A little more progress to report.
I found a load of unused driveshaft joints in my parts box (on the right). I'm not sure if the worn one on the left is a different metal - IIRC there were upgrade versions available, so I wonder if that's what I have unused?
The front and rear suspension is coming together. All fairly standard at the moment as I just need to get the thing built and running.
This is my one 'cheat' from the later Procat. I don't have any of the rear lower wishbone pivot blocks, so am using the all-in-one Procat item instead. Quite simply it's the difference between running the car or not. TBH I think whilst it's stronger than the genuine XLS parts, I don't see it offering any performance advantage. Hopefully no complaints?
This is a work in progress. I want to try running double crashback uprights on the front to provide more choice of shock mounting positions. At the moment the panhead screws at the bottom foul the lower wishbone, so I've ordered some countersunk slotheads (gotta keep that period feel) which will solve the problem.
Along with those countersunk screws, I've also ordered some
hardened steel caphead screws to pass through the rear transmission to clamp it all together. These have 18mm thread on the end, so I ordered them about 5mm too long so I can trim off the excess thread and make the most of the extra material for strength. These certainly shouldn't bend, although being hardened steel they be more inclined to snap so some testing will be required...
