SC10
- mrlexan
- Been thanked: 12 times
Re: SC10
I am only partially back...... work is keeping most of my attention hostage these days. I am slowly trying to get back into the swing of things.
www.gojammedia.com
www.gojammedia.com
- call-911
Re: SC10
Prices popping up on web sites for pre-orders is between $189-250, but I'm guessing closer to $189 since Tower was the $250 and they always jack up the price before release.
Keith C
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: SC10
I found this on A Main Hobbies also measured against my Slash and it's very close.
CLEAR body included. Must be painted.
Based on a lengthened version of the 6-time National Champion RC10T4 platform
Realistic short course racing truck .040” polycarbonate body
Chassis side nerf bars
Trick KMC™ style wheels and aggressive tread multi-terrain scale tires with re-enforced sidewalls
Realistic bumpers front and rear for maximum durability
Rubber AE logo mud flaps
2.6:1 ratio gearbox equipped with sealed gear differential
Two spur gears included: 75 tooth for brushless stock and 87 tooth for brushed and modified motors
Efficient dual-sided, externally adjustable slipper clutch
Molded composite low-CG chassis
Hinged battery hold-down strap fits up to 8-cell battery pack
Set-screw secured antenna tube
Durable front and rear body mounts
14 rubber-sealed ball bearings
Rugged steel turnbuckles for quick and easy suspension adjustments
Fully adjustable suspension geometry
Angled bellcrank “coplanar” steering with integral servo saver
Vertical ball end roll-center adjustments front and rear
Blue aluminum shock bodies
Steel dogbone rear axles
Many Factory Team and Reedy option parts already available!
Specifications:
Scale: 1:10
Power : Electric
Length: 550mm
Width: 293mm
Track: 245mm
Weight: 2080g
Wheelbase: 327mm
Internal Gear Ratio: 2.6:1
Drive: 2WD
Specifications:
Scale: 1:10
Power : Electric
Length: 550mm
Width: 293mm
Track: 245mm
Weight: 2080g
Wheelbase: 327mm
Drive: 2WD
This is all very interesting!
- Has thanked: 36 times
- Been thanked: 1318 times
- Group B
Re: SC10
Uh, what's up with the "sealed gear diff"?
Re: SC10
adjustable, yet no slip and usually stronger than ball diffs. This is the standard setup in larger scale race cars.Group B wrote:Uh, what's up with the "sealed gear diff"?
If this fits a standard t-4 gearbox I bet a lot of oval racers will give it a try.
- Has thanked: 183 times
- Been thanked: 157 times
Re: SC10
the slash is still cool imo. i doubt you can bash the sc10 at a skatepark like you can the slash...
and something waterproof is pretty sweet when you live in the winter wonderland that we do.
Re: SC10
I'm really liking the price, it's a kit, I love building and most of us have electronics we prefer anyway.
The only big question is how will it fit in with the slash class?
The SC10 doesn't have the high CG chassis like the slash so my best guess would be the AE truck would make a great "Pro2" class which either chassis would be allowed with maybe a 19turn motor, then the boxstock slash class that we run around here could be a seperate class, maybe call it "Pro2 lights" kind of how it's sorted out in real CORR (or whatever it's called now, forgive my ignorance). I really like the way the RC hobby is sorting itself out, it feels more like the days when the heavy metal class was around before the LXT and rc10t carved out the truck class.
Mark
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
Re: SC10
From the official press release, the fine print:
I'm so glad I didn't pull the trigger on a Slash.
And actually it's a sensored motor so nine wires...Note: SC10 shown equipped with items NOT included in kit: Reedy battery, XP servo, pinion gear, LRP ESC, motor, and receiver. Body comes clear. Assembly, painting and decals required. Team decals sold separately.
- MelvinsArmy
- Been thanked: 11 times
Re: SC10
That's one of the coolest new r/c's I've seen in a long time. Good thing I really don't have anywhere to run one around here or I'd be getting one. An SC10 class at a track would be a blast. Scale looks and performance is a good combo.
- 673 Views
- 1115 Views
Last post by slotcarrod
- 20 Replies
- 2302 Views
Last post by fredswain
- 855 Views
Last post by purplenut
- 21 Replies
- 3034 Views
Last post by soniccj5
- 1704 Views
Last post by Kayne
- 2512 Views
Last post by JosephS
- 1499 Views
Last post by therigliveson
Users browsing this forum: Amazon [Bot] and 8 guests
