New reproduction and Protype parts
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: New reproduction and Protype parts
Post by klavy69 »
Justin33 wrote:Any word on the reliablity of the xx front bulkhead yet?
I believe them to hold up on the shelf just fine 8)
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
I figured my silence was good enough answer. :)
It failed spectacularly, I got hit on the track after about 5 minutes and the top split open just like it does with the original black ones. I knew it would happen, heck the parts fit so tight I was surprised it survived going together.
Thin 3D parts that don't have much surface area for adhesion don't work well under stress. The upper part of the bulkhead that meets the top brace is just such a terrible thin and weak design. Go look at the Duratrax Evader. Their copy of the XX redesigned that area to get away from that flaw. The Duratrax design is much better for strength.
So as of this time, October looks to be the start date for remaking the XX bulkhead with injection molding. I have a company that will start working on the CAD design for the tooling and then they will hand it over to a plastics company that I got a quote from way back in December. Shame Losi would't work with me, but they have other priorities.
Justin33
Post by Justin33 »
Thats tough to hear would've been awesome if i worked out but thanks for sticking with it and getting an injection mold done to keep these things rolling on the tracks keep us posted :)
mytimac
Business Member
Post by mytimac »
New prototypes
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
mmmm, those look nice. could you make me a set that fits 12mm springs 8) 8)
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Hmm, I was just thinking... what about a replacement top brace for the XX series that did away with the upper hinge mount? It would be useful to basically get more life out of a front bulkhead with a broken top hinge.
Put design it to go far enough forward to clear the xxt shock towers and include spacers to take up this space for the buggies?
I will add a rough sketch of this to this post from my tablet.
It should be able to be cut from a sheet of graphite or fiberglass if you could find it with thew right angle... It could be a "XX bulkhead saver brace" as it would save all those previously useless front bulkheads. As as it would use through bolts, for extra strength you can add a small thin nut to the slightly longer 4-40 screw to really reinforce things.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
mytimac
Business Member
Post by mytimac »
clm wrote:Hmm, I was just thinking... what about a replacement top brace for the XX series that did away with the upper hinge mount? It would be useful to basically get more life out of a front bulkhead with a broken top hinge.
Chris
That is actually a very good idea at first glance. Only thing to really have to worry about I see so far is not making the front so wide it can't fit through the hole in the XXT shock tower. It couldn't be 3d printed easily, too thin and weak at that bend. So sheets of something would have to be the material.
clm
Post by clm »
The xxt front shock tower would be the one to worry about, you might have to narrow it down to just the two top bolts or neck down the area right behind the shock tower so you can fit one end through move it over and fit the other side through. Although just the two bolts at top would probably be more then sufficient if used with a 4-40 bolt and nut so the threads in the nylon isn't what is taking the abuse.
Chris
mytimac
Business Member
Post by mytimac »
JK Racing wrote:mmmm, those look nice. could you make me a set that fits 12mm springs 8) 8)
This would be pretty easy to do I think. You thinking Losi 22 size shocks springs?
JK Racing
Post by JK Racing »
yep...22 12mm, AE 12mm, K-car 12mm, others I am sure.
mytimac
Business Member
Post by mytimac »
JK Racing wrote:yep...22 12mm, AE 12mm, K-car 12mm, others I am sure.
Ok, should be real quick to change. Try and print it out in the next few weeks and see if it works with my 22 shocks.
Right now getting ready to test on the track the a5010 and a2000 replacements.
But just got this off the printer, had been on hold while I made the initial launch parts. The printer decided to crash the head into the upper left corner when it finished so ignore how bad that looks right now. Did a test fit and fit perfect right from the start. Now I have to try doing some different test prints using different methods to make the part easier to produce.
Soon I can print out a chassis... just kidding!
hondaman
Post by hondaman »
So you are the guy behind oldrc.com.. I love your parts.. I just bought some jrx2 steering arms not too long ago and some shock mounts.. nice quality.. the arms are beefy and mounted up pretty well.. just had to clean out the steering post holes as they caught up on my posts.. no biggie.. once quickly cleaned (2 seconds each.. so yea quick) they were perfect.. works great and looks great too.. love the shock mounts I got today as well.. going to swap them in soon on my jrx2 and have a set for my runner yoke build.. even came with the little wrench to install them.. nice touch.. great parts.. glad you are around.. got my jrx2 up and running again thanks to you.. keep up the great work.. :wink:
Thanks again!
Shawn
knixdad
Post by knixdad »
Something has to be done about the front bulkheads, I just realized I am out of them again.
What's weird is that I thought I had 3 or 4 but I can't find them, but I don't recall using them. I'm getting old.
LosiXXkid
Post by LosiXXkid »
mytimac wrote:New prototypes
Any update on these bad boys??? :mrgreen:
mytimac
Business Member
Post by mytimac »
These are getting track time right now. So far so good. Run them some more and then the real torture test. I am going to let my girlfriend, who can't drive an RC car to save her life, test them. I am scared she will break something else on the car and those will be fine.
Return to “Losi Forum”
