Show me your Gold Pan electronics layouts
Re: Show me your Gold Pan electronics layouts
I moved some things around and came up with the attached below. I still need to secure everything down and zip tie the wires together to clean it up. Assume this is better. I moved the battery up toward the front for weight distribution and tried to keep it centered.
https://www.dropbox.com/sh/vabkf811tkaqo7v/AABoKqXqaDN6gg9i9UeuB8kLa?dl=0
- yellowdatsun
Thanks. So I hooked everything up to test it out and setup the castle esc, bind the radio, etc. How do I prevent the rear tires from ballooning? They are brand new tires/rims not glued but I do have the foam liners inside. Should I glue or tape the insides of the tires? I saw a few posts about adding holes to the tires or rims to prevent ballooning. Also saw a post where they lined the inside of the tires with duct tape.
- yellowdatsun
Tires just balloon, that's how it is. Most of the tricks have downsides as well. Just let them balloon and you'll be fine.
- duckhead
- Has thanked: 160 times
- Been thanked: 204 times
Agreed, make sure you clean the tires well with SimpleGreen, etc. to remove the mold release and glue the bead to the rim. Ballooning under power is normal.yellowdatsun wrote: ↑Mon Aug 21, 2017 12:33 pm Tires just balloon, that's how it is. Most of the tricks have downsides as well. Just let them balloon and you'll be fine.
- 1173 Views
Last post by DarthRacer
- 31 Replies
- 4897 Views
Last post by Sixtysixdeuce
- 48 Replies
- 4628 Views
Last post by Hcp22
- 579 Views
Last post by JPAE07
- 919 Views
Last post by shodog
- 21 Replies
- 2246 Views
Last post by vwjuice
- 2115 Views
Last post by rc10absuer
- 1374 Views
Last post by Marty
Users browsing this forum: Amazon [Bot] and 3 guests
