At last, a TopCat for Dan!
losiXXXman
Re: At last, a TopCat for Dan!
Post by losiXXXman »
DennisM wrote:That paint job embraces my idea of a TopCat. Long slim front - low and fast.
The partitions at the back takes away the "wide" from the rear end, which in my opinion is a good thing.
In regards to what Dennis says, how ultra sleek would a top at look with a Cougar2 shell ? :idea: 8)
Oh, and uh, nice paint Dan. Can you say mirrored chassis ? :D
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
Quick pic!
Will take some proper pictures in the daylight which will hopefully show the colours & detail better, I hate this time of the year.. its only at the weekend that I get the chance to see my house in the daylight! :|
Still got a few little bits/issues to resolve on this TopCat before I can say that it is 'finished' - despite the same oil (& pistons) in both front & rear shocks (30wt), the front is really soft & springy - whilst the rear is way over damped! - There is also still a slight leak from each shock cap, which i'll have to look into (new Diaphrams perhaps?) The black allen head screws in the front wheels need replacing for original spec bright BZP (silver) screws - & I need to dissmantle the L/H front hub as there is a knocking (I think the 'pimples' on the back of the plastic axle need shaving down a bit)
CAT3K
Post by CAT3K »
I like the paint Dan, much better than I can do :)
The front damping on Topcats is a pain, a bit like Predators used to be. You used to have to use a much thicker oil on a laydown suspension, than a normal setup.
As for the caps, I always give the cap threads a coat of AE green slime (even on my new buggies) just for this issue.
DerbyDan
Post by DerbyDan »
CAT3K wrote:I like the paint Dan, much better than I can do :)
I dissagree - I love the paint job on the Cougar in your avatar 8)
Yes i'm going to try perhaps 40-45 wt in the front & perhaps 20wt in the rear? Its all academic as the car is unlikely to ever run - but I do like my shelfers to 'feel' right when you do the obligitory suspension 'push' when admiring a model :wink: I have actually smeared green slime around the lip of the diaphrams... but will try it on the threads also when I do the oil :D
The decals/stickers that I brought were a little dissapointing - firstly they are almost transparent so when applied to the dark areas of the bodyshell the colours of the decals are lost (but this also seems to be the case when you look closely on Luke's image of Phil Davies' car with the side decals) Also it would appear that being so old, the decals were very difficult to peel off from their backing paper & in some cases the paper came away with the sticker - which is most evident on the large Schumacher decal on the R/H side - I managed to get rid of most of the paper (rubbed with thumb with decal submerged in soapy warm water) but there is still some white residue :|
DerbyDan
Post by DerbyDan »
Some better pictures for your viewing pleasure :D
So clean, you could eat off of it! Very nice job. 8)
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
I'm enjoying seeing such a nice example if a Top Cat up here. Really nice job.
-Jason.
Still known as- bormac
CAT3K
Post by CAT3K »
It's amazing how much better they do look in the sunlight. The blue looks a completely different shade, but in a good way :)
Paul.
urpaldan
Post by urpaldan »
Cor, that's really lovely Dan. Top marks for a TopCat! 8)
Return to “Schumacher Forum”
