RC10t from the ground up with an RC Carbon Works chassis
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: RC10t from the ground up with an RC Carbon Works chassis
those rc carbon works axles essentially are just a long axle with a spacer to put between the bearing and the drive pin. The rear wheels would bolt up just like anything else on a regular axle...just out further than originally. Those are dogbone only and I would go cvd for reliability for a runner before those but thats just me.
Not bashing you on this but just an info on my end but why would you want to extend out your wheels that wide?
- Has thanked: 1129 times
- Been thanked: 3919 times
- klavy69
- Moderator
yeah, threw me for a loop in the truck section...all the same offsets kinda thing...GoMachV wrote:Modern offset wheels
I was more kind of inquiring about them to figure this kind of stuff out! Thanks for the response!klavy69 wrote:those rc carbon works axles essentially are just a long axle with a spacer to put between the bearing and the drive pin. The rear wheels would bolt up just like anything else on a regular axle...just out further than originally. Those are dogbone only and I would go cvd for reliability for a runner before those but thats just me.
Had to put the project off a few weeks as a pine tree fell into our master bedroom during storms last week... fortunately everyone was safe but the house incurred loads of damage which we're in the process of sorting out with insurance!?! Mostly damage to the house... very little loss of personal property thankfully! So stay tuned - assembly coming at some point!
Random question so I can be sure - will an rc10gt bellcrank/steering kit fit an rc10t? I'm pretty sure it will but wanted a definite answer!
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
It will but you'll have to use them in the shorter position in the nose plate. If you use the stock GT parts no problem, if you use a MIP set up beware the bellcranks are "flipped" to opposite sides.
Yeah I've seen a few of those MIP GT kits on ebay and was curious... so they won't fit or they're just backwards?
- RC10th
They fit no problems, just "backwards" from the 10T bellcranks.
i.e. servo arm is on the right side instead of left.
So does that mean I'd need to drill new holes to remount the servo?
Thanks to PerryCodes I've got a new in package nose plate coming! So I may actually start assembling stuff next week!?!
Anyone have any suggestions for for shocks now that I'm getting into actually building something? I envision the truck for large open indoor surfaces like gyms or light carpeting/turf... maybe asphalt if I'm able to get a fitted clear protective film on the bottom. There's a local Xpel shop nearby that can cut a fitted piece for me.
The more I think about the idea of a top deck the more I'm considering just getting a second carbon fiber chassis cut down to fit and leave a hole for the battery to fit into;)
Randomly had two mint, new in package nose plates come into my possession this week:
Man those things are hard to come by nowadays!? I watched for like 3 months and didn't find anything without a ton of scrapes and scarring... then like 30 minutes after I decided to buy one the other immediately popped up on ebay!?!
- 25 Replies
- 3431 Views
Last post by firebird1999us
- 2313 Views
Last post by Ucsdmutt
- 3646 Views
Last post by phoenix
- 1195 Views
Last post by shodog
- 20 Replies
- 2169 Views
Last post by JosephS
- 29 Replies
- 5587 Views
Last post by EMC
- 2316 Views
Last post by durb69
- 26 Replies
- 3497 Views
Last post by Chewbacca
