RC10 Green Edition - Build
GreenBar0n
Has thanked: 1228 times
Been thanked: 798 times
Re: RC10 Green Edition - Build
Post by GreenBar0n »
Looked in to the shock options, and the CC shocks are $70 +tax and shipping.
Found some Team Car hardened anodized green with black aluminum cap shocks for $70, but cramming those on top of short arms doesn't seem like a good idea.
Going to have to polish the orange off the stock shocks, to keep the cost down.
Even if I were to chemically strip the orange, the surface would still need to be polished after the process. Would like to keep the inside of the shocks smooth to promote correct wear, so I guess that means I will have to polish them. Have some MacGuire's and Dremel, need to study up on how to do this without ruining anything.
GreenBar0n
Figured out the rear wheels so far, but still deciding on the front wheels and tires.
RC10resto
Has thanked: 1439 times
Been thanked: 548 times
Post by RC10resto »
Green needs the front bling IMHO :wink:
GreenBar0n
RC10resto wrote: Thu Jan 09, 2025 8:16 pm Green needs the front bling IMHO :wink:
Have I gone too far? :mrgreen:
Dangeruss
Has thanked: 360 times
Been thanked: 1169 times
Post by Dangeruss »
GreenBar0n wrote: Thu Jan 09, 2025 8:25 pm Have I gone too far? :mrgreen:
GreenBar0n
Too far!
Puffdogg
Post by Puffdogg »
Wow - such a sweet build!
Puffdogg
Post by Puffdogg »
With some of the resto's I've done relating to aluminium parts - shocks/chassis plates etc
- I just removed the anodising
- Polished them to a shine - polishing before anodising gives a better finish
- Have re-anodised locally(at a company) in a different colour to set mine apart from the standard kit
But in saying this - they look awesome but my shelf cars are dry rebuilt so can't tell if the shocks will hold any oil... :lol:
GreenBar0n
Puffdogg wrote: Fri Jan 10, 2025 4:02 pm With some of the resto's I've done relating to aluminium parts - shocks/chassis plates etc
How did you remove the anodizing in the past?
I've seen Lye (sodium hydroxide) used in many forms like Drain cleaner and Easy-Off oven spray, also have seen Zep purple degreaser used to remove anodizing.
Lye will go too far too fast if not watched, and Zep or Simple Green can take an hour or more.
Looking for the quickest and safest way to do this.
I have Simple Green here, seems like the perfect thing to try first.
If that won't do it, maybe this will :mrgreen: :
https://www.amazon.com/dp/B085FS4JTD
Q: can you please provide ingredients list for those who are severely chemically sensitive?
A: Benzisothiazolinone, Sodium hydroxide, Methylchloroisothiazolinone and Methylisothiazolinone are preservatives.
RC10th
Has thanked: 50 times
Been thanked: 1491 times
Post by RC10th »
Oven cleaner is the easiest and fastest method, just don't leave it in there too long, 5 - 10 minutes at a time.
GreenBar0n
After 13 hours in Simple Green, they smell good.
Going to have to get something more serious to remove the orange. Will try the Easy-Off oven cleaner first, and then the lye soda beads/flakes as a last resort.
MarkyDents
Has thanked: 1783 times
Been thanked: 637 times
Post by MarkyDents »
The original yellow can Easy-off is what you’re going to want to use. Your going to have to babysit it but it’ll definitely get it done and quick 8)
Hey Cru ! Go balls out 8)
GreenBar0n
MarkyDents wrote: Sat Jan 11, 2025 5:18 pm The original yellow can Easy-off is what you’re going to want to use. Your going to have to babysit it but it’ll definitely get it done and quick 8)
Ordering the yellow Easy-Off spray cleaner now. Thanks for another vote for this.
Couldn't take those Jackman 5-spoke wheels and tire-writing from the Sand Scorcher, made a different front pair for the GE instead, these are the Pargu wheel covers.
Need to go back over the tire-writing with a toothpick and wet Q-tip to clean up/sharpen the lines, and then touch it all up again with the paint pen. Not fun, but better than trimming a large pile of decals.
Has thanked: 264 times
Been thanked: 2007 times
These were mostly stripped with Easy-Off. I used a Dremel and brass wire wheel to remove any remnants.
GreenBar0n
juicedcoupe wrote: Sat Jan 11, 2025 5:41 pm These were mostly stripped with Easy-Off. I used a Dremel and brass wire wheel to remove any remnants.
Very clean, that's the look I'm going for.
I got both the aerosol Easy-Off and the liquid for soaking, should be here Tuesday.
