RC10 assemebly . What do you hate the most ?
- Kayne
Re: RC10 assemebly . What do you hate the most ?
trimming bodies is probably the worst for me. I don't mind building shocks, it's the bleeding that sucks.I usually have one shock that will not cooperate,end up being firmer than the rest.
Matt
Drive It Like You Stole It!
- slotcarrod
- Been thanked: 45 times
Get to work Pit Bitch! You don't have time to type on here!vintage AE wrote:Nothing bothers Rod about building rides, I do it for him. So, the thing I hate the most for Rod is cleaning his pile of crap and rebuilding his damn shocks![]()
Bending wing wire sucks ass too!
Hey! You have only built a few for me!
Rod Littau
- SRTracer121
oooh, forgot about bending wing wire. the act itself is easy enough if you have atleast 4 fingers but for the life of me it never comes out right no matter what i do.
like sunday, i was rigging up a wing on my traxxas fiero directly to the rear pod and even though the wire seems strait and bent correctly it is both unlevel once mounted and one side is further back then the other.
watching me bleed shocks is funny too. was bleading a set of 1/8th shocks a few days before the wing bending and i pulled down to quick trying to get the air out from behind the piston (had a down stop in it), shot 15wt oil right in my eye
then once i washed out my eye and jumped back in on the other shock, well, lets just say i went to bed with one hell of a bloodshot eye.
wasnt even a good oil choice so i wound up going up to 30wt at the track. *facepalm*
- Brandon G
This is probably a repeat of what has already been mentioned, but...
1. Turnbuckles
2. Installing axle roll pins
3. Trimming the body for rear shock clearance
4. That damn e clip that goes on outside of the gearbox on the spur gear shaft opposite of the diff.
1. Turnbuckles
- THEYTOOKMYTHUMB
- Has thanked: 3709 times
- Been thanked: 1980 times
Ever stop to think how many Associated e clips have been lost over the years?? Has to be in the millions! Most after being shot across the room because you thought it was all the way on...Brandon G wrote:damn e clip
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
That flippin large e clip on the 6 gear tans is a pain in the a$$ most times, I'm with ya on that
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
This is why they're also referred to as Jesus clips. Mainly because you're apt to yell "Jesus Christ!" when they go flying.THEYTOOKMYTHUMB wrote:Ever stop to think how many Associated e clips have been lost over the years?? Has to be in the millions! Most after being shot across the room because you thought it was all the way on...Brandon G wrote:damn e clip
- arf
- Been thanked: 7 times
Does this count?
- Attachments
- File%20time%20to%20post.jpg (61.26 KiB) Viewed 1056 times
- slotcarrod
Yea! Battery slots are a BIOTCH!
Rod Littau
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
you're kiddin' right???Lowgear wrote:Why is that done? I never remember anyone doing that in the 90's when I raced pan cars.
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
I remember guys with 10l fiberglass cars not doing it, but with the graphite being a decent conductor and sharp edges it would destroy battery shrink wrap in 1-2 runsLowgear wrote:Why is that done? I never remember anyone doing that in the 90's when I raced pan cars.
- THEYTOOKMYTHUMB
I forgot about that too. That was a PITA!
I thought it was so that the cells sat further in to lower the c/g. Although I guess it would definitely save the shrink wrap too.
- Lowgear
Ah I see, that makes sense. I'm lucky I never had that problem. Maybe because my packs were always held together with glass tape and prayers.
An RC10L is the only R/C with a graphite chassis, and battery slots I've ever run which is why I wasn't aware of the need to do that.
- 2247 Views
Last post by treehugger
- 1037 Views
Last post by clm
- 19 Replies
- 2228 Views
Last post by fastang
- 1603 Views
Last post by klavy69
- 1005 Views
Last post by slotcarrod
- 966 Views
Last post by Mr. ED
- 789 Views
Last post by DMAT
- 860 Views
Last post by Cronus
TravelinTravis and 6 guests
