2014 stealth
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: 2014 stealth
Post by RC10th »
The no felt thing is a bit of a bummer but it is what it is. I'd rather have a stealth trans and no felt than to have neither at all. I would like to say thanks to all who have made this possible. The legend continues.
romulus22
Has thanked: 900 times
Been thanked: 789 times
Re: 2014 stealth
Post by romulus22 »
Is the felt gasket even really necessary on todays style of track?
knixdad
Re: 2014 stealth
Post by knixdad »
Of all things to be concerned about, the felt gasket is so very minor. I'll just punch out my own if I feel the overwhelming need for one.
slotcarrod
Been thanked: 45 times
Re: 2014 stealth
Post by slotcarrod »
Most team drivers never used the felt gasket bitd any way, it would cause drag! Remember, they built this new world as a racer, not a replica! :wink:
kaiser
Re: 2014 stealth
Post by kaiser »
all my current vintage racers have no gasket, no issues at all. i do regular maintenance though, but the gearbox isn't dirty.
janaya
Re: 2014 stealth
Post by janaya »
I run my 10T regularly as well as race it at least a couple times a month on a clay track. My motor get more gets more dirt then my stealth and I clean and check both every 2 months. It stays pretty clean.
Javier -
RC104ever
Re: 2014 stealth
Post by RC104ever »
All this time and I've been trying to keep my old felt gasket together because I thought it was a needed part. But because I'm a stickler for details, really how hard would it be to just make one from some kind of thick rubber or foam?
- Chris
Lots of cars...so many cars
Bottom Feeder
Has thanked: 13 times
Been thanked: 25 times
Re: 2014 stealth
Post by Bottom Feeder »
Didn't someone make a foam/neoprene/whatever gasket back then? Trinity or someone? I remember a dark gray material but it could have been purple, maybe even red. It's been a while.
It may not be necessary for a racer, but I'd still rather have one on a basher.
Re: 2014 stealth
yes, someone sold one that was red. Someone on the forum used that dense foam stuff you find in such things as kids puzzles and toys, kneeling pads, and gym equipment to cut them out.
really, with a sealed bearing, even a shielded bearing, it's not needed. otherwise, you would expect more dirt entering from the MUCH larger outdrive bearings, also much 'closer' to the dirt than the top shaft. I always wondered why they even bothered with that felt.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Re: 2014 stealth
Post by aip47-2008 »
Bottom Feeder wrote:Didn't someone make a foam/neoprene/whatever gasket back then? Trinity or someone? I remember a dark gray material but it could have been purple, maybe even red. It's been a while.
ETA made the super gasket.
Bottom Feeder
Re: 2014 stealth
jwscab wrote:really, with a sealed bearing, even a shielded bearing, it's not needed. otherwise, you would expect more dirt entering from the MUCH larger outdrive bearings, also much 'closer' to the dirt than the top shaft. I always wondered why they even bothered with that felt.
To help keep debris out of the pinion and spur, yes? I wouldn't think it did anything at all to keep the bearings or diff clean.
Bottom Feeder
Re: 2014 stealth
aip47-2008 wrote:ETA made the super gasket.
Nice. The gasket looks familiar but I don't remember that company. Interesting. Thanks!
hawgfanman
Has thanked: 14 times
Re: 2014 stealth
Post by hawgfanman »
Diff outdrives at $11.99 each MSRP on their website now! :mrgreen:
janaya
Re: 2014 stealth
Post by janaya »
hawgfanman wrote:Diff outdrives at $11.99 each MSRP on their website now! :mrgreen:
Now my vintage NIP outdrives can be put away never to be touched for a decade or so.
Javier -
glastornjet73
Re: 2014 stealth
Post by glastornjet73 »
The end cap looks to be there its between the case halfs
You Tell E'm Im Comin! And Hells Comin With Me
