- COMCOM'ed '93 Works (Fibre-Lyte background history page 4)
- GJW
Re: - COMCOM'ed '93 Works (Fybre-Lite background history pag
it's really come together david your tower's are different to mine, your rear is 94. the rear belt is correct for 93 works with pirelli written in blue great build man!
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
Thank you for the compliment Nope, the only one they still make is the RC10 tub and you would have to drill the holes in the front kick up plate by yourself: http://www.fibre-lyte.co.uk/Scott S. wrote:Are they still making those Chassis and Tower ? That is an Awesome build.
Come and visit the stable
- Been thanked: 11 times
Re: - COMCOM'ed '93 Works -
I can't believe that.
Asso_man! wrote:Nothing special at all, just elbow grease...LTO_Dave wrote:What the heck did you use to clean that diff pulley? It looks new!
... and this:
At first I spray the diff pulley with WD40, let it soak a few minutes, then brush it with a toothbrush, rince with hot water, then a second run of WD40/toothbrush and lastly rince with hot water, add a dab of dishwash soap, brush and rince, you're done!
The metal parts get treated the same way except I obviously don't use water and soap. First step is to spray them with WD40, let them soak a bit, then I use a steelwool pad to gently scrub them (it prevents to remove material at critical locations), the outdrives are gently polished with a 1000 grit sandpaper sponge (see pic above). Last step is to clean and dry everything with a cloth.
I've done the other diff today using this very method, here is the result (thumb pics are clickable):
Before: After:
Rebuilt diff:
Now the transmission is done, took me a good three hours to get this (thank God the kids still do a nap ):
- minimini
- Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
- Been thanked: 9 times
Re: - COMCOM'ed '93 Works (Fibre-Lyte background history pag
the oblique twill weave pattern of the tub & upper deck are not at the same direction.......this occurred in my Lazer ZXR carbon tub too......
- stickboy007
- Been thanked: 17 times
This is my sentiment:
[youtube]aHrzzdr0J_M[/youtube]
Reason: fixed youtube link
Even though u am six months too late....Great job on the car! Very impressed with your work! How did you get the motor mount so schmick? Probably the best example i have seen so far! I have been using a dremel to get similiar results...havent tried to polish it as yet . Would be cery interested to know how you got it so nice!
- Asso_man!
Hey thanks for the compliment on the car! The motor mount was cleaned with elbow grease and a metal cleaning product called 'Sidol' and meant to clean copper and other metals. Nothing really special, you need patience and care above all...flustorm99 wrote:Even though u am six months too late....Great job on the car! Very impressed with your work! How did you get the motor mount so schmick? Probably the best example i have seen so far! I have been using a dremel to get similiar results...havent tried to polish it as yet . Would be cery interested to know how you got it so nice!
Well its the best job i have seen on a motor mount! Looks brand new! Thanks for the info.
- Asso_man!
Plan for the weekend is to bend music wire, cut some double side tape to form and adapt the below Fibre-Lyte aerofoil wing to the old dog. It came with a full Traxxas Rad2 in poor shape I acquired directly from them a few years back but thought it would better fit da dawg. Again lots of craftmanship into it. Wing buttons had to be filed and inserted carefully inside the wing through the lateral holes in a surgical manner.
Man thats one cool wing! Must of taken a while to get those wing buttons in there!
Damn nice.. that looks great.. that will really set it off.. very nice..
Shawn
Shawn
- Been thanked: 5 times
Hello,
I followed your COMCOM discussion with great interest - here are some supplement photos.
On the package can be seen, this chassis was manufactured in Great Britain by FIBRE- LYTE and sold by COMCOM.
Sorry for my bad English.
Thought this the best place to ask, but, didnt Chris Grainger use a tub carbon chassis in the BRCA touring rounds, on a YZ10, not a Works car!
Wish i stil had my okd RRCI's to check, but id love to have a custom made for the 94 car!
Lee
Lee
- Asso_man!
Some small progress on the yet old carbon dog that received its new wing wire, side dams as found in the original box from Hansell Composites, and a wing eventually. I still have some holes to drill in the bulkhead caps to mount the top deck, finish the rear stab bar, properly set the electronics and find a body. The pair of front copper springs it had are now on my 91 Stealth until I find another one of them Pictures reflect the type of wheather, daylight and mood we experience in this season in Central Europe.
- 81 Replies
- 13804 Views
Last post by Welshy40
- 1092 Views
Last post by minichamps11
- 1114 Views
Last post by Jirka
- 610 Views
- 1092 Views
Last post by fakiee
- 30 Replies
- 4199 Views
Last post by mamadoesntletme
- 898 Views
Last post by john73
- 924 Views
Last post by Richieflax
