- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
I think the solder tabs definitely need to be used. I think using the endbell screws would just result in a short circuit of the ESC across the sync ring that the screws go into.
- Has thanked: 92 times
- Been thanked: 72 times
Definitely...but I have no idea why they would have marked it that way, it's not helpful.Frankentruck wrote: ↑Tue Jun 06, 2023 5:44 pm I think the solder tabs definitely need to be used. I think using the endbell screws would just result in a short circuit of the ESC across the sync ring that the screws go into.
- Frankentruck
I agree, I don't see any value in these markings. They make no sense to me.
- Frankentruck
It looks like I'll have to find a pinion gear to use a replacement motor. The pinion is pressed on. No set screw or flat spot on the armature.
Heat it up with a torch and it might expand enough to pull it off. Then overdrill it to slide on a motor shaft (1/8"?) then drill and tap threads for a set screw. That's what I would try, unless those are something common like Mod. 1 pitch or something.Frankentruck wrote: ↑Tue Jun 06, 2023 6:21 pm It looks like I'll have to find a pinion gear to use a replacement motor. The pinion is pressed on. No set screw or flat spot on the armature.
- Frankentruck
I have a puller that might take it off, but I'm going to think about that for a while.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Idk looks like a really good excuse to buy a mini induction tool to me
Hey Cru ! Go balls out
Can't argue with that!MarkyDents wrote: ↑Tue Jun 06, 2023 8:16 pm Idk looks like a really good excuse to buy a mini induction tool to me![]()
- Regular Member
- Been thanked: 4 times
Replacement/Upgrade parts for Kyosho Spada 09 and front wheels for NDS project
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Yeah, you don't have my postal address
- Has thanked: 665 times
- Been thanked: 473 times
I probably do somewhere and I know you have mine so I better be careful
- vonBraun
- Has thanked: 41 times
- Been thanked: 69 times
Really got a streak of luck at the moment.
But also means I’m blowing all my budget and there is no progress with the projects.
Really couldn’t pass this never run RC10GT Factory Team Edition. Only bummer are the faded turnbuckles. They turned dark gray for some reason. Can’t complain about it though. Super happy about this find
I like trucks and I cannot lie
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Love the lil' bluevonBraun wrote: ↑Wed Jun 07, 2023 2:03 pm Really got a streak of luck at the moment.![]()
Really couldn’t pass this never run RC10GT Factory Team Edition. Only bummer are the faded turnbuckles. They turned dark gray for some reason. Can’t complain about it though. Super happy about this find![]()
Killer score
- 6238 Views
- 6693 Views
Last post by ireg
- 1569 Replies
- 178000 Views
Last post by Frankentruck
- 5572 Views
Last post by Dr. Robotnik
- 6474 Views
Last post by Synergy
- 20 Replies
- 10396 Views
Last post by cas22
- 4317 Views
Last post by ca-rj
- 1716 Views
Last post by CUDDZILLA
