- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
the bottom half looks traxxas cat like. I know those are traxxas cat wheels anyway. Top half/rollcage is something I've seen before but can't place a name on it. Someone will come thru though...
- Has thanked: 43 times
- Been thanked: 56 times
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
- nvxwax
I second the Bison F10, It looks to be missing the body that goes over the cageJ.M. wrote:Simon I am quite certain it is a BISON F10.
- 3trxvintage
I did not know there was an official thread for this until today.
I was able to get these cvds from a parts box at LHS and have no clue where they are from. I have searched everywhere on the internet and have had no luck
-My guess is they are not MIP because the outdrive cup is chrome.
-They are 2 ¾ inches long and use a 4mm locknut at the end.
-They fit perfectly on a nitro 4 tec. (But were not made for this car).
Has anyone ever seen these before? Or know what kit they belong too? Any help would be great. Thanks
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
The drive train of that Nikko is a copy of the grasshopper. It uses nylon bushings which can be replaced by ballbearings (did that for a friend ages ago)
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
As I said in the other thread, based on the diff outdrive and CVD length, I guess they are for a Kyosho Spider (Pure Ten).3trxvintage wrote:I did not know there was an official thread for this until today.
I was able to get these cvds from a parts box at LHS and have no clue where they are from. I have searched everywhere on the internet and have had no luck![]()
Based on the glossy finish, they could be from Kose or Cross, except that neither has made CVD-style axles for the Pure Ten Spider cars to my knowledge (only regular universals).
- slapshot1979
tsan wrote:Somebody on another site I frequent has posted this car, looking for an ID... any ideas? I'm just curious.
Definatley a nikko product I have the rhino here in basement. the chassis's are identica,l cage is black, but wing and body are white with green red strips on the rhino
That one is missing body piece. I'm 99% sure its a bison
- 3trxvintage
I did a little research and found the pure ten uses black cvds. They also use a different connection style from the cvd bone to the axle. Cross also uses this connection style. I will admit these cvds have been the hardest thing to identify everEvolutionRevolution wrote:As I said in the other thread, based on the diff outdrive and CVD length, I guess they are for a Kyosho Spider (Pure Ten).3trxvintage wrote:I did not know there was an official thread for this until today.
The black CVDs are Kyosho's stock units. Kyosho also has a slightly different length that are a flat silver color. Aftermarket units - which these likely are - don't need to be the same color or style.3trxvintage wrote:I did a little research and found the pure ten uses black cvds. They also use a different connection style from the cvd bone to the axle. Cross also uses this connection style. I will admit these cvds have been the hardest thing to identify everEvolutionRevolution wrote:As I said in the other thread, based on the diff outdrive and CVD length, I guess they are for a Kyosho Spider (Pure Ten).3trxvintage wrote:I did not know there was an official thread for this until today.
I'm pretty sure that the CVDs you're trying to identify are for a Kyosho car, because the diff outdrive cup shown (with the setscrew) is a design typically used by Kyosho for their gear diffs.
- Mr. ED
And may other brands wih geardiffsI'm pretty sure that the CVDs you're trying to identify are for a Kyosho car, because the diff outdrive cup shown (with the setscrew) is a design typically used by Kyosho for their gear diffs.
- Been thanked: 325 times
Those chrome outdrives are a Duratrax part number; they're originally for a Duratrax Maximum ST/BX. They happen to be perfect swaps for the Kyosho cars but I don't think they were intentionally made for Kyoshos. Maybe the CVDs are also made for a Duratrax?EvolutionRevolution wrote:I'm pretty sure that the CVDs you're trying to identify are for a Kyosho car, because the diff outdrive cup shown (with the setscrew) is a design typically used by Kyosho for their gear diffs.
- 3trxvintage
I agree the outdrive cups I have do look like the duratrax outdrive cups. I have provided a picture for reference. As far as the cvds go the only thing I could find that looks remotely close to the cvds I have are the duratrax cvds for the evader (see picture they are too long).Coelacanth wrote:Those chrome outdrives are a Duratrax part number; they're originally for a Duratrax Maximum ST/BX. They happen to be perfect swaps for the Kyosho cars but I don't think they were intentionally made for Kyoshos. Maybe the CVDs are also made for a Duratrax?EvolutionRevolution wrote:I'm pretty sure that the CVDs you're trying to identify are for a Kyosho car, because the diff outdrive cup shown (with the setscrew) is a design typically used by Kyosho for their gear diffs.
Duratrax never made cvds as short as the ones I have (I think
Thanks for the help guys. I will search around a little bit more for Kyosho cvds. If anyone can locate a pair of these let me know.
- Attachments
- DuraTrax Joint Maximum ST/BX (2)
- dtxc8100.jpg (17.34 KiB) Viewed 1746 times
- Hcp22
- Has thanked: 33 times
- Been thanked: 22 times
Can anyone identify this 2 body’s and to witch cat they fit?
- Attachments
- Body 2.jpg (13.47 KiB) Viewed 1738 times
- proffesso
ayk buffalo no?
any yokomo folks know what model this is? 91?
http://page11.auctions.yahoo.co.jp/jp/auction/n104398026
I'm a retro radio control hipster - I only like the stuff no one bought!
- 59 Replies
- 16070 Views
Last post by Diamond Dave
- 106 Replies
- 27094 Views
Last post by mikesofunny
- 431 Replies
- 54589 Views
Last post by Eccentric
- 67 Replies
- 16817 Views
Last post by bearrickster
- 321 Replies
- 41997 Views
Last post by tazz888
- 448 Replies
- 50194 Views
Last post by MelvinsArmy
- 351 Replies
- 47575 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
