1993 Brian Kinwald Replica (last update 12/12/2009)
slotcarrod
Been thanked: 45 times
Re: 1993 Brian Kinwald Replica
Post by slotcarrod »
Going very well, great job Cedric! How soon are you getting the towers?
pottok
Post by pottok »
Hi,
Some news about this very nice project ???
Four
Post by Four »
This is an awesome build. Looking forward to the updates!
Has thanked: 220 times
Been thanked: 322 times
C'mon stop teasing us!!!!!!!!!!!1
kenooze
Been thanked: 7 times
Post by kenooze »
Don't worry guy's, I still on.
Just need to find the solution to do the metal fake rear graphite tower .
FasterLouder
Has thanked: 12 times
Been thanked: 56 times
Post by FasterLouder »
Cedric-You should be really proud of this car!
You've done REAL good on this one...It'd look real good parked next to a Losi XX CR Kinwald . :D
All The Way Alive
kenooze
Post by kenooze »
Yep, to follow, a XX 1997 replica and a 1995 Matt Francis B2 :oops:
kenooze
Post by kenooze »
The current improvement of the project, I designed the motor plate to be sure about the dimensions of each slot.
Now I could machin safely a NIP motor plate...
SteveK
Post by SteveK »
kenooze wrote:I'm back on the way !
Today I try to design the rear tower
Tomorrow, I work on the front one.
What's your comments, I'm right or not ?
Thank you for posting this; I don't have a rear shock strut and Tower doesn't sell them anymore, so I can use this to cut my own. 8)
littleVETTE
Has thanked: 6 times
Been thanked: 9 times
Post by littleVETTE »
cedric, i have a question about your front spindles and the losi aluminum axles up front. did you notice any play between the axle and the spindle? i'm asking because i have put the same axles in the same spindle that you have. and, i had to slightly shave the outter lip of the spindle so that the axle recess could do it's job of holding the wheel bearings in place(i noticed that you didn't shave yours, in the photos. which will have the bearings riding up on the spindle's lip, instead of the axle's recess). also i had to slightly enlarge the spindle's hole for the axle. with that done i have up and down movement in the axle now. the inside diameter of the losi kingpin hole is larger than associated's aluminum kingpin hole. this obivously is the reason for the movement, and not the modifcations i have done to the spindle.
philk
Location: I prefer Andys to standard arms of rc10-they are easier to clean and are better looking
Post by philk »
I know this is an older thread, but could you advise me on the spacing of the slots on the motor plate? Were these done with a ball end mill? Also, did you ever finish the front shock tower? I would love to see a dimensioned drawing of both these parts.
Thank you- this is a great car.
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
This project looks great! Did it ever get finished? Any pictures?
kenooze
Post by kenooze »
YES!!!!!!
One more step down in this project, the motor plate was finally machined.
Tomorrow, Iwill finish to work on and build the transmission, stay tuned 8)
That's a long project, but I'm confident to finish it before 2010...
kenooze
Post by kenooze »
Well,
Before securing the plate on the transmission, I have to finish the machining process.
Rising the lower edge of the plate (just under the two holes to secure the plate to the chassis).
Cutting the motor guard area.
kenooze
Post by kenooze »
The last improvements .
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarGoogle [Bot] and 9 guests
