- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Idk man looking more closely at mine now they sure do look a little wonky
Hey Cru ! Go balls out
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2980 times
It's interesting that both pair look to be for the same standard size servo, not a standard size and a smaller servo like an S132.
- MarkyDents
His chassis the holes look like they are way closer to the center line of the chassis as well. Looks like mine has the antenna mount hole in the same spot.
- Frankentruck
It's hard to tell for sure how close to center the servo holes in his are since the servo blocks have the holes offset. They might line up well with one pair of holes in yours.
- MarkyDents
Idk if the pic is exaggerating it but the servo sure does look crooked in this top shot
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
I've been after a pack of these for quite awhile.
- Has thanked: 1129 times
- Been thanked: 3919 times
I was actually thinking about another run of those with the stealth trans being back now. They would be changed up from originals of course though.
- R6cowboy
- Has thanked: 872 times
- Been thanked: 903 times
When you find a "like new" Reedy RT1408 low profile servo with ProTek horn for 39% of new cost, you don't say no.
-Jerry-
- morrisey0
- Has thanked: 87 times
- Been thanked: 1853 times
I got in a bunch of yellow zinc plated hardware for my RC150, which is cool and all, but really wanted to throw a shout out to the supplier. https://www.aircraftspruce.com/ Their fastener selection is EXTENSIVE, great prices, and everything I ordered was in stock and shipped the next day. As far as I could see there were no minimums, so you could go there and find a single $.17 screw, and order it. All parts individually packed, and numbered on the description tag was the exact quantity. They are in PA, so super quick shipping to the east coast.
All of the hardware below (ignore the dog awful McMaster threaded rod which is probably going back) was just under $15 + s&h. That is 70 fastener pieces for $14.52
EDIT: I should note, their inventory is mostly/all IP. Sorry about that.
Double edit. I will make this a two-for. I emailed McMaster about not liking the threaded rod at all, and their immediate response was for me to keep it and they would refund in full. I am assuming I am out the shipping, but either way, that is great customer service!!!
- Frankentruck
If I'd ever had a Speed Gems Pro Chromium back in the day, then I'd have to wonder how you got that motor from my collection. I used to do a lot of sweet solder jobs like that.
I've been on the hunt for a particular Schumacher motor. This wasn't the one I'm after but I couldn't pass it up.
- Has thanked: 1783 times
- Been thanked: 860 times
You gonna put that in the pink Top Cat!?!Frankentruck wrote: ↑Thu Sep 26, 2024 10:13 amIf I'd ever had a Speed Gems Pro Chromium back in the day, then I'd have to wonder how you got that motor from my collection. I used to do a lot of sweet solder jobs like that.![]()
- Frankentruck
The pink TC is definitely a thought I've been considering.1911Colt wrote: ↑Thu Sep 26, 2024 12:37 pmYou gonna put that in the pink Top Cat!?!Frankentruck wrote: ↑Thu Sep 26, 2024 10:13 amIf I'd ever had a Speed Gems Pro Chromium back in the day, then I'd have to wonder how you got that motor from my collection. I used to do a lot of sweet solder jobs like that.![]()
1000014875.jpgSeems like the logical place to store it...
....but the pink Trinity in there is a pretty bad @$$ motor.
- 6238 Views
- 6693 Views
Last post by ireg
- 1570 Replies
- 178369 Views
Last post by ZED32
- 5572 Views
Last post by Dr. Robotnik
- 6475 Views
Last post by Synergy
- 20 Replies
- 10396 Views
Last post by cas22
- 4317 Views
Last post by ca-rj
- 1716 Views
Last post by CUDDZILLA
