Edit : tweaked it so it become less obvious that the external ring is bigger...
I think I'll need to reprint those
I just noticed the impact of the retractation on the long print for 4 wheels. I reduced a bit and the time is already noticeable.... Going to direct drive at the same printing speed (i'm currently printing at 60mm/s) will definitely change something...Dadio wrote: ↑Sun Feb 06, 2022 10:39 am It's a toss up between Bowden with a light print head but lousy retraction and direct drive that's heavier but tiny retraction , the thing that swung me to direct drive was the time it takes to do retractions , just try it on a long print in your slicer with a 7mm retraction or with a 0.5mm retraction , it saves loads of time , this means that a Bowden printing 80mm/p/s is not much faster than a direct drive at 60mm/p/s .
Also these days with the super light weight extruders like the Orbiter that I'm using a direct drive setup is not nearly as heavy as they used to be ! You'll probably have to design a mount yourself as the 5+ is not so popular , I had to design one for the Ender 5 as there was nothing exactly right on Thingiverse as I'm also using a Dragon hot end .
My brother is doing some stuff on bigger things powered by those same stepper motors. His take on them : they are able to cope with more weight without much issues, and he has converted his bowden printer to direct drive by just changing the stepper motor place for the extruder: and as per his saying, he's able to print much faster than 60mm/s with his configuration. At this stage with those issues I got recently, I didn't dare going faster than 60mm/s anyway. I may want to try this... The roller are accumulating dust, and this is my problem : cats in the house probably don't help for this : linear rails would be a substantial improvement for this reason... Ultimately, i'm still debating about upgrade or replace the printer:Dadio wrote: ↑Sat Feb 12, 2022 4:09 pm Yup , it's not actually printing faster but it's waisting less time for the same result , another thing you mentioned was going to linear rails , with the Ender 5 style printer there is already an extra stepper motor on the X axis making it heavier than a core XY printer , adding a linear rail will make it heavier still , I've been planning on fitting them to the Y axis as there's no weight penalty but I'm leaving the rollers on the X axis as it's lighter , I've even considered milling down the X axis 20/20 beam to reduce the weight further .
Brain cheese builds up fast in Fusion 360 , you need time for it to melt awaysilvertriple wrote: ↑Sun Feb 13, 2022 5:14 pm The print is done and tested, and it's now final.
But not now. I'm exhausted![]()
Thanks! @Dadio , do not hesitate to contact me if you want details on the parametric stuffDadio wrote: ↑Sun Feb 13, 2022 5:49 pmBrain cheese builds up fast in Fusion 360 , you need time for it to melt awaysilvertriple wrote: ↑Sun Feb 13, 2022 5:14 pm The print is done and tested, and it's now final.
Looking good though , worth the effort![]()
