[Some pix back in P5] - "Blue Is Better" TRX-1 Resto-Mod (2017/07/07
- TRX-1-3
- Has thanked: 2071 times
- Been thanked: 993 times
Re: Black and Blue TRX-1 - Seabass-style - Electronics IN! (03/25/2017).
You could get some 2600 series dished wheels. 2.2 rears and 2.15 fronts. Would be a direct fit and they are comprised of less nylon. I've dyed a bunch of them and they never turn out blue/dark purple. I over concentrate and long soak them. Just an option. They are a little harder to find though.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Thanks Todd. Got it. Mmmh, alloy wheels... have a link to share, especially for the front? Who knows... this might be the perfect finishing touch!klavy69 wrote: ↑Sun Mar 26, 2017 8:25 pm To dye this stuff takes a definite 'want to do'. I've had issues with black not taking in and turning brown also. Looked like crap when I was done and ended up looking worse than the off colors it was to begin with. If you do try to dye a set of those wheels simple green the crap outta them and then boil them first to get rid of the form release agents on the nylon and they'll take dye easily and uniformly![]()
I'm thinking this one could use a nice set of alloys like some blue T&A wheels to be over the top but then again...they don't hold up well the way I"d run it![]()
Cheers for the suggestion - would you have a full P/N by any chance? Struggling to identify them online...TRX-1-3 wrote: ↑Mon Mar 27, 2017 9:30 am You could get some 2600 series dished wheels. 2.2 rears and 2.15 fronts. Would be a direct fit and they are comprised of less nylon. I've dyed a bunch of them and they never turn out blue/dark purple. I over concentrate and long soak them. Just an option. They are a little harder to find though.
Thanks guys!
Paul
- TRX-1-3
Yes TRA...I get fixed on the TRX. Thanks for the clarification.
TRA 2671, Front, 2.1"
TRA 2672, Rear, 2.2"
- Lonestar
thank you!
WHOA
http://www.ebay.com/itm/VINTAGE-TRX-TRAXXAS-FRONT-WHEELS-WHITE-NYLON-DISH-TCP-2671-/370722463830/?_ul=HN
$33!!! And he sold 8 already!
Rears are $4, much better
Will stick to the existing set I guess
you could technically use an RC10 white front wheel with 5/16" bearings, and put 5x8mm bearing it, with 8mm being super close to 5/16"
- TRX-1-3
Well if you want a set of dyed black original five spokes(2770, 2771), let me know. Then you would need to find some old school 2.0" rear tires. Options. You have options.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
WIsh I had a link to some T&A wheels. Problem with them is they seem to be rarer than tecnacraft anymore. When I do see them they go for well over my budget for them at the same time. I miss when they were littered all over the boards and ebay. Duratrax alloys seem to come up more often for cheaper and then you can get them re-annodized to fit your needs but I don't even have a set of those anymore. I've got a set of fronts or rears that I"ve been looking for the other end for a couple years now
If I come up with any ideas Paul I'll drop them your way
- Lonestar
Cheers Guys, you're nice
True, I forgot about the AE front wheel trick... silly me, I use it on one of my runners!
thanks
TRX-1-3, sir, PM coming your way - black original 5spokes would be great, I still have 2.0 tires that would fit nicely!
Thank you,
Paul
Thank you,
Paul
- Lonestar
Body fitted!
- Lonestar
Trying to cover a few days of updates in one go
First, the body was decal'ed using a mix of old and new stickies, representative of the car and the parts that are on it! Lots of LRP stuff, some traxxas, some RPM (gear cover!), etc...
It's a fine balance between protecting the overall looks of the car, and still putting the right amount of stickers, which is a fine art... I tried to do my best
Then a few people commented that the white rims simply don't work that well with the car... and they are right to some extent! Mark was kind enough to provide some mildly used but unmolested original black-dyed 5-spokes
Thanks again Mark
Then I dug into my NOS tire stock and I came up with this for the front, as well as a set of Cat copycats!
even if it's "just" a pair of tires, it's always a fine moment to open a sealed vintage RC bag... Then I cleaned them up and with a lot of elbow grease and cusswords (these old coumpounds are HARD!) this is what the final result looks like, at last:
Thanks to all those who helped make this one come to life - it only took two and a half years to get this one done in the end
Paul
Paul
- Been thanked: 325 times
Re: [COMPLETED AT LAST] - "Blue Is Better" TRX-1 Resto-Mod (2017/05/10)
That's a beautiful car, dressed or nude. Great attention to detail.
Glad you went with the black wheels!
- TRX-1-3
Dude, I'd sleep with that next to me. I'm that crazy. Nice work on the build. It looks amazing and I bet it would (not sure if you should run it) get around pretty good also. I am glad the wheels worked out for you.
- klavy69
- Moderator
really dresses that chassis up with those black wheels. Turned out stellar...thanx for helping keep the old traxxas alive
- 3309 Views
Last post by TRX-1-3
- 1291 Views
Last post by Brandon G
- 1492 Views
Last post by JasonB
- 2751 Views
- 2555 Views
Last post by Benjammin
- 1736 Views
Last post by scoobyrs25
- 1437 Views
Last post by shoman24v
- 3274 Views
