Inventory updates
Moderator: mytimac
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 56 times
Re: Inventory updates
The new parts are up. Still working on photos.
http://sabulatech.com/storefront/index.php?controller=new-products
HPI RS4, RS4 MT and Nitro Rush
72082 Universal Dogbone Center Front
72011 MIP CVD Axle Front Pro2
72190 Sway Bar Set Nitro Rush
A349 Bumper Set Nitro Rush
73030 Front Shock Tower Nitro Rush
Trintiy
TK1200 RC10GT Motor Mount Brace (for old style chassis)
Proline
2641Y Dish 2.2” 4WD Front XX4
Tamiya
0115227 K Parts King Blackfoot
0005642 G Parts King Blackfoot
0005417 D Parts King Blackfoot - super blackfoot - bush devil
9005304 B Parts King Cab - Hilux
9465592 Screw Bag C Ferrari F201
9465589 Screw Bag G TXT-1
Trintiy
Proline
Tamiya
- mytimac
- Business Member
Found we accidentally never put these visible on the store months ago.
All for early Losi
RPM 7302 Heavy Duty Bellcranks
RPM 7325 Extra Wide Side Bulkheads
RPM 7318 Delrin Pivot Balls
RPM 7310 JRX2 Spindle Blocks
RPM 7385 Losi Carriers
All for early Losi
- mytimac
- Business Member
Got some new Losi parts in and found some stuff that wasn't shown in stock while going through inventory.
a1001
a1107
a1120
a1206
a3010
a3033
a3227
a3269
a3946
a4005
a4123
a4216
a4221
a6218
a9960
a1001
a1107
a1120
a1206
a3010
a3033
a3227
a3269
a3946
a4005
a4123
a4216
a4221
a6218
a9960
- mytimac
- Business Member
Losi parts just in
A3089 GenII Dogbone and Yoke
A5015 Double ORing Shock Cartridge
A5020 Silver X-Long Rear Shock Kit 1.2"
A5022 1.2" shock shaft
A5026 Blue Shock Bodies 1.2"
A5037 Black Shock Bodies 1.2"
A9946 Titanium .250 Ball studs and rod ends
- mytimac
- Business Member
Just in
Associated Parts
9210 Front Kickup Black Anodized
9241 Rear Chassis Plate B2 T3 B3
HPI Parts
A470 Rear Bulkhead Set
A180 Servo Saver Shaft
A779 Arm Brace Set
Losi Parts
a1116 Fr Suspension Arms XXXT XXXNT
A1125 Fr Spindles and Carriers XXT
a2126 “CR” Rear Hub Set
a2909 Monster Diff screw
A3045 Slipper Gear Cover Plug
A3090 Dogbone
a3099 Full Thrust Bearing Set
a3316 Diff Bearing Centric JRXS
a3983 48P Spur Gear 82T
a3987 86t Kevlar Spur
a4117 Battery Strap Foam Pads
a4222 Wing Mount Set
A4239 Body Post and Bumper Set JRXS
a5004 Shock Shaft Front .6"
a5060 Shock Shaft .6" Tri-Nitride
a6365 Hub Bearing Spacer & Shim Set
a9336 Engine Mount Set XXXNT
a9735 Fr Arms Graphite
A9802 Rear Arms Graphite
a9807 1Deg Rear Hub Set
A9810 Graphite/Composite Rear Arms (XXT CR)
a9911 Graph Long Battery Strap
a9926 XXT Truck Alum Dog Bone
Associated Parts
HPI Parts
A779 Arm Brace Set
Losi Parts
A3090 Dogbone
- mytimac
- Business Member
Many new Losi parts in. These are just the ones I have gone through so far, I have more. We are closed until the 15th right now, but orders will resume shipping again on the 16th. (might take most of the 16th to get through the back log of orders to ship)
You can order items now and when I get the rest added you can do another order if needed. I will combine shipping on all orders placed before the morning of the 16th and refund some of the shipping charges.
If an item sells out check again later after next update on here, I have a bunch to go through and we may have more to add. I know there is long xx chassis to add, XX steering mount (both styles), XX4 Truck Mounts...
A7004 Yellow Forn Rims XXX
A6003 Foam Things
A3074 2.19 Diff Gear
A1111 Front Arms XXX
A9955 Red Alum Fr Pin Brace XXX XXXT
A3078 Diff Screw Hardware & seal
A9956 Alum Fr Pin Brace XXX XXXT
A3018 Small thrust bearing
A3098 Diff Thrust Bearing
A3070 Diff Rings
A9712 XXXT Fr Arms
A4100 XX Main Chassis
A2010 Wing Tubes
A3001 Transmission Case (grey)
A2020 Pro Rear Shock Tower
A1002 Fr Spindles Carriers
A8120 Machined Wing Buttons
A3101 Hydra Drive Unti
A3002 Motor Plate
A3130 Hydra Drive Rebuild Kit
A3119 Hydra Drive Housing
A2210 Rear Pivot blocks XX4 White
A6003 Foam Things
A3070 Diff Rings
A9712 XXXT Fr Arms
A2010 Wing Tubes
A3002 Motor Plate
- mytimac
- Business Member
Ok, more listed. If a part listed last night showed out of stock it is now back in stock again. Here is now the complete list of Losi parts listed in last 2 days. As of this post they should all be in stock. Prices have also been lowered on many parts. We got a good deals on some parts and passing the deals on to you.
A6003 Foam Things
A3070 Diff Rings
A9712 XXXT Fr Arms
A2010 Wing Tubes
A3002 Motor Plate
A2110 XX Rear Pivot Support
A1601 XX Steering Servo Mounts
A4045 Front Bumper
A9730 0 Deg Front Bulkhead XX4 & SW
A2107 CR Rear Pivot Plate
A9910 Graphite Battery Strap XXX
A2035 SE Rear Shock Tower
A1014 Se Front Shock Tower
A2112 Rear Pivot Block 0Deg
A9830 Graphite Rear Pivot Plate for CR
A3055 Retrofit Transmission Case 2.61:1
A3016 Rear Axle Spacer
A9903 XX Graphite Chassis with Brace Long
A4227 XX4 Truck Body Mount Set
A6003 Foam Things
A3070 Diff Rings
A9712 XXXT Fr Arms
A2010 Wing Tubes
A3002 Motor Plate
A4045 Front Bumper
- mytimac
- Business Member
The Losi Motor Plates from last post are sold out now.
But here is some stuff for just about everyone, stickers. Autographics decals with various vintage RC brands on them.
10013 Novak Gold Decals
10023 Reedy Gold Decals
10024 Reedy Red Decals
10025 Reedy Blue Decals
10031 Team CRP Black Decals
10032 Team CRP White Decals
10033 Team CRP Gold Decals
10034 Team CRP Red Decals
10035 Team CRP Blue Decals
10043 Futaba Gold Decals
10052 REVTECH White Decals
10053 REVTECH Gold Decals
10055 REVTECH Blue Decals
10061 ProLine Black Decals
10063 ProLine Gold Decals
10064 ProLine Red Decals
10081 JG Black Decals
10082 JG White Decals
10083 JG Gold Decals
10085 JG Blue Decals
10092 Tekin White Decals
10093 Tekin Gold Decals
10094 Tekin Red Decals
10105 Paragon Blue Decals
10113 Airtronics Gold Decals
10123 RC Car Action Gold Decals
10134 Gonzo Red Decals
10135 Gonzo Blue Decals
10145 Twister Blue Decals
10153 Sanyo Gold Decals
10154 Sanyo Red Decals
10155 Sanyo Blue Decals
10161 RC News Black Decals
10171 Checkpoint Black Decals
10182 Competition Plus White Decals
10184 Competition Plus Red Decals
10193 Race Prep Gold Decals
10193 Race Prep Red Decals
- mytimac
- Business Member
Just a quick couple things
RPM RC10T Mini Fornt Bumper in Black are back. 3 of them
Team Associated 3980 tc3 rally front bumper back as well.
Our mega big arrival of updates should be this week some time.
- mytimac
- Business Member
The Team Losi A5000 parts are up on the store now. Still have some pictures to take but will worry about that later.
Got a bunch of the old style shock cartridges right now.
A-5004 "SHOCK SHAFT FRONT SHORT .6"""
A-5005 "SHOCK SHAFT REAR .9"""
A-5006 COMPENSATING SHOCK CARTRIGE
A-5008 UPPER SHOCK MOUNT BUSHING
A-5011 OUTER O-RING FOR SHOCK CARTRI.
A-5012 TEFLON SHOCK PISTON SET W/E-CL
A-5013 XXX FR & RE UPPER SHOCK MOUNT
A-5014 O-RING FOR SHOCK CARTRIDGE(8)
A-5015 DOUBLE O-RING SHOCK CARTRIGE
A-5017 "1.0"" SHOCK SHAFT"
A-5022 "X-LONG SHOCK SHAFT 1.2"""
A-5023 SPRING CLAMP & CUPS H-ARM
A-5025 SHOCK SHAFT .36 SEDAN
A-5028 SHOCK BODY HARD .36 SEDAN
A-5029 "SHOCK BODY .6"" HARD ANOD/COAT"
A-5030 "SHOCK BODY .9"" HARD ANOD/COAT"
A-5031 "SHOCK BODY 1.2"" HARD ANOD/COAT"
A-5032 "SHOCK SET .6"" HARD COAT W/HARD"
A-5034 "SHOCK SET 1.2"" HARD COAT W/HAR"
A-5035 .36 SHOCK SET HARD ANODIZED
A-5043 TEFLON SHOCK PISTON #60 NATURA
A-5045 TEFLON SHOCK PISTON #57 BLACK
A-5046 TEFLON SHOCK PISTON #56 RED
A-5047 TEFLON SHOCK PISTON #55 ORANGE
A-5048 TEFLON SHACK PISTON #54 BLUE
A-5050 SHOCK SPACER SET
A-5053 ".36""THREADED SHOCK BODY (SEDAN"
A-5054 ".6"" THREADED SHOCK BODY SETw/N"
A-5055 ".9"" THREADED SHOCK BODY SETw/N"
A-5056 "1.2""THREADED SHOCK BODY SETw/N"
A-5058 "SHOCK SHAFT .28"" TITANIUM PLAT"
A-5059 .36 TITANIUM SHOCK SHAFT
A-5060 "TITANIUM .6"" NITRIDE SHOCK SHA"
A-5061 "TITANIUM .9"" NITRIDE SHOCK SHA"
A-5062 "TITANIUM 1.2"" NITRIDE S/SHAFT"
A-5064 "SHOCK SHAFT 1.0"" TI-NITR."
A-5081 ".28"" TITANIUM THREADED SHOCK"
A-5100 "SPRING 1.5"" RATE 4.2 SILVER"
A-5103 "SPRING 1.5"" RATE 3.6 RED"
A-5108 "SPRING 1"" 20.0 RATE PURPLE"
A-5110 "1""SPRING 25.0 RATE BLK"
A-5115 "1"" SPRING 40.0 RATE YELLOW"
A-5117 "1.15"" SPRINGS 7.6 RATE WHITE"
A-5118 "1.15"" SPRINGS 8.6 RATE ORANGE"
A-5119 "SPRING 1.15"" YELLOW SEDAN"
A-5120 "1.15"" SPRING 10.6 RATE PINK"
A-5121 "1.15"" SPRINGS 11.6 RATE RED"
A-5123 "SPRING 1.15"" SILVER 12.6"
A-5125 "1.15""SPRINGS 14.6 RATE(BLUE)"
A-5126 "1"" SPRING 17.5 RATE (D.GREEN)"
A-5129 "SPRING 2"" RATE 2.9 ORANGE"
A-5130 "SPRING 2"" RATE 3.2 SILVER"
A-5132 "SPRING 2"" RATE 3.5 GREEN"
A-5134 "SPRING 2"" RATE 3.8 BLUE"
A-5146 "SPRING 2.75"" RATE 1.6 GREY"
A-5147 "SPRING 2.75"" RATE 1.8 WHITE"
A-5148 SPRING 2.0 RATE(YELLOW)
A-5150 "SPRING 2.5"" RATE 2.3 PINK"
A-5152 "SPRING 2.5"" RATE 2.6 RED"
A-5154 "SPRING 2.5"" RATE 2.9 ORANGE"
A-5156 "SPRING 2.5"" RATE 3.4 SILVER"
A-5158 "SPRING 2.5"" RATE 3.2 GREEN"
A-5160 SPRING 2.5 RATE 4.1 BLUE
- mytimac
- Business Member
The A6000 parts are up for Losi now.
Lot of the Ball Cups are either older grey or even older black versions.
A-6000 "BALLS STUDDED W/END 4-40*3/8"""
A-6001 "BALLS STUDDED W/END 4-40*3/16"""
A-6002 ADJUSTABLE ROD ENDS (NYLON)
A-6004 "BALLS STUDDED W/END 4-40*1/8"""
A-6005 H.D. 30 DEGREES PLASTIC ROD EN
A-6006 "STUDDED BALLS w/ENDS 4-40*1/4"""
A-6007 STUDDER BALLS w/ENDS XXX
A-6010 SHORT 30 DEG PLASTIC ROD ENDS
A-6014 BALL CUPS,LONG & SHORT,RED
A-6030 ASSEMBLY WRENCH (V2)
A-6034 "ADJ.L/R ROD SET w/ENDS 1.375"""
A-6035 ADJUST THREADED ROD ENDS 1.625
A-6038 "ADJUSTABLE THREADED L/R 2.25"""
A-6040 "ADJUSTABLE THREADED L/R 2.5"""
A-6042 4WD STEERING ROD W/BALL
A-6053 MOLDED SUSP.PIVOT BALL (10)
A-6081 TITANIUM HINGE PINS 3/32*.930
A-6082 "HINGE PINS 3/32*1.05""TI-NITR."
A-6088 "HINGE PINS 1/8*1.246""TI-NITR."
A-6089 "HINGE PINS 1/8*1.42""TI-NITR."
A-6091 "HINGE PINS,1/8*1.80""TI-NITR."
A-6093 HINGE PINS 1/8*2.04,TI-NITRIDE
A-6094 "HINGE PINS 1/8*2.125""TI-NITR"
A-6100 "E-CLIPS .125"" SMALL"
A-6101 "E-CLIPS .1875"" LARGE"
A-6102 C-CLIPS .1875 LARGE
A-6200 "SHOULDER SCREW 4-40*1/8"""
A-6201 SOCKET HEAD MOTOR 3mm*8mm
A-6202 "SOCKET HEAD 4-40*3/4"" LONG"
A-6203 "SOCKET HEAD 4-40*3/8"" LONG"
A-6204 "SOCKET HEAD 4-10*1/2"""
A-6205 "SOCKET HEAD 4-40*3/4"""
A-6206 "SOCKET HEAD 4-40*3/8"""
A-6208 "ALUM.FLAT HEAD 8-32*3/8"""
A-6209 "ALUM.FLAT HEAD 8-32*1/2"""
A-6210 "FLAT HEAD SOCKET 4-40*3/8"""
A-6211 "SOCKET HEAD (DIFF) 5-40*7/8"""
A-6212 "BUTTON HEAD 4-40*1/8"""
A-6213 "FLAT HEAD SOCKET 4-40*1/4"""
A-6214 SHOULDER SCREW 2-56
A-6215 NARROW WASHERS #4
A-6216 "SOCKET HEAD 4-40*7/8"""
A-6217 "ALUM.SOCKET HEAD 4-40*5/16"""
A-6218 "STEEL CHASSIS SCREWS 8-32*1/2"""
A-6219 ALUMINUM TRANSMISSION SCREW SE
A-6220 "FLAT HEAD SOCKET SCR.4-40*1/2"""
A-6221 "SOCKET HEAD 4-40*5/8"""
A-6223 "SOCKET HEAD 4-40*1"""
A-6224 "NYLON SCREWS,WASHERS 4-40*1/8"""
A-6225 "BUTTON HEAD 2-56*5/19"""
A-6226 FLAT HEAD 4-40*7/8
A-6227 SET SCREW 4/40
A-6228 SET SCREW 5/40
A-6229 "4-40*3/8"" BUTTONHEAD SCREWS"
A-6230 "SHIM SET 3/16"" .010,.005"
A-6232 "2-56*1/4"" SOCKET HEAD"
A-6233 "4-40*5/8"" FLAT HEAD SOCKET"
A-6234 "BUTTON HEAD 4-40 X 1/4"""
A-6235 KINGPIN/HINGE PIN SCREWS
A-6245 "4-40*5/16"" BUTTON HEAD"
A-6300 HEX NUTS 4-40
A-6301 NYLON LOCKING NUTS 4-40
A-6302 STEEL LOCKING NUTS 5-40
A-6303 NYLON LOCKING NUTS 10-32
A-6304 ALUMINUM LOCKING NUTS 10-32
A-6350 "#4 & 1/8"" HARDENED WASHERS"
A-6365 HUB BEARING SPACER & SHIM SET
A-6400 PINS, U JOINT
A-6401 PINS, WHEEL AND GEAR
A-6402 XX-4 PINS FRONT U-JOINT
A-6403 "078X5/16"" PINS FOR 4WD SHAFTS"
A-6923 XX TRANS DIFF BUSHING ONLY
A-6924 COMPLETE BUSHING SET XX/XXT
A-6950 "1/16"" CARBIDE DIFF BALLS"
A-6951 "3/32"" CARBIDE DIFF BALLS"
- mytimac
- Business Member
Some a7000 parts up today. Mannnyyy more to go for A7000 stuff.
A7201 RIBBED (H.T.)
A7201G RIBBED GOLD W/FOAM LINERS
A7202 "FRONT ""WIDE BODY"" RIBBED (HT)"
A7202G "FRONT ""WIDE BODY""RIBBED (GOLD)"
A7202S "WIDE BODY RIBBED ""SILVER"" W/FO"
A7203G FRONT DIAMOND W/FOAM GOLD
A7203S FRONT DIAMOND W/FOAM SILVER
A7204R FR XTRA-WIDE TIRES w/FOAM RED
A7204S FR XTRA-WIDE TIRES(S) w/FOAM
A7211 STAGGER RIB FRONT (HT)
A7221 FRONT SIX ROW SPIKE
A7231 FULL RADIUS RIBBED (HT)
A7231G "FULL RADIUS RIBBED ""GOLD""W/FOA"
A7297 4WD FRONT FOAM LINERS-FIRM
A7299 "BUGGY FRONT ""CLOUDS""FOAM LINER"
A7301 FOUR-ROW SPIKE (HT)
A7352 MICRO STEP PIN 2.2
A7355 STEP PIN 2.2
A7361G REAR 4-ROW GOLD W/FOAM 2.2
A7364 IFMAR STUD 2.2 (HT)
A7364G "IFMAR STUD 2.2 ""GOLD"" W/FOAM"
A7370S "IFMAR DASH 2.2 ""SILVER"" W/FOAM"
A7201 RIBBED (H.T.)
A7355 STEP PIN 2.2
- mytimac
- Business Member
Ok another update, some more A7000 and some A8000 numbers that had been in same box.
Also at the end of list Jammin tires. I have put just about all of the tires at 9.99 or lower. Think only a couple higher and one already sold out.
We now have to count rims, and if you saw video you know there is a lot of rims.
A7039 XX FRONT WHEEL DISK
A7128 "2.2""""DISK""WHEEL CAPS"
A7129 WHEEL CAPS DISCS (ASSOC.)
A7198 TRUCK DISC RIM CAPS
A7199 XXT DISC WHEEL CAPS
A7398 BUGGY REAR FOAMLINERS-FIRM
A7399 "BUGGY REAR ""CLOUDS""FOAM LINERS"
A7500G "M.T.RIBBED ""GOLD"" W/FOAM"
A7504 M.T.LOW PROFILE (HT)
A7504G "M.T.LOW PROFILE ""GOLD"" W/FOAM"
A7505R FRONT DIRECTIONAL RED W/FOAM
A7505S FRONT DIRECTIONAL SILVER W/FOAM
A7506G FRONT WEDGE W/ FOAM GOLD
A7506S FRONT WEDGE W/ FOAM SILVER
A7507R FR 8-RIB(R) w/FOAM LINERS
A7507S FR 8-RIB (S) w/FOAM LINERS
A7638G M.T.REAR IFMAR PIN GOLD W/FOAM
A7640S "REAR ""SPRINT""w/FOAM LINR-SLVR"
A7641S "TRUCK REAR ""T-2000"" SILw/FOAM"
A7699 Truck Clouds Foam liner
A7798 PROFILED/SOFT-SEDAN TIRE INSRT
A8051 STREET WEAPON DUST COVER
A8104 JRX-2 V-WING
A8105 XX WING
A8108 XX4 Maxi Wing
A8112 NXT RECEIVER COVER
A8116 BK2 Wing
A8150 "ATYPE SEDAN WING ""ALFA"""
A8151 "B TYPE SEDAN WING ""LEXUS"""
Jammin Tires
J701 MINI PIN
J701G JAMMIN'MINI PIN GOLD W/FOAM
J710G STEP PIN (GOLD)
A8104 JRX-2 V-WING
A8105 XX WING
A8108 XX4 Maxi Wing
A8116 BK2 Wing
Jammin Tires
J701 MINI PIN
- mytimac
- Business Member
Some rims added, not done yet.
A7000 FRONT SPOKE RIMS-ORANGE
A7001 FRONT SPOKE RIMS-NATURAL
A7002 FRONT Spoke RIMS-WILD RED
A7003 FRONT Spoke RIMS-Yellow
A7005 XXX WIDE FR WHEEL-WHITE
A7006 FR WIDE WHEELS SOLID BLUE XXXK
A7010 FRONT LOGO RIMS-HOT ORANGE
A7011 FRONT LOGO WHEELS-NATURAL
A7012 FRONT LOGO RIMS-WILD RED
A7013 FRONT LOGO RIMS-BRIGHT YELLOW
A7014 FRONT LOGO WHEELS NEON YELLOW
A7030 XX FRONT WHEELS W/DISC NATURAL
A7031 XX FRONT WHEELS-DISCS-NEON YEL
A7040 XX 5 SPOKE FRONT NATURAL
A7041 FRONT 5-SPOKE YELLOW
A7044 XX-4 FRONT WHEEL 5 SPOKE NATUR
A7045 XX-4 FRONT WHEEL 5 SPOKE YELLO
A7046 XX4 FRONT WHEEL w/SOLID FACE W
A7047 XX4 FRONT WHEEL w/SOLID FACE Y
A7056 FR TRUCK WHEELS,RED XXXT,NT
- mytimac
- Business Member
Forgot to keep track of latest wheels update.
But there is wheel sets (front and rear) for XX, LXT, XXT, XXX and RC10T
Also A7126 RC10 Disc rear wheels
http://sabulatech.com/storefront/index.php?id_category=35148&controller=category
Then a bunch of touring car rims.
http://sabulatech.com/storefront/index.php?id_category=34168&controller=category
A7801 5 SPOKE SEDAN WHEEL WHITE
A7802 5 SPOKE SEDAN WHEELS YELLOW
A7803 SPLIT SPOKE EXTRA OFF-SET (W)
A7805 7 SPOKE SEDAN WHEEL-WHITE
A7809 24mm MESH RACING WHEELS (4)
Going to try and get some A8000 (bodies, wings, and stickers) parts in this evening.
- 1983 Views
Last post by mytimac
- 1096 Views
Last post by amx73
- 1475 Views
Last post by MONSTER
- 55 Replies
- 6444 Views
- 732 Views
Last post by RCveteran
- 308 Views
Last post by Tang
- 1802 Views
- 26 Replies
- 4339 Views
Last post by Jared J
