Bored? Come To The Chit / Chat Thread
Brendan2904
Has thanked: 222 times
Been thanked: 220 times
Re: Bored? Come To The Chit / Chat Thread
Post by Brendan2904 »
Lowgear wrote: Fri Jan 10, 2025 1:00 am Everyone is absolutely right. :)
As it pertains to ClodTalk, it used to be it's own separate forum but went dormant many years ago. Plus something like 80% of images in posts no longer worked any longer either. It became a major waste of time and resources to continue maintaining it for no real reason, so the decision was made to close it down for good, and incorporate the domain name into the board here. This way it would alleviate the problem, while allowing ClodTalk to continue on in at least some capacity. :)
As a dedicated Tamiya collector from the 80’s to today I can definitely appreciate this!
morrisey0
Has thanked: 74 times
Been thanked: 1735 times
Post by morrisey0 »
I started looking through the box of my Kyosho WaveChopper, and found the speed controller. Due to it's age, I am not sure if it works so I looked up and found a wiring diagram in case I needed to troubleshoot it in the future. I may use the same type on my dragster in the near future, so it may help there also. I thought I would post it here in case it could help anyone else in the future.
:D
MarkyDents
Has thanked: 1778 times
Been thanked: 637 times
Post by MarkyDents »
I think that’s how the long skinny pedal in my full size truck works as well 8)
Hey Cru ! Go balls out 8)
TRX-1-3
Has thanked: 1930 times
Been thanked: 939 times
Post by TRX-1-3 »
Anybody know if the RCD/Hitec Shredder receiver housing is lexan or hard clear plastic? (Not the storage/display case).
Has thanked: 1670 times
Been thanked: 1115 times
TRX-1-3 wrote: Sun Jan 19, 2025 6:28 pm Anybody know if the RCD/Hitec Shredder receiver housing is lexan or hard clear plastic? (Not the storage/display case).
My couple appear to be hard plastic, from memory.... will grab them out tonight and confirm, if someone else doesn't beat me to it.
TRX-1-3
Post by TRX-1-3 »
Incredible_Serious wrote: Sun Jan 19, 2025 6:30 pm
That's enough for me. Thank you. No need to go digging. The more I look at the pictures I've found, here and elsewhere, it appears that the case is near Identical to the Dynamite Micro Pro, which is red hard plastic. The relief/contour/case detail has crisp sharp lines. Hard to achieve that with lexan.
Has thanked: 2469 times
Been thanked: 2775 times
They are a tinted gray clear hard plastic.
Has thanked: 263 times
Been thanked: 2003 times
TRX-1-3 wrote: Sun Jan 19, 2025 7:34 pm The more I look at the pictures I've found, here and elsewhere, it appears that the case is near Identical to the Dynamite Micro Pro, which is red hard plastic.
I have several of both. Other than the color and decals, they are identical.
Brendan2904
Ok so I might not have the terminology correct but here goes.
In my understanding if you connect 2 2s batteries together you get a 4s power supply. So this would be a parallel connection right? Is there a way to connect 2 2s batteries together so that they remain 2s batteries ( in series) and don’t double to 4s?
Am I crazy?
Brendan2904
Maybe I have parallel and series mixed up?
Brendan2904 wrote: Thu Jan 30, 2025 9:20 pm Ok so I might not have the terminology correct but here goes.
Am I crazy?
Two 2S batteries in series gives you a 4S pack.
Two 2S batteries in parallel gives you a 2S pack with double capacity.
Halgar
Has thanked: 135 times
Been thanked: 172 times
Post by Halgar »
Series = in line ( + to -, + to -) = double battery power, no increase in capacity. This is how all battery packs are assembled to get the battery to it's target voltage/amperage for its application. Smaller cells can discharge their energy faster than one large cell, they also charge faster.
Parallel = side by side ( + to +, - to - ) = same battery power, double capacity. Think of this as having two buckets, each bucket holds the same amount, but you can carry twice as much.
Brendan2904
Halgar wrote: Fri Jan 31, 2025 10:16 am Series = in line ( + to -, + to -) = double battery power, no increase in capacity. This is how all battery packs are assembled to get the battery to it's target voltage/amperage for its application. Smaller cells can discharge their energy faster than one large cell, they also charge faster.
Incredible_Serious wrote: Thu Jan 30, 2025 11:04 pm
Am I crazy?
Thank you very much. I am just trying to figure out how to run 2 shorty 2s batteries in one of my trucks and not make it 4s but keep it 2 s and increase the capacity. I am going to make a parallel adapter or just buy one and see how it works.
Dangeruss
Has thanked: 357 times
Been thanked: 1161 times
Post by Dangeruss »
The more important question... which hurts more when you stick your tongue to it... :mrgreen:
Halgar
Post by Halgar »
Brendan2904 wrote: Fri Jan 31, 2025 11:00 am
Something to keep in mind when doing this is that you need two identical batteries. Do Not use different sized cells or capacity batteries, unless you like smoke and flames. :? :mrgreen:
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot] and 10 guests
