$20 ebay beater + homemade 4wd kit
- templeofspeed
Re: $20 ebay beater + homemade 4wd kit
Ed, have a look here:
https://sdp-si.com/eStore/Direct.asp?GroupID=169
sprockets are listed in the LH column...
- Dr. Robotnik
I had a look but they aren't metric...
I am confuzzled...how will I measure;
Pitch Circular & Dp?
- templeofspeed
There is a toggle for metric on the top of the left column...
- Dr. Robotnik
Pah! Gah! Nah! Thanks again. I am going back in.templeofspeed wrote:There is a toggle for metric on the top of the left column...
- Has thanked: 29 times
- Been thanked: 66 times
okay I gotcha, CONRAD's page is really set up weird.
Check THIS out.
You need pages 343 and 344. With their chains, you need module 1 gears. Steel might be a bit heavy, but it should work.
Check THIS out.
*** POWDER - KING ***
- Dr. Robotnik
I might be mildly retarded but I can only see gears but not chain gears on those pages and a lot of them have modul 1 written next to them.Chewbacca wrote:okay I gotcha, CONRAD's page is really set up weird.
Check THIS out.
supposedly their chain works directly with the module 1 gears it's in the text for the chain...
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Hey ed,
you could also step down the ration in 2 steps: small gear on the topshaft of the MIP, bigger gear on the outside of your rear construction, smaller gear on the inside of your rear construction and larger pulley upfront. This way your front pulley doesn't have to be twice the size.
anyone know what size a kyosho chain is? Ive been looking for some couple of chains as Im a few short. This might be a cheaper and easier solution
- 2033 Views
Last post by Dr. Robotnik
- 28 Replies
- 3411 Views
- 817 Views
Last post by Asso_man!
- 106 Replies
- 11985 Views
Last post by Mr. ED
- 1588 Views
Last post by clodsrule
- 35 Replies
- 5194 Views
Last post by AscotConversion
- 787 Views
Last post by a01butal
- 24 Replies
- 2654 Views
Last post by Bormac
Users browsing this forum: Google Adsense [Bot] and 36 guests
