Assembly continues but it’s time for an update.
Arms, links, and shocks are fitted. I’ve turned some aluminum spacers for the top and bottom of each shock. The top spacers are threaded and effectively replace the nut that’s normally used to secure the screw to the shock tower. The bottom spacers are just simple collars.
The rear bulkhead has been modified and I’ve decided to retain the wing tubes for this car (more about that later).
The bumper is also finished. Kydex is very easy to work with; it cuts like butter and bends easily (with help from a heat gun) and, once it’s cooled, holds the shape like it was molded that way.
Most of the components are fitting well however I’ve discovered interference between the chassis and the rear suspension arm and this is preventing full droop. When I made the CAD model, all suspension arms were placed at the neutral plane (ride height) so apparently, I didn’t provide enough clearance under the pivot to allow the arm to drop. I’ll fix the problem by removing some material from the chassis plate when I pull the car apart for painting and finishing.
Masami’s car had a similar problem, but they chose to mod the arm and not the chassis plate.
- interference masami.JPG (58.64 KiB) Viewed 3327 times
I’m using set screws rather than the typical e-clips to retain the hinge pins. This solves a couple of problems; no fumbling with e-clips (I really hate installing them – who doesn’t?) and the screws effectively remove some of the looseness in the hinge pins from those oversized pin holes in some of the 3d printed parts. In fact, with the set screws fully tightened, there’s only a small amount of looseness remaining at the hinge, so I really don’t feel the need to fit oversized pins (that 3.5mm rod stock that I’d bought earlier). If the hinges loosen over time I can replace the current 1/8” pins with the 3.5mm rods.
I will use an e-clip for the castor blocks however; that part’s vertical pin is retained with a clip on the bottom plus the normal set screw through the center of the axle. The clip is necessary to distribute some of the suspension loading to the lower pivot on that part. Without the bottom clip, the car’s weight and all bump forces from the wheel would transfer to the block’s upper pivot alone and this could lead to a part failure.
When I pull the car apart, I’ll turn a shallow recess in each pin at the set screw contact point. The screw can key into this recess, locking the pin and prevent it falling out if the screw should loosen.
I’ve found the paint I’ll use for the printed parts. It’s not a perfect match to the nylon but it’s close. I’ll try wet-sanding the parts before painting them to remove some of the rough surface texture and, perhaps, reduce some of the stress risers that might lead to a fracture.
Next are bell-cranks and steering. Stay tuned.
