GJW
Post by GJW »
I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.
I would really like to find some of these in the appropriate length; we used them back in the early 90's on some custom built loose dirt oval cars - they were smooth beyond ANYTHING produced in that era - with aluminum shock pistons![/quote]
Let me know what length you need... I will disassemble and determine if the extra unknown pistons are for these shocks.[/quote]
The shocks are 80mm extended front and 94mm extended rear - it is a single shock front end and I believe that the Delta Desert conversion possibly used 2 shocks up front - not 100% sure on that....
In the line of different and unusual, I received this body from a fellow in Japan many years ago; it was what they called a 'space shuttle' body for the 834 B if my memory serves me correctly. He indicated that it had been run in a worlds - don't remember if he said which one or not but I thought I'd give the knowledge base here a shot!
The body is in decent shape - it's a pearl color and was lined on the inside with what appears to be race numbers for cars. Has a crack behind the rear, upper pin hole for mounting. AND, an interesting factoid is that the windows are black paint - rather than clear or tint. Interesting...[/quote]
the body is a bolink
GJW
Post by GJW »
how about this part?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
A moterspacer with provision to add a cooling fin. If litespeed made a universal unit this would be a good candidate.
GJW
Post by GJW »
thanks ed, what car would it suit with heatsink attached?
Mr. ED
Post by Mr. ED »
it would be rather universal but some models would no twork with regards to moterprotection etc being in the same spot
knucklebuster
Post by knucklebuster »
GJW wrote:I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.
Thanks for the info.
mikedealer
Post by mikedealer »
any ideas? i recognize the tires as AJ's
mikedealer wrote:any ideas? i recognize the tires as AJ's
Weird, I've never seen a transversely-mounted, angled gear arrangement like that before! I'm trying to figure out how you mount a motor to that?
mikedealer
the motor mounts appear to be angled same as spur, weird design.
tomolupus
Post by tomolupus »
mikedealer
there is one on ebay for $50 not listed right, wonder if i should get it, as you can see from pics it needs work and has no motor.
JOESGARAGE
Post by JOESGARAGE »
WHAT ARE THESE?
OLD SCHOOL!
crusaderlyf
Post by crusaderlyf »
the second pic is kyosho scropion tomahawk etc circuit 1000 series arm
the last two pics are graphic shock tower set for yokomo 870C
mikedealer
First pics are the 3 body parts for a kyosho javelin, the roof, roll cage support, and front plate.
JOESGARAGE
You guys are good! picture #3 anyone?
OLD SCHOOL!
Return to “Identifications”
