knucklebuster wrote:???
Well, I guess I've stumped the crowd on the axles... added the threaded shocks. Andy ideas??? Thanks in advance.
- Been thanked: 4 times
Yes USA1 wrong wheels.Should have a 90s model chevy body on it.DON
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
More specifically a USA-1 with Big Brute tires/rims on it.scr8p wrote:i think it's actually the electric USA-1.
I just saw it on eBay and they aren't rare at all and generally go for around a hundred complete and in good condition.
It's a kyosho double dare it used the same chassis as the USA-1
- highwayracer
- Been thanked: 6 times
yup...usa 1 with big brute wheels and tires.
The double dare shared the same suspension as the big brute, big boss and hi rider vette. The usa 1 had different suspension components to compensate for the larger / wider tires.
I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.knucklebuster wrote:knucklebuster wrote:???
I would really like to find some of these in the appropriate length; we used them back in the early 90's on some custom built loose dirt oval cars - they were smooth beyond ANYTHING produced in that era - with aluminum shock pistons!
Wherever you go; there you are!
- old_rc_lover
No ideas on this old dog????old_rc_lover wrote:Hoping one of you guys know what this is. I got this from a local hobby shop. Was a gift from owner. I was told that this was made from a kit. You got a bunch of tubing and instructions on lengths. It has a .19 engine in it. does have suspension in front. If you can call 2 little springs suspension..![]()
Let me know what length you need... I will disassemble and determine if the extra unknown pistons are for these shocks.Chris K wrote:I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.knucklebuster wrote:knucklebuster wrote:???
Let me know what length you need... I will disassemble and determine if the extra unknown pistons are for these shocks.[/quote]Chris K wrote:I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.knucklebuster wrote:knucklebuster wrote:???
The shocks are 80mm extended front and 94mm extended rear - it is a single shock front end and I believe that the Delta Desert conversion possibly used 2 shocks up front - not 100% sure on that....
In the line of different and unusual, I received this body from a fellow in Japan many years ago; it was what they called a 'space shuttle' body for the 834 B if my memory serves me correctly. He indicated that it had been run in a worlds - don't remember if he said which one or not but I thought I'd give the knowledge base here a shot!
The body is in decent shape - it's a pearl color and was lined on the inside with what appears to be race numbers for cars. Has a crack behind the rear, upper pin hole for mounting. AND, an interesting factoid is that the windows are black paint - rather than clear or tint. Interesting...
- mikedealer
im pretty that body is just a parma or mcallister body, i forget, have same one at home, i think mrlexan even pulled some of those a while back
- mikedealer
scorpion/advance/tomahawk/assault front arm mount, crp still sells em on ebay
I would really like to find some of these in the appropriate length; we used them back in the early 90's on some custom built loose dirt oval cars - they were smooth beyond ANYTHING produced in that era - with aluminum shock pistons![/quote]
[/quote]
Thanks Chris... I just saw a new in package Cook's Racing shock that looks very similar on epay.
[/quote]
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
On the lower left you have a trickbits motor spacer. It's designed to keep a free airflow to the venting holes in a brushed motor case.Bimdapogs wrote:I have a few here:
9. No idea on these:
Thanks in advance for any input.
[/quote]knucklebuster wrote:I believe those are Delta shocks - the large diameter model originally built for the Yokomo 834B conversion they made.
Thanks Chris... I just saw a new in package Cook's Racing shock that looks very similar on epay.[/quote]
Yeah, those are nice BUT not $100.00 pr nice.... I'm sure most know but Cook Racing re-packaged a lot of Delta stuff and did their own version of the (I believe) Super Eagle.
At any rate, I'm not in any hurry - I've had both of my 834s for years so I'm not going to get nervous now! As many have said, a lot of the fun is in the hunt!
- 59 Replies
- 16058 Views
Last post by Diamond Dave
- 106 Replies
- 27089 Views
Last post by mikesofunny
- 431 Replies
- 54438 Views
Last post by Eccentric
- 67 Replies
- 16812 Views
Last post by bearrickster
- 321 Replies
- 41876 Views
Last post by tazz888
- 448 Replies
- 49984 Views
Last post by MelvinsArmy
- 351 Replies
- 47449 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
