2013 TEKIN VINTAGE OFFROAD NATIONALS • SEPT 13-15TH
Post about upcoming or past events.
kaiser
Re: 2013 VINTAGE OFFROAD NATIONALS • SEPT 13-15TH
Post by kaiser »
r/cat, an ezup is like a tent, keeps the sun off of you.
friday practice, i'm not sure when it starts. i'm local and head over after work and run until dark.
the race is well organized by erich, the original poster in this thread.
we get there early saturday, 8am ish. unpack your stuff, find a spot to pit and go check in. it will all be spelled out for you.
it's and easy race to attend. saturday can be a long day especially if you stay and watch the dirt oval race under the lights.
kevin107
Post by kevin107 »
speaking of tents/etc.. is there room for a trailer? We typically travel to bigger races with a small 6x10 (or 8x12? I forget..) enclosed trailer.. it's really no bigger than an EZ up, it's just a matter of if there is room to pull it in and park it somewhere..
RCSoup.com
kaiser
Post by kaiser »
in the parking area there is room. not sure about pulling it into the race area, you'll have to check with da boss, erich.
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
Do the Li-Po battery’s need to be ROAR or EFRA approved?
Cheers
Lars
My Feedback
kaiser
Post by kaiser »
nope.
Hcp22
Post by Hcp22 »
And is it still Hole Shot that rules on the track?
Cheers
Lars
My Feedback
kaiser
Post by kaiser »
hard to tell, i haven't been there this year, but holeshots or double dees are a good option, worn goosebumps too.
last year i used double dees i think.
Brandon G
Post by Brandon G »
I am curious, I think the Tamiya Toyota Prerunner (TA02 based 4wd truck) was released before the '94 cutoff date allowed by the Vonats rules. What class would thse fit in, Classics? Or maybe Heavy Metal? That would open it up to the later models as well since they really didnt change anything except for the body.
kaiser
Post by kaiser »
the manta ray, same chassis and similar release date, would race in classics. the top force's and later ta01/02 variants would be in 4wd due to all the fancy parts.
i think the general concensus is tub based ta01/ta02/df01 vehicles fall into the classics class, whereas the later frp double deck versions fall into 4wd.
stickboy007
Been thanked: 55 times
Post by stickboy007 »
I used to have a Chevy S-10 (ta02), which I later put Manta Ray arms on and a Pro-Line Dodge Ram body. Then I put a double deck FRP chassis on it and coverted it to a Top Force. Now I have a bunch of ta02 spares lying around (from other ta02-based projects)...so I'm going to take those and build up a ta02 with Manta Ray arms...again :) Should be classic legal.
j0pp3
Post by j0pp3 »
Thanks for the response to my questions earlier. Another one has showed up :)
In the 4WD class it says 10.5 and 13.5 brushless motors only. Does that mean it's actually two classes?
Cheers
Joel
bscotti
Post by bscotti »
it's either a 10.5 or 13.5 motor choice. Both run in the same class.
Classics rule, moderns drool
j0pp3
Post by j0pp3 »
bscotti wrote:it's either a 10.5 or 13.5 motor choice. Both run in the same class.
Thanks!
Cheers
Joel
stickboy007
kaiser wrote:hard to tell, i haven't been there this year, but holeshots or double dees are a good option, worn goosebumps too.
Don't forget Flipouts and IFMAR pins. I think I used Flipouts last year, and they were great.
Hcp22
Post by Hcp22 »
2WD front?
Cheers
Lars
My Feedback
Return to “Racing News / Get-Togethers”
