RC10 - FF10 -Done-
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: RC10 FF
Possibly try making a rack bar which should require less cutting and possibly could correct geometry with it a bit also.
- sandkil
- Has thanked: 795 times
- Been thanked: 623 times
Re: RC10 FF
Rack bar is a good idea and as you say it will fix the geometry a bit. Thanx!
I'm also tinkering with the rear wheel axles. I'm not a hundred percent sure what way to go.
Here's one way to do it. Just hoping the aluminum axle holds up and with the B4 servo link the tracking can be adjusted.
- romulus22
- Has thanked: 900 times
- Been thanked: 789 times
Re: RC10 FF
Love the creative fabricating!
For your swing arm axle, what about making new arms and putting a brake/bend behind the axle and running a screw into the back of it where you have the ball joint. Along with the bolt going through the king pin hole that should eliminate twist and shouldn’t get slop over time.
- Has thanked: 19 times
- Been thanked: 29 times
Re: RC10 FF
Awesome work
Not a fan of the FF concept itself, but I’m looking forward to seeing how this turns out
- sandkil
Re: RC10 FF
Thanks Todd,romulus22 wrote: ↑Fri Nov 06, 2020 6:58 pm Love the creative fabricating!
I could do that, but really makes things critical as I have to get the tracking/toe in right whilst machining.
What I might do is add a 10x10 mm profile screwed into place in the arm and with a oval hole for the ball joint/screw locking the toe in , but still have the possibility to adjust and a more rigid installation.
Faceniating how things evolve while discussing the subject.
Appreciate all your feedback a lot.
- sandkil
Re: RC10 FF
No turning back.
Chassis is drilled and we have what looks like a working steering setup. Some minor adjustments left, but overall happy with it.
- sandkil
Re: RC10 FF
Hind legs in the making (prototype)
Brain melt. The more offset on ball joint mounts the more negative camber with compressed suspension. Is this a bad thing with trailing arms?
- sandkil
Re: RC10 FF
Sacrilegious some may say!
I’ve had this Novak NER-3FM in a drawer for quite some time due to that someone before me had cut the housing around the crystal and it looked like crap.
Finally found use for it.
Mounted a Futaba 2.4 GHz R204GF-E circuit board in the Novak housing.
- sandkil
Re: RC10 FF
Fabricated stanchions for the upper chassis plate. They are on the thin side, but then again there’s six of em plus the battery box.
The battery box will be fixed with double sided tape to chassis and screwed into the upper deck.
Composite Craft Teflon tape under steering rack for smooth operation.
Redcat 76mm (end to end) dog bones are on the short side.. might need to find 80mm.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: RC10 FF
Those universals don't look anything too short to me. Too long maybe... how do they move when you compress the suspension?
- romulus22
Re: RC10 FF
How are you attaching the arms to the turnbuckles?
Obviously I don’t have your parts in front of me to try it. But, I believe, if you space the rear/more inboard turnbuckle up and mounted it on top of the arm instead of inline as pictured, that should help with some of the camber during the sweep.
Obviously test it and don’t just take my word for it. Hope it works
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
Re: RC10 FF
Just amazing craftsmanship. Thanks for the great info and pictures.
- sandkil
Re: RC10 FF
Hmm too long!?
the pins on the dog bone barely engages the outdrive. I do not wish to fling them to neighbouring zip-code when powering out of corner with suspension fully "extended"
Pic is when suspension is fully compressed.
- sandkil
Re: RC10 FF
Thanks romulus22,romulus22 wrote: ↑Thu Nov 26, 2020 10:25 pmHow are you attaching the arms to the turnbuckles?
I will test various setups. I'm not that happy with this set up. Does not look good and might try to machine new axles all together...
Was thinking of having a set screw as adjuster of camber... We'll see
- 48 Replies
- 20531 Views
Last post by Turbobuick
- 3303 Views
Last post by Beau S
- 1663 Views
Last post by MBesr25
- 2201 Views
- 1629 Views
Last post by SMOKE-DOG
- 4470 Views
Last post by WebSteve
- 1946 Views
Last post by JosephS
- 2099 Views
Last post by mrduckz
