- 1535 Views
Last post by AndrewCooke
- 1181 Views
Last post by ASC6000
- 2471 Views
Last post by mytimac
