- TEKIN chassis build -
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
It's no good, I'm sorry, I've tried to resist but I'm going to have to comment on this thread and bump it because I'm wetting myself with excitement waiting for mine to arrive and I know others have bought a few as well. :D Just looking at some of the pictures here has really got me hooked. I still don't know enough about RC10s to comment but at the moment this is my favourite chassis conversion. Oh man I feel like I'm 5 again and Christmas is coming. :D
Here's my TC Showroom
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
Hey guys! I have a question: Has anyone had any problem setting the pinion/spur mesh on this baby? I'm using a 81 tooth spur and a 20 tooth pinion. I just can't get the pinion to reach the spur. It's like the transmission or suspension block is getting in the way. Anyone? I'm waiting on a few more front suspension parts and I'll post some pics when I'm done.
Thanks for pointing out this thead Mark (Ferretti).
-Rich
RichieRich wrote:Hey guys! I have a question: Has anyone had any problem setting the pinion/spur mesh on this baby? I'm using a 81 tooth spur and a 20 tooth pinion. I just can't get the pinion to reach the spur. It's like the transmission or suspension block is getting in the way. Anyone? I'm waiting on a few more front suspension parts and I'll post some pics when I'm done.
-Rich
i never put a motor in mine, so i tried it with that gear ratio. and your right, it won't mesh. the wire tabs on the the endbell are hitting the left a-arm mount.
with an 81/20, your at a 9.11 final drive. try an 84/21. that will give you a 9.00, and you should be able to mesh the gears without a problem. and the final drive is very close.
RichieRich
scr8p wrote:i never put a motor in mine, so i tried it with that gear ratio. and your right, it won't mesh. the wire tabs on the the endbell are hitting the left a-arm mount.
Ok, I just wanted to check and make sure I didn't build something wrong. The instructions are a little vauge. I have an 84 spur in my toolbox so I'll try that. I'm sure it will work. Thanks for checking. :)
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Re:
Post by adam lancia »
Ron Jeremy wrote:Asso_man!, scr8p... did either of you have an issue with the lower shock mount holes in the rear arms?
Primarily due to finding this damn board, I went out and unboxed all my old RC stuff and got to tinkering with stuff.
One of the things I had forgotten is how the holes in the Tekin arms were too big and the screw just slides in and out.
yes | no | maybe ?
I've got a buggy and truck kit as well and noticed the holes for the lower shock mounts are too big. I'm not going to use them anyways, stock rear end for me.
Brandon G
Re: TEKIN chassis build
Post by Brandon G »
Yup, they are definetly too big. What were they thinking?
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
I don't remember any problem with mounting the rear socks inside the arm holes, maybe try to use some longer screws? Anyway, I built it long ago, so can't remember exactly :? This is a pain to build anyway and the chosen design/materials are even more of a pain :|
Come and visit the stable
adam lancia
Re: - TEKIN chassis build -
True that the plastic is really hard to thread screws into but I have tons of faith that they won't back out while I'm putting in laps on the track :)
You might be onto something with the longer screws, I didn't try that...might give that a try if I decide to build it as it was intended to be built and sell it.
Group B
Re:
Post by Group B »
[quote="Northy"]How does the active bit work and what does it do? I can't see from the pictures./quote]
It looks like some variation of a watts link, but on an IRS.
