CNC Mill Build Thread (Video and parts pics)
- Seabass
- Business Member
- Been thanked: 12 times
Re: CNC Mill Build Thread
Made good progress this weekend and I am getting ready to make a test cut of a shock tower. This will be the first part that will be cut with the machine. I am having problems with my PC though. I cannot get my software to unlock from the demo mode and I believe it has something to do with the operating system. The bad thing is I am running XP (as recommended) and there is not much support out there. I am scrambling to find all the service packs to update the OS. This is supposed to fix all my problems. I should have known putting a fresh load would give me problems.
Hopefully the next post will include a video.
Jake
Jake
- Seabass
- Business Member
After about 18 hours, I got the software to finally come out of demo mode
I now have the ability to run a program that has 10 million lines of code
I will have a video for you guys later tonight. Will be machining a new custom shock tower for my Traxxas TRX1.
Jake
Jake
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Can't wait to see this!!Seabass wrote:After about 18 hours, I got the software to finally come out of demo mode.
I now have the ability to run a program that has 10 million lines of code![]()
Jake
- Has thanked: 1129 times
- Been thanked: 3919 times
- Seabass
- Business Member
Alright guys, that was a lot of fun...
Actually I ran into a bit of a problem but I still was able to produce a part I can use
I wanted to run the shop vac to keep the dust from building up but controlling the machine, recording, and vacuuming was too much to do at once. I also did not want to run coolant cause I don't want the dust in my coolant just yet. I need to do some more research on machining CF.
The first video is the machine working itself around cutting the holes for the tower. I don't have a drill chuck for the machine yet so I had a 3/32 end mill go around and make all the holes. A drill would have been faster but this was all I had.
The second video was the profile of the tower. I only made 3/4 of a pass before I had to put the camera down to fix a major problem. You can see at the end of the video, the end mill was actually smoking. I didn't realize this but the end mill was not the one I wanted to use for the tower. I cut the video and finished the tower with the proper end mill and it came out great.
Things to do:
Setup a vacuum system
Finish mounting my coolant line
Finish the coolant splash guard
Overall, the build was not as intensive as I originally thought however I did have a few moments of confusion throughout the process. I still have a good bit to learn but as time goes on I will become more proficient with the machine.
Enjoy the videos.
[youtube]RMN3QuLiJY0[/youtube]
[youtube]lJlHbumFuD4[/youtube]
Things to do:
Enjoy the videos.
Jake, give me a call when you have a chance, I have some CF machining experience. There are some big things to do correctly, and some you don't want to do at all (like introduce fluid) ...anyway drop me a line-
Did you have a tool path already cut into.the MDF?
- Seabass
- Business Member
Reg because this was a test piece I did not bother with cutting the tool path in the MDF prior to the part. Before I machine the chassis I will plan accordingly and build a proper jig to hold the material. I will call you a bit later today.
Jake
Jake
- Seabass
- Business Member
Hey guys was able to cut two chassis' today. I was only going to cut one but I screw up the material placement the first time. I was able to save the chassis, I just had to make it narrower than I wanted. The chassis' are for a Traxxas TRX1 that I drew up.
I am calling the mill thread done for now and will posting pics of parts cut in the various forums where the builds take place. Looks like the 91 Worlds car will start making progress again...
Jake
Jake
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
Re: CNC Mill Build Thread (Video and parts pics)
Nice work Jake, feels good to accomplish something like that. Makes me want to try a few things like that.
I need a garage...
I need a garage...
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Wow...is great enough to have a mill. But to build and then have it work
priceless.
- losiXXXman
- Been thanked: 5 times
Great looking chassis Jake...Now, how about that ULTIMA!! ULTIMA!!!
Built your own cnc mill and are now making custom parts!? Wow!
- 31 Replies
- 5527 Views
Last post by durb69
- 1705 Views
Last post by fredswain
- 725 Views
Last post by shodog
- 768 Views
Last post by body snatcher
- 1536 Views
Last post by Rizzo
- 75 Replies
- 21834 Views
- 2298 Views
Last post by matt1ptkn
- 100 Replies
- 18502 Views
Last post by DerbyDan
Users browsing this forum: Elkcycles and 3 guests
