RE RE STEALTH TRANS
GodSpeed
Re: RE RE STEALTH TRANS
Post by GodSpeed »
So I got a 'bad' style case and a bad top shaft....and bad idler?
I spoke to a guy about 30 minutes ago and he said to call back in an hour to talk with Bob Stormer. Just want to get my info straight before I call.
Thanks guys.
Has thanked: 33 times
Been thanked: 1212 times
not everyone had problems. build it and find out or send it back and get the old style kit.
Has thanked: 1081 times
Been thanked: 3747 times
Exactly, it's not a guaranteed problem just not the actual kit. He may not know they are different.
GodSpeed
Post by GodSpeed »
Well, I'm a little bit annoyed about it because I thought what I was ordering was a #6560 kit, not a bag-o-parts.
And you're right, it doesn't have the brace, so what am I going to do there?
Waiting for Bob to get back into the office. Hopefully it can be sorted out....with a proper #6560 kit, but my expectations are dwindling.
I bet he knows exactly what's going on.
Keep in mind the brace is a couple bucks, the motor plate and gear cover are far more! I think it was a good deal actually, but if the case and or shaft are a problem it may be more difficult to get associated to cover it since it was from a kit not a trans only kit
Maybe he will send you the 6565 case and 6570 idler, who knows!
GodSpeed
Post by GodSpeed »
gomachv wrote:Maybe he will send you the 6565 case and 6570 idler, who knows!
And a top shaft? What's the P/N I'd want?
So far he's been like Polkaroo. "You just missed him. Try back in another 30min to 1hr." haha
RC10th
Has thanked: 50 times
Been thanked: 1495 times
Post by RC10th »
Were there any problems with the top shafts in the proper US kits?
I opened and built one worlds kit which had the top shaft issue, I also bought a US stealth kit, somewhere along the line I had a new top shaft that made its way into the mix.
Comparing the worlds problem top shaft to I presume the top shaft from the US kit they are both identical, both machined further than a used B4 shaft that I compared them to. I don't really want to take the trans out my OIN again to compare but I'm curious.
NickTheGreek
Post by NickTheGreek »
What about the diff gears themselves....you have the cream colored one (that comes with the worlds car) where the balls fall right in and then the black one(that comes in the stealth kit) ) where you have to press the balls down into place. Is one preferred over the other???
Seems like the only replacement diff gear is th black one. (Part# 6580) .
Material wise the tan gears should be superior, but in actual usage I can't say
badhoopty
Has thanked: 169 times
Been thanked: 151 times
Post by badhoopty »
i ordered 2 6065 stealth kits out of ebay boredom last week.
last night i opened up a worlds re-re kit and got to work on the trans. after reading a little here i didn't really have any hopes it would spin nice or clear the motor plate, but i figured id at least find out for myself.
like many here I've put together ALOT of stealths over the years, and the second i managed to snap the new case together with the kit internals i knew it was garbage... decided to put the motor mount and slipper on to see if i had that problem too, and yep the slipper made contact with the motor mount. absolute crap trans. I'm a big fan of it aint broke you don't fix it, and i dont understand what was broke about the original design.
anyway, decided no big deal right? i'll just use one of my 6065 kits. but out of the two stealth kits only one had the properly machined topshaft. so it might be old news, but yeah there are bad shafts in the 6065 bag kits as well.
i couldn't believe the crappyness of the revised kit stealth. somebody wasn't paying attention to somebody else's lack of quality and craftsmanship.
badhoopty
Post by badhoopty »
RC10th wrote:Were there any problems with the top shafts in the proper US kits?
i had a us kit with the crap topshaft.
Good to know. I hadn't heard of the mismachined shaft in the trans kit yet. I agree, the old case was good. Us Americans especially should know, "change" isn't all it's cracked up to be :mrgreen: :lol:
besty22
Post by besty22 »
Has anyones re re kit transmission gone together well?
Respect - Hard Earned but Easily Lost
besty22 wrote:Has anyones re re kit transmission gone together well?
No, that's pretty much the summary here- the kit trans is junk. Install a 6565 case, 6570 idler, and get a non-mismachined top shaft and it will be great tho!
besty22
Post by besty22 »
Thanks, so I should order those parts now before I even build it you reckon?
Cheers
Users browsing this forum: No User AvatarGoogle Adsense [Bot], User avatarmorrisey0, User avatarpma1123, No User Avatartimjz and 4 guests
